Honda CR-V Trailer Towing
There are a lot of discussions on this board about installing a trailer hitch. In fact, this was helpful in my decision to install a Class III hitch. However, I find very little about actual trailer towing experiences.
I am hauling my daughter 1300 miles to start her life in another city. I plan on towing a 5x8 enclosed UHaul trailer that has a empty weight of 900 lbs. What she has is bulky rather than too heavy.
My question is what has been the experience of towing using a 07 CR-V? Any cautions or things I need to be aware of? What mpg were you getting?
I typically tow a trailer with ATV total weight 1400 lbs. I had a 1997 CR-V AWD and would tow this load approx 400 miles in hilly terrain from Northern Arkansas to Southern Oklahoma. I did not turn the O/D (over drive) off during these trips. It was always a fairly agitating trip with the family because of the RPM changes and loud engine rev.
I know the 2008 CR-V has higher torque than the 1997, but now understand that turning off the O/D on the 2008 only leaves you with 3 gears! How fast can one travel in third gear? Must I turn the O/D off to tow? Someone who has experienced this situation......
PLEASE HELP
Honda advises to leave the transmission in D when towing on level terrain and use D3 when ascending/descending significant hills. Per the manual, trailer weight not to exceed 1500#, and loads over 1000# require trailer brakes (surge or electric). Also, the usual cautions about cargo distribution and possible overheating on long grades.
