Blazer Rear Wiper Problem
stevehenristevehenri Member Posts: 1
99 Blazer Rear Wipers do not work. Replaced fuse and motor. Rear window latch and rear defogger work. Washer fluid on rear also works. Ideas ?
  • repairdogrepairdog Member Posts: 948
    Supply power to the motor via a jumper and see if it works. Ground good also. If so check that dash switch out.
  • grose69grose69 Member Posts: 7
    The plastic gear inside the motor has a tendency to strip out as well. Push the switch then try to move the arm by hand. If you can feel the motor running, the gear is stripped.
  • gmc94gmc94 Member Posts: 4
    Hi i have some issues with my Jimmy my rear window wiper works but fluid does not come out i dotn know were i would find the pump can anyone help me
  • ron_a_tronron_a_tron Member Posts: 2
    i was just looking at my 1994 today, the rear wiper motor and pump is located at the back of the truck. and the small black hose that goes to the rear window is the fliud hose. the wiper motor is a combination pump and motor...
  • dart09dart09 Member Posts: 2
    I disconnected the rear wiper on my '99 Blazer LS and ended all problems. :)
  • paul_in_topaul_in_to Member Posts: 1
    Re: motor and pump being one, this is incorrect. The Washer reservoir has two pumps near the bottom. One for the front, one for the back. the hose passes near the motor, but the motor is unrelated. The switch has both functions built in, but the systems are separate.
