A reporter would like to speak with you about your experience; please reach out to PR@Edmunds.com by 7/25 for details.
Oldsmobile Silhouette
1121315171826
  • jonbgoodjonbgood Member Posts: 157
    Does anybody know how to remove the vcr from the premier van? Thanks for any help. VCR is eating tapes now.
  • fstabrylafstabryla Member Posts: 1
    We have started having problems with the A/C. We live in Florida and use it frequently. The fan doe not seem to blow consistently with the same force. Sometimes on the 5 setting, it will blow you out of your seat and other times it has to be set on 5 to feel any air at all. Not a consistent problem, very sporadic. Needless, to say, mechanics cannot find anything wrong with the parts, I am thinking it might be a problem with the fan motor, or controls? Appreciate anyone with similar problems or suggestions.
  • shifty4shifty4 Member Posts: 53
    You don't say how many miles on the van? Just a thought, have you ever replaced the pollen filters behind the glove compartment? Clogged filters can reduce airflow considerably.
  • dirkdaddydirkdaddy Member Posts: 313
    I think I recall seeing a few people complain about the fan control switch going out, they would have to turn off and then back on to get it fired up again. I don't remember if the fan switch was the problem (on these computer controlled cars you can't be sure w/o looking it up) but I'd guess that's the the problem, bad contacts on the switch giving you varying degrees of power to the fan.
    DD
    2003 pricing for the Silhouette is now online here.
    Steve
  • jmeaselljmeasell Member Posts: 30
    Has anyone experienced a jack hammer-type noise while running the AC? This has been occurring lately on my 01 Silo when the compressor kicks in. I noticed a similar posting (#306) more than a year ago, but no solutions. The dealer can't duplicate the problem and says the compressor turns on and off depending on the load. I owned a 97 Silo and told him I know how the compressor operates, but this is not normal while running the AC. Your thoughts. Thanks.
  • montanafanmontanafan Member Posts: 945
    John, Have the dealer check the Auxiliary Thermal Expansion Valve for the rear a/c. This can cause the noise whenever the a/c is selected or compressor cycles on and rear fan is on, and lasts for 10 to 15 seconds. Good luck. Post back with whatever results the dealer comes up with.
  • kwitsup1kwitsup1 Member Posts: 1
    Hello all,
    We are in the process (or so we thought) of buying a 2001 Silhouette with 41,000 miles. We got a great price and are supposed to pick it up today. We have been doing a little reading here, though, and found many discussions about a problem with coolant levels in 2001-s. It just so happens that our test drive last night included a "low coolant" warning on the message center. Should we be worried? Obviously, there is no longer a warranty... THanks!
    Karen
    I wish I could tell you that the coolant problem does not exist, but for some GM vans, it is a problem. My 98 GLS uses about a quart every month. Not a lot by any measure, but there is a problem.
    Are other vans better? Not really IMHO. Hondas are very expensive to buy used, and they have more transmission problems than GM has coolant leak problems IMHO and have marginally comfortable seats, tinny radios and are loud on the road. Ford and Chrysler also have transmission troubles. Mazda is small and terribly underpowered (the new one might be changing that) and Nissan's, well that one I'm not familiar with but the Host Steve has one I think and I see them on the road. They are probably about average.
    Since that maybe an issue on your particular van, I'd get a mechanic to do a "pressure test" on teh cooling system (very easy to do with a PT tool) and check the oil for coolant. I'd also look into a warrenty and price the gasket repair so you don't over pay. I think I've heard of $600-1000 bucks US for the fix.
    The good thing about buying a used domestic is the steeper depreciation curve which gets you more for your money.
    Good luck
    DD
  • kkollwitzkkollwitz Member Posts: 274
    Our 99 venture has used a gallon of coolant in 50k miles....the most of any car I've owned. But if I could pick something to be wrong with a car, using coolant would be a great choice. To me, adding fluids ocaasionally is a yawner. I don't worry about fluid consumption unless there's some other problem it points to. For example, I owned a Mustang that used a quart of oil per 800 miles....but it didn't smoke, power & mileage were fine, so I didn't worry about it.
  • indrgbindrgb Member Posts: 115
    Has anyone had coolant leak problems other than the leaking intake gasket?
    BTW for anyone interested, I just got back from a short vacation in my 2000 Silo. I had seven people in the van (3 kids) plus all the luggage we could cram in. The van was fantastic. Smooth, quiet, enough power. I got 23 MPG minimum which included a significant amount of stop and go and driving through some small mountains. The TV/VCR was great. My kids usually fight all the time but pop in a tape and they're fine. And they don't even mind wearing the headphones if we want to listen to the radio.
    Ron
    I have a '99 Quest and it seems to be doing ok, although lots of people have had their problems (electrical, esp.). I just got back from a few days in the UP of Michigan and the only "foreign" cars I saw were 2 Subarus and 1 BMW X5. I was really amazed at all the Ventures, Silhouettes and Montanas represented there (in addition to the many Caravans and some Windstars). Been a few years since I was in "big iron" country.
    Remember that people tend to complain when their van has a problem and don't speak up when it's running fine (thanks Indrgb & Kkollwitz for being recent exceptions to the "rule").
    It's probably better to compare the problems posts here with the ones other vans have rather than just reading this thread and thinking the vans fall apart once they leave the lot!
    Steve
  • bopper88bopper88 Member Posts: 3
    I just wanted to mention here that I had a Venture, loved it, bought a 2000 Silo GLS, only problem I ever had was the heated driver's seat failed twice and a resistor needed to be replaced in the heater blower (under warranty), and I am today buying a new 2002 Silo. 5 years 0% interest and paying invoice cost. You can't beat the $1,500 loyalty rebate, the $4,000 rebate or 5 years free interest, and the 5 year or 60K mile warranty....
    If this will be your third GM Van in the 6 years they have been out, that means you may not get to the 60 months as owner. Wouldn't you then be better off with the $4,000 rebate, to lock your savings in up front?
    Yes, you are correct, maybe if I thought that far ahead. This did result in the lowest payment, though, and I do hope to keep it longer, what with the longer warranty and all. Who knows what incentives they'll have later?
  • sickedssickeds Member Posts: 5
    Had what appears to be the same problem with my wife's '98 Sil a couple of weeks ago. Turned out to be a fan control module. There's a module for speeds 1-4; and a separate module for speed 5. The one for 1-4 was burned out. Works like a charm again. Good luck.
  • dukeofchurchildukeofchurchil Member Posts: 6
    I have just tried to buy a manual such as Chilton's of Hayne's for my Olds Minivan. Seems as though they are not out yet. I does not set well with me to pay $30.00 to change the fuel filter. Does anyone know where to get instructions on fix it items for the Olds Silhouette? And at what cost?
    I have a Haynes repair manual for 97 thru 01 models. The catalog number is 38036. I bought it at Advance Auto (Parts America) for $15. I think they recently came on the market. If you're just looking for basic info like how to change the fuel filter, then it's fine. If you want something with details on everything, then get the GM manuals for $120. Or maybe you could get lucky and find a used set on ebay.
    The GM service manuals are the opposite of the Haynes books, they have so much incredible detail it can be difficult to locate what you need.
    There must be about 60+ pages just on the operation of the electric sliding door for instance. One thing I took away quickly from skimming them is that the body control computer logic is quite involved. I recommend the books however, but be aware they are far from a "dummies guide to GM vans".
    Just the sections on programming the body computer and stuff like that is valuable.
    Funny, they don't have much on rebuilding the motor like they used to in the old manuals with setting the specs for crankshaft clearances and whatnot. I guess they figure the motor will be replaced as a core in today's shop. There is probably a different GM manual for engine rebuilding LOL.
    If anything the books look impressive on your shop wall.
  • blackcurrantblackcurrant Member Posts: 152
    Hi all. We bought our Silo new 3 yrs and 37k miles ago. She's definately been good to us. Never standed us or had unusual problems. The dealer replaced the intake manifold gasket last year due to an oil leak..we didn't request it...they just did it. The alternator died 1 month BEFORE the warranty expired last June. They took care of that for us as well. She runs as well as the day we bought her.
    We had to replace the original General tires. They rode well in the beginning but, by 25000 miles they were noisy and we experienced hiway vibration. CHUNKS of tead were peeling from the tires. I kid you not! Very dissappointed in GM with those lousy tires.
    Now, question. Since we've replaced them the gas mileage has dropped to around 19 MPG. We had the usual 21-25 MPG until recently. Anyone have any suggestions? Could the tires drop the MPG so much?
    Mike
  • jeberjeber Member Posts: 91
    good to hear! I just bought an '01 silo with 30000 miles, I'm always eager to hear that people are pleased with theirs.
    I'm gonna be watching for intake manifold problems like a hawk! In past vehicles I've had, that would be something easily repaired myself, and although I probably could handle it in the silo, the way they have that motor jammed in that little engine compartment, with no room to spare, has me a little scared! lol I'll let the dealer's mechanics fix it under warranty if at all possible, if it comes to that...
    as far as tires, I've heard more than a few people say those generals were not a very good tire, I'll stay away from 'em...what type did you get as replacements? I've always had great luck with dunlops...michelins, for the most part, are good, esp. if you get into their high $ models. I've just purchased my first goodrich LT for my '95 pathfinder, although only at < 5000 miles, they seem real good.
    gas mileage is definitely a concern to try & nip in the bud. first thing I would do is make sure tires are not REALLY low, although with that mileage drop, they would have to be about half flat, quite noticable visually, I would think. I would jack up front, & then back & make sure a wheel is not hung up with a brake problem or the like (just spin 'em, make sure they seem ok)(or go to brake shop with free inspection, but BEWARE some will create problems/repairs out of thin air)
    otherwise....oil changed regularly? air filter?(although again, this probably wouldn't account for 6 mpg)
    lastly, you might have your injectors cleaned...with professional system, not just the pour-in-the-tank stuff
    is trans shifting as always? not stuck in 2nd or 3rd or anything like that?
    other than that, call in the pros, I guess, do a computer diagnostic check, possibly an emission system problem making it run rich or something, which would be good as (I believe) emissions equipment is under factory warranty for 75000 miles...
    let us know results, good luck
  • buckeyevanbuckeyevan Member Posts: 1
    I have a 1999 Silhouette with 39,500 mi and the dash lights periodically come on and stay lit (lights only come on when starting the engine, never had them come on while driving). Sometimes the "brake" light with stay on too. I've had service look into this and they have changed out both the brake control relay and the ABS (EC) module. Still having the same problem. Anyone else had a similar problem and a possibly solution?
    Have really enjoyed the van, but fortunate that I have an extended warranty. This is getting costly.
  • jmueljmuel Member Posts: 1
    I just noticed a vacuum line running down the passenger side along the frame under the van. It stops about halfway back and is open. Any ideas on where this line is supposed to go? I'm sure it is not supposed to be open.
  • nkairnsnkairns Member Posts: 27
    I purchased a 1999 Silouette GS short body length last July. On cold start ups the engine makes a clicking sound (almost sounds like a valve lifter or something). When the engine warms up the noice goes away. I'm told this is normal for the GM 3.4 litre motors and the sound is caused by the pistons expanding as the vehicle warms up. It appears the pistons are made of magnesium which contracts when cold and this is what is causing the noise.
    Does this sound right to everyone?
    I must say I'm not so curious I am going to jack up my van to see what you're talking about, but its probably a transmission vent or something like that. You have to allow for expansion of the air in the transmission or it would blow seals, so the vent is needed. It could also be a a/c drain. why worry?
    the piston noise is normal, its due to short piston skirts, loose rings and loose fitting pistons when cold. metal expands when heated and then it tightens up. if it was tight when you started it woudl seize the motor more than likely. Most mfg's find a way to engineer around a noise like that, but not GM, they don't care. I'm not ripping GM, I like my van, but the attitude of what the customer will and won't accept seems different at GM than say Honda or Toyota.
    The loose fitting pistons make for a low friction engine and great gas miliage.
    DD
    I've read there are coolant leak problems on the 3.4 litre motors. Does anyone know exactly where the coolant is leaking and what measures can be taken to ensure this doesn't develop?
    Some people have reported coolant leaks from the intake manifold water passages connection to the cylinder head. The intake must be removed and new gasget installed. Not a do-it-yerself job unless you like huge jobs, but a shop can do it in one day I'd guess.
    My 98 looses a little bit of coolant every few weeks, but its not enough right now to warrent fixing. Other brands have their own problems, which are usually worse like transmissions.
    DD
  • artic1artic1 Member Posts: 4
    I have a 2000 Silo, 52k, and the heated passenger seat is not working. I swapped the module or box under the seat from one to the other and it still doesn't work, any suggestions?
    Fuse?
  • jjkewljjkewl Member Posts: 7
    I have a 2001 Silo and I've noticed last weekend that the AC is not blowing enough hot air when set to the hottest position. Have it checked yesterday and found out that my coolant is low and the gasket is leaking. Seems to me this a common problem. If you noticed that your coolant level gets low over time, have it checked immediately. I don't know why the message center didn't show anything ( such as LOW COOLANT ) Luckily it's under warranty.
  • bcd99bcd99 Member Posts: 45
    Good advice on watching for coolant leak. I know GM can be backwards, but doesn't the AC usually blow cold air. *S* I just had the keyless remote on my 01 silo break where the key ring went in. Dealer says they gladly replace it on Tuesday for $150 today. I'll get one off ebay thank you very much.
  • bob550kbob550k Member Posts: 148
    At 33,500 we just replaced the front tires on the van, those General sure did shake. The previous owner never rotated the tires so the rears are in excellent condition. There is such an improvement in switching to Bridgestones just on the front I can't believe it. The front brakes looked pretty worn, I guess I'll have to do those soon but who can complain at 33,000 + miles out of the front tires and brakes.
    Funny I do have the same problem too but in my case it's the rear tires that were cupped badly. I thought a rotation would work but it made it worst. At 31,000+ miles my front brakes were worn out too, I have it done together with my gasket leak ( coolant problem ). Did you notice that at this mileage the van would start to fall apart ? screws in the fender and in some body parts would come loose and fall apart. I have the ceiling trim checked too since they might fall on me while driving, aside from making all those noises and rattles..
    I've checked the fuse and it is fine, just the passenger seat not working. I was thinking maybe the heating element in the set was bad. It heated one day and the next day it wasn't working.
  • ronsmith38ronsmith38 Member Posts: 228
    I am having tire problems also with the Generals. Which Bridgestone tires did you purchase?
    $150 for a remote is high, I got mine at a dealer for about $115 (if you ask for a discount sometimes they will do it) and then you have to do a programming technique to get it to work. If you don't own the GM service manual with the process in it, you might need to take to a dealer anyway. You might find a web site that gives the process, its not hard just have to do things in order. I have the process in the glovebox (dealer gave me the printout of how to do it) and can post it if there's sufficient interest.
    DD
    Just FYI, in dry and "normal" operating conditions you can mix new/old and brands of tires front and back w/o a lot of problems, but beware in rain and/or snow or in emergency situations. Its wasteful but safer to replace all 4 for balanced performance, if that word applies to a mini-van (G).
    I had a beater Mazda pickup and I'd get free tires from the tire recycling pile and put them on. Yea, it wasn't optimal but it worked. Always put 2 at a time on, but the thing was just used as a work truck for my house.
    The worst part about it was the size (205 15" if memory serves) was mostly a passenger car rated tire and I ruined a few what seemed to be good tires by overloading them on the pickup taking debris to the dump. Would have the thing loaded till the axle was resting hard on the stops. Had a lot of broken belts and stuff like that.
    Should have just bitten the bullet and got new tires, live and learn.
    dirkdaddy,
    can you post the procedure for programming the remote. one of the original remotes broke and i was able to purchase 1 in e-bay for $6. The dealer will charge me $50 if i let them do it. The remotes are for 2001 Olds Silhouette.
    I usually don't mix the tires, but they are the same size and the rears are better than 50%. The new fronts and now new brakes with ceramic pads and turned rotors compelety eliminated the shakes.
    No I can't say the van is falling apart at all, it's still solid and nice. But your's however at 31,000 miles cupped wear is not normal. That is a sign of suspension damage, worn struts or out of round tires. You may want to have your suspension looked at. Whatever is shaking bad enough to cause cupped wear would shake most cars to death. Mine had a mild shake, not enough to cause irregularities in the wear pattern on the tires. Even if it's just the tires causing the cupped wear, not repairing it for a length of time will lead to other more expensive problems. I can understand why screws would be coming out of the vehicle if it is shaking hard enough to cause cupped wear. Somewhere out there exists a video of how the tire hops at speed to cause that type of wear, it's kind of unsafe to drive like that.
    Regarding the coolant leak, my mechanic made the blanket statement "All of the 3.4's do this, but it's still a more reliable car than the Ford or Chrysler" but that's just his opinion. Mine has not started to leak yet.
    Dirkdaddy,
    please do post those instructions. I was going to take the guts out of a new one and replace with guts from mine. But would be better to program new one. Seems funny how easily my 2001 silo key remote broke, I only use it on weekends since van if wifes vehicle. Been using the key remote on my 96 everyday during the week since I bought it new in 96...no problems with it. But of course it is thicker and better made. Thanks for making things cheper GM
  • banddexpressbanddexpress Member Posts: 63
    was thinking about buying a 2000 its a decent price with 44k on it I was concerned about the crash scores though. I was wondering if anyone had any experience with a crash happening.
    Dang! Ebay remote for less than $10?? Man, I wish I had thought of that. I feel stupid for going to the dealer and paying about $100. But I had just got the van used and wanted to get all the "stuff" to make it like a new one.
    On the front suspension, if you are having pulling or wierd tire wear have the suspension checked out. My van when I got it @62k miles needed outer tie rod ends, but I did it myself for less than $50 if my memory serves me right.
    I'll dig up the programming and post it.
  • vistacruiservistacruiser Member Posts: 7
    I had the "Service Engine Soon" light go off on our Silo. This is a 2001 with about 25,000 miles (mostly highway driving). A quick call to OnStar determined that it was a relatively serious emissions control failure and that I should go to the dealer within 7 days (that seems to be their standard advice).
    The dealer has it for a day, and says that the catalytic converter has gone bad, and a new one will have to be ordered (7-10 days). I ask the service manager what specifically happened. He says that the diagnostic code off the OBD II pointed to a cat failure. I ask him what was the diagnostic code. He says that he doesn't know, but the tech might, and he's gone home for the day. I call the second day after and am told that they usually don't like to have the techs talk to the customers as they are busy working on the vehicles. Fine, all I want to know is why did the cat fail, and if they are sure that there are no upstream problems (oxygen sensor, unburned fuel, etc.) that will cause a second cat to fail. He says that usually it's a mechanical failure (breakage of internal parts) or the cat gets clogged. They can't be sure exactly without opening it up, and that's usually more trouble than its worth (better from a labor cost point of view to just replace the part). He says it's not likely that a second cat will fail. I ask him if he's seen this before. He says that he hasn't seen it on a Silhouette, but has seen it on a Regal.
    Have any Silo owners had a cat failure? If so, did a replacement cat fix the problem long-term or did the replacement cat fail?
    I suppose that I shouldn't worry too much, as this is a relatively new vehicle still well under existing warranties. If they want to swap parts to their heart's content, go for it. All I'm out is a quick drive up and back, and I get a newspaper, a cup of coffee, and a pleasant chat with the shuttle driver for my troubles.
  • jackjtjackjt Member Posts: 178
    I've noticed that the carpet along the passenger side (outer part/side along where the carpet and sils met) of my Silo is showing signs of leakage. Large rust spots on the carpet.
    Anyone else experience this problem?? What have been the fixes?
    Something is seriously leaking. Look at the AC drain, door seal, windshield seal, etc. One way to see where the body is leaking is to put the fan on high and close the car, put soapy water all over it. If air is escaping it will blow bubbles. either that or your passengers are total pigs!!
    LOL
    Check in the jack compartment for signs of water. May have a leak around the wheel well on that side. Dealer should be able to check it out and fix it. Another potential source of repair is a body shop, they should be able to check and have sealant as needed.
  • rylesryles Member Posts: 19
    Is the Silo available with the 8 passenger seating linke the Venture? We have an 18 month old and are expecting twins. I'd like to be able to put all three in the second row for the first few years until they get big enough to complain about it.
    Ryles
    I've got the same problem on a 2001 Silo with less than 30k. Driver-side heated seat is intermittent. Inverse Murphy's Law dictates that it will be working when I bring it to the dealer, and they will insist that they cannot diagnose faults in a system that nominally appears to be OK.
    (Troubleshooting is clearly a dead art. Labor costs and OBD-II killed it.)
    As with the original poster, there are no obvious problems like a blown fuse or loose wires under the seat.
  • dlubindlubin Member Posts: 66
    Ryan,
    Not available on the Olds, only the Chevy and Pontiac.
    Dan
    Thanks for the pig suggestion. Would have never thought of it!
