coolant in oil
brittieboybrittieboy Member Posts: 3
edited January 2024 in Dodge
dip stick shows coolant or extreme mosture in oil. coolant in radiater just slightly low. changed oil didnt see any thing really bad
  • thecardoc3thecardoc3 Member Posts: 5,878
    During very cold temperatures, on some engines you can see a milky condensate on the dipstick or oil filler cap and not actually have a problem. The first key would be if you start losing coolant and have to add to the radiator to replace it. Just monitor the coolant level closely for a few weeks and if you aren't losing it, then it is likely that it is just condensation.
