Heater blower motor location
DiscGolfer1976DiscGolfer1976 Member Posts: 3
edited January 2024 in Mercury
I dont have any heat blowing thru the vents in my car, and all fuses I can find are good. Controls of vents all seem to work, I just have no air flow at all. Everything else seems to be working in the car aside from the cigarette lighter. Any help would be appreciated as it is now Jan in Wisconsin. I need to get the heat working asap.
Answers
  • thecardoc3thecardoc3 Member Posts: 5,869
    Year, Make, and Model information would help.
  • DiscGolfer1976DiscGolfer1976 Member Posts: 3
    1991 mercury capri, convertible, my bad, I thought it stayed under category I searched for.
    Unfortunately my service information system is very limited that far back. Your best bet will be to purchase information from AlldataDIY. They do have it listed. I selected the turbo version but they also have the non-turbo.
    https://www.alldata.com/diy-us/en/find-vehicle/plan?vid=10771
    The Capri was a European import so there weren't very many of them. Prior to that model the Capri and Mustang were very similar. If you just want to start searching remove the lower shield under the dash on the passenger's side, and/or remove the glove box. Keep in mind that being a European import it may have been designed to allow for right hand drive which could have the blower on the driver's side.
  • kyfdxkyfdx Moderator Posts: 272,501
    Australian, actually, I think.. :)
    Thanks much, I will take a look under the dash and see if I can find it. If I cant find it, then I will have to look at the AllData link you provided. I appreciate the help fellas. Hopefully I can find its location and a replacement part.
