Jaguar XK-Series Engine Problems
in Jaguar
Some XK owners report engine hesitation, stuttering and other symptoms of erratic engine operation. Have you had these experiences and solved them, or are you having them now?
Charlie, Seattle
Anyway, this sounds like a computer problem..a total misfire...I just can't think of any other component that has control of that many functions all at once. I mean, no one fuse or relay could kill the ignition and work the trunk!
One would have to examine the wiring diagram carefully to understand how this all fits together.
Anybody no of a dealer who knows how to fix this ? The car is of little use running the way it does.
With a bad fuel pressure regulator, no pressure is maintained in the fuel rail overnight, requiring the fuel pump to pump fuel all the way from the gas tank, to repressurize the fuel rail and then start the car--in other words, the defective regulator bleeds off pressure overnight but not during the day.
