Interior water leak
I have a 2002 Yukon Denali just noticed the driver side carpet is wet. Checked door & window seals also looked for other wet spots and found none. The wet area is in the center of the carpet on the drivers side I can not find where the water is coming from. Anyone experience similar problem?
"VERIFIED CONCERN WATER LEAKING INTO HEADLINER AREA LOWERED HEADLINING AND WATER TESTED FOUND WATER LEAKING AT DRAIN HOSES WHERE RUBBER HOSES CONNECTS TO PLASTIC HOSE. APPLIED ADHESIVE TO HOSES AND RECONNECTED AND ALLOWED TO DRY WATER TESTED NO LONGER LEAKING REASSEMBLED CONCERN CORRECTED.”
SUVs and Smart Shopper
I purchased our new/used Yukon XL Denali at the beginning of June. He have has some rain storms, but not many. Last night were driving in one for about 15 minutes. We then pulled into our sloped driveway. It rained some during the night not nearly has hard as it did when we were driving. When we pulled out of the driveway this morning, water came pouring out from the back seat seat belt hole and the headliner. Has anyone successfully diagnosed the issue on a 2007 Yukon XL Denali?
Thanks in advance for your help.
Rick
I apologize for the water leak you are experiencing. Were you planning on taking the vehicle to a GM dealership to be fixed? Please keep me posted.
Thank you,
Caron, GM Customer Service
Thank in advance, Rick
Armando
I apologize we cannot. We don't have that type of information. The dealer is in the best position to explain what is happening, as they are able to examine the vehicle. Please keep us updated on your situation. Have a great weekend!
Christina
GM Customer Service
I definitely recommend taking your vehicle into your dealer of choice. They will be able to at least diagnosis your vehicle for you as well as provide you a quote for the fix. Please keep me updated on your situation.
Christina
GM Customer Service
I put $30 gas in the car drove it down the street and came back start driving it again and the gas light came on... Can anyone help?
Were you planning on having the vehicle looked at by a GM dealership? Please keep me posted.
Thank you,
