Spark plug wire resistance
kberthakbertha Member Posts: 1
Is there a rule of thumb for determining the
appropriate spark plug wire resistance? I have a
multimeter but am not quite sure how to set it or
what the reading should be.
  • jamesk9jamesk9 Member Posts: 18
    I have a 1998 Dodge Grand Caravan with the 3.3L engine and 18,750 miles on the odometer. My questions are:
    1. How long should the factory plugs and wires last. One parts store said, "don't come back until you have 100,000 miles on the van".
    2. Are the factory wires good, and are there other wires that would perform better? What gains would I expect to see (i.e. gas mileage, performance, reliability, etc.)?
    Any thoughts!!
  • oilcan2oilcan2 Member Posts: 120
    I have found the factory wires to be as good or
    better than your pep boy or auto zone "life
    time" wires.I have also had good luck with using
    a accel brand ig coil to replace your stock coil.
    I have had this eliminate problems with hesitation
    and rough idle.As for wires I have found "magna
    core" brand,they are available at"www.howellauto
    motive.com
