2008 Chevrolet Aveo Check Engine Light
I bought a 2008 svm aveo5 with nothing in itdrove about 40 miles and turned around because the check engine light came on. I got to the dealer and shut off the car. they read the OBDII and there wasnt anything stored. I drove another 40 miles and the check engine light came on a gain. I went back to the dealer and left it running. They were able to get the code. It was a misfire in the the engine. the flashing engine light according to the manual from the car also states that this is the problem. anyone have simular experience at any mileage level?
came on. Dealer hooked up code reader found out gas cap was loose. Gave it a few good turns everything aright now. Now that is a tight system.
many things were done as claimed > change O2 cable, chg TCM, change ECM, chg sparkplugs...... but every 3mths or so, the MIL will pop up again.
i get the same error codes always (P0300, P0700, P1702)
trying to see what option i hv now as is beyond the 3 year period.
:lemon: :lemon: ??
Goodluck!
Ron
This problem happens every morning when I first start the car. If I get to work and turn off the car, then maybe an hour later drive the car again, it won't happen. Basically it seems to occur when the car has been sitting for quite awhile, for example, by the end of the workday.
I have never had any problems with the car at all, just the weird thing with the lights. The check engine light never comes on at any other time during driving.
Any ideas on this? The dealership has been nice about it but seem to be clueless about helping resolve it.
