Navigation disks for an 02 Aurora
Anyone know what #disk and where Ican get them for the nav.systemin my 02 Aurora? Thanks in advance.- Don
Dave
I'll have to remember to bring in my disc set tomorrow to work, and I'll give you what I have. From what I understand so far in my research, yes, the nav system is fairly rare, and I'm pretty sure that '02 was the first year they offered it. The person I spoke to at GMnavdiscs told me they never updated the discs after '03 because they decided after that to go to DVD's instead. I would have to say that the '02's and '03's would likely be the same, as I find it hard to believe they would have made a design change for the remaining few that ordered it in '03. I have two discs, one covering the Northeast, and one covering the entire US Interstate system. Again, I'll try and bring the p/n in tomorrow, and we can work with that.
Dave
OK here is what I have. The Northeast is region 7, and the p/n for the disc is 25732171. If you look it up, the number supercedes..(I don't know if that means it is any more up to date in info than what I have). I also did not make note of the new number. Now if your dealer can't help you, I worked backwards, and because there are 9 regions, the beginning p/n for region 1 (I think..) should be 25732165. If you look this number up, is just says "disc" in it's description, and it too supercedes. So just keep going in p/n's to find the disc you need. These things aren't cheap..over $200.00 each! (You'd think GM would dump them at any cost considering they are so antiquated.) The nav system is a cool thing, however it's like the telegraph as compared to todays GPS that don't even need a disc!
Let us know how you made out, and if you need any more info on what I have. I have a friend in a GM Caddy parts dept. if I need more info myself.
Dave
My Aurora came with a double CD case, in which are two CD's; one for US freeways, and one for MCA (Map Coverage Area) 7. revision 5.1. It's p/n is 25733246 for the set. So I just guessed by going down two part numbers at p/n 25733244 for your region 5 set. If you look it up on line, (I happened to use the website www.newgmparts.com, which I think sells parts via your local GM dealer), the numbers come up described as "DISC" only..no other info. I called a guy I know, and found unfortunately the disc set I THINK you need is discontinued as of April 2006, and he did not see any in the system. I would probably have another dealer run it again to make sure, but understand that I am making an educated guess on what really is Region 5.
Now the only other idea I had for you is find out where your local GM dealer send the radios out for repair. Contact them and maybe with a little luck, they might have a disc for you. If you still need a call to clarify this, let me know. Good luck. Dave
I am also looking for the Navigation disks for an 02 Aurora. I just bought the navigation system for Aurora as well. I am about to install but I am not sure if it will ask for the code. When you installed your Aurora's navigation did it ask for a code ?
Oscar
