But the iQ is expected to have the 1.3, the biggest gas engine offered in that model elsewhere in the world. And I would expect mileage well into the 40s, so if a 3-seater is your thing (I think of the Echo as a 2+2), it could be just the ticket. Certainly it looks like a good candidate for a commute car.
See you at the next 50k!
RJ
See you there!
I think a large part of my excellent battery life is I drive the car exactly the same every day. 6 miles to work and back. Very consistant. Of course the ECHO is a very high quality car and that counts for a lot too. That and I add water to the (nonsealed) battery every four months.
I bought a 2000 ECHO with auto for $3000 and 117,000 miles a year ago for my son to drive to school. (it was used for a 50 mile daily communte) Its been a year and the car has been no problem at all 9000 miles later. He got 43 mpg driving to the Catskills with two friends last weekend.
Auto tran, fully loaded with books and clothes, air con used the whole trip (Georgia in August!), 5.5 hours: 42 mpg.
The main thing is that my radio and clock stopped working about two days after I bought it, I plugged in the cigarette lighter and the radio and clock shorted out. I was sure it was a fuse, and I replaced all of the 15amp fuses in the fuse box, and the 30amp too. The radio still doesn't work. Either I still cannot find the blown fuse, or it's not a fuse problem?
Also, the car is generally really noisy. When I have my foot on the break at a stoplight, it makes a noise like something might be rattling and causing a noisy vibration. When I accelerate, the car is pretty loud as well. Is this normal?
I am hoping I bought the right car, I have faith in it, but I'm a little nervous! its has 92k miles which didnt seem too bad. Do you have to get the timing belt changed or is it a chain instead? The car didnt come with a manual.
Is the check engine light on? If so have the codes read at Auto Zone for free and tell us what they are.
There are more fuses in the engine compartment perhaps one is blown in there. Look for a plastic box under the hood that looks like it might be a fuse box.
Sounds like you have brake and muffler issues which need a mechanic to fix. Hes a test you can do. In the morning BEFORE starting the engine. Start the cold engine and go to the tailpipe with a heavy rag. Use the rag to plug the tailpipe air tight. You should feel back pressure and perhaps air hissing out of the exhuast system. If you have ZERO back pressure on the rag then there are holes in the muffler/exhuast pipe and the exhuast system needs work. PLEASE do this test with the engine cold so you dont get burned.
If it's a vibration that shakes the whole car but lessens while in neutral and stopped, or when you take your foot off the brake it's probably the motor mounts. That's actually a fairly common issue with the Echo it seems, and is more annoying than anything else.
If it's a knock you could try bumping up a grade in fuel. I know it says you only need 87 but I've found as the mileage rises the engine benefits from running on 89 instead.
So, for me it's tire time. Tell me out there in Echoland: what tires are you running? I could get another set of Toyo Spectrums, the ones I have now did the full 65K they promised, but I'm also thinking of spending a bit more money for Michelin Harmonys, which are supposed to be quieter and give me 80K miles, in addition to better wet-road traction.
So do tell, what tires do you have on your car, and do you like them or hate them?
But something tells me your not a cheap tire guy?
I got a quote for $100 less than the Michelins on four Yokohama Avid H4s, which are a great tire for medium money, but I know that they would knock down my fuel economy by a solid 10% and I don't want anything to do with that. The superlative fuel economy is the main reason I still have the Echo, and am contemplating keeping it for another three years. I don't even want to THINK about dropping below 40 mpg! *shudder*
Hey kneisl, what tires do you have on YOUR Echo?
My wife's still got the original Bridgestones on her Yaris and I don't know that I like them that much - I'll probably get Sumitomos for that when it's time.
BTW I have 218,000 miles on the car and looking for the 2 door hatch Yaris 5 speed. .Nothing wrong with car, just giving it to my son.
Test drove one . What a car! Very fast to merge speed on highways. Quality bulit like my echo The car I test drove was sold next day. Now im looking most dealers around here are out they say becasue of CFC.Im in eastern PA
It could be titled: "Echo/Yaris Instrument Lights - blue/green Temperature light/Automatic doesn't up-shift" or something to that effect followed by the basic explanation:
It's completely normal. The light stays lit until the engine is at it's appropriate temperature at which time it will allow the automatic transmission to upshift.
Hey Mods... what do you think?
1) shift cable faulty
2) synchronizer ring worn
3)shift key spring dammaged
I looked at the pictures and there are two synchro rings on the output shaft and two on the input shaft.
Right off I notice it is a softer tire (the Harmony is S-rated as the original tires were; the Toyos I had before were T-rated) but that's not a bad thing. Echo is no race car to begin with. ;-)
There is less impact harshness over bad pavement than I ever had with the Toyos. And supposedly this is an 80K-mile tire, which means if they perform to expectations, these may well be the last tires I ever buy for this car.
Now I'm crossing my fingers that I will also get better wet traction when the rain starts in a month or so......
