Ford Explorer Air Conditioner and Heater Problems
I have a 98 explorer 4.0 xlt SOHC. I have replaced the thermostat, and the heater control valve--both of which were bad. Had the heater core checked and it is ok; good heat going in and out of it. I looked at the blend box and it is operational as to when i go from a/c to heating... I am at a loss any suggestions would be welcomed..
PS the fuse is also good
Daren
Daren
:sick:
Sean
My overhead console air temperature is indicating 32 F when the temperature is 54 F. Does anyone know if this can be adjusted or reset?I don't even know where the sensor is located.
Resolution?
SUVs and Smart Shopper
Help
When the a/c is set on normal vent, the defrost vents blow a little bit of air out. I have read the posts in the Ford Ranger Maintenance and Repair post, but I am not sure if I can decipher the wording. Sorry, not very car hood literate.
Any thoughts/suggestions?
N
Scott
In other cars I had, it's been a loose vacum hose. I don't know if it's the same for an explorer.
to resolve this issue? If so, help! Thanks for insight.
I have a new problem, the direction controller will only blow out on your face. I took out the glove box and can see the problem. The silver arm the goes in and out of the (pressure box?) looks to be disconnected from the black plastic arm that moves to control the vents. Has anyone had this problem?
