Mercedes-Benz E-Class Sedans
19798100102103131
    Their are many advantages to more gears: faster shifts, better gas mileage, improved accleration being the main ones. A gear for every almost every situation, only a CVT is more flexible. BMW, Ferrari and even Porsche all have 7 speed boxes on the way, either in manual or SMG/F1/DSG form.
    M
  • px260px260 Member Posts: 42
    Just imagine you are going 100mph or so and your tech shows the dial at the 3k rpm mark - lots of room to go provided there is enough hp to propel the car. I won't be surprised if the top speed on the E500 sedan will reach 180+.
  • footiefootie Member Posts: 636
    Where do we use that speed? Why is that relevant to a modern day car discussion?
    Do you think that an E500 is stable on U.S. interstate highways at 180 mph?
    Thats 264 feet per second.
  • mbnut1mbnut1 Member Posts: 403
    I doubt that increasing the number of speeds would increase the top speed anyway. My 190e 2.6 was able to reach max speed in 4th not 5th. 5th was an overdrive for low engine speed cruising not max top speed.
  • jb_shinjb_shin Member Posts: 357
    I highly doubt it, drag will limit the speed.
  • habitat1habitat1 Member Posts: 4,282
    I suspect the 7-speed is 90% marketing and 10% performance driven.
    As far as a 7-speed automatic being quicker than a 5 or 6 speed, I seriously doubt it - perhaps just the opposite. Most cars make it 0-60 in 2nd gear requiring only one shift. No matter how quick the shifts are, adding a second shift would likely produce a slower time. And staqndard Mercedes automatics are not quick shifting, in my opinion. After test driving a AMG C32, my friend's E430 seemed quite slow shifting by comparison.
    The 7-speed seems particularly curious for Mercedes, considering they are pumping torque in their high performing cars. In my Honda S2000, all 6 gears are necessry to get maximum performance and the 150 mph top speed out of the 9,000 rpm low torque engine. Linking a 7-speed to a low rpm, high torque engine seems almost counerproductive to performance. If the engine is lugging along at 65 mph in 7th gear on the highway, how many gears will it need to drop to have some punch?
    Kudo's to the marketing guys for making something out of nothing.
    P.S. There is a parallel in wheels and tires. I have yet to drive a car under $70k that handles better than my S2000, equiped with 16" wheels and 50 series tires. Putting 18-19"+ wheels and 35-40 series tires on cars that are less capably designed from the gound up may look impressive on the showroom floor or in sales brochures, but doesn't necessarily translate to better performance where it counts.
    I'd read up on it before making such uniformed claims. It's hardly just marketing making something out of nothing.
    http://www.germancarfans.com/news.cfm/newsid/2030515.001
    M
  • boo20boo20 Member Posts: 85
    Clearly there is an improvement in BOTH acceleration to 60 (contrary to habitat's claim above) AND gas milage.
    If Lexus hasn't yet 'improved' upon it then they don't want to hear of it.
    Sour grapes.
  • jfz219jfz219 Member Posts: 63
    I am glad to see this new generation of 7 speed transmission. However, it is surprizing that introduction of the direct-injection gasoline engines has been delayed. The advances in the transmission will produce improvements in acceleration and fuel consumption in the 5% range. The new fuel injection technology should produce increases in the 15-20% range.
    Does anyone have any information on projected introduction dates.
    I read the link posted by merc1 and concede that the new 7-speed transmission appears to be a "real" improvement. And, in fact, it did answer my very question of how many gears it will need to drop from 7th to have some punch: 4 gears in total, but done in two 2-gear drops rather than four 1-gear drops.
    The article seems to suggest that the entire redesign - not just 2 more gears - will lead to improved fuel efficiency and performance. I just hope the new "driver adaptive shifting" or whatever it's called works better than on my friends E430. I have gone on record giving AMG credit for perhaps the best automatics I have driven (C32, E55), but I had been unimpressed with the standard Mercedes automatic when pressed beyond casual acceleration / highway cruising.
    So I am willing to stand corrected, notwithstanding that the article looks like it was written by Mercedes for reprint in "GermanCarFans". I will look forward to seeing actual road tests of the new transmission to see how well it delivers on its promises.
    New engines: I wish I knew when, but I'd guess with the debut of the next SLK, the GST and CLE we'll see the first versions of the new direct-injection engines. These new Benzes should all start debuting next winter, and spring 04'.
    However gradually introducing new powertrain advancements are usually the Mercedes norm. They rarely come out with a new car/engine and new
    transmission all in one swoop. This way the new gearboxes will have been proven before the new engines arrive.
    M
    Merc1,
    I know this might sound Incendiary but it's not 'personal'.
    What does 'proven' mean? How long does it take MB (or other car companies that operate this way) to prove that their 'new' eleventy-nine speed gizmos really work?
    Is that the marketing word that MB uses for 'beta' quality components in their cars.
    What a wild idea it might be for them to 'prove' something through significant testing before selling it to customers or maybe even, what other marques, do which is racing?
    How long does one wait for new MB technology to be 'proven'?
    You don't know what "proven" means? It's pretty self-explanatory.
    M
  • microrepairmicrorepair Member Posts: 508
    I hope the last two posts don't foretell the direction of MB's quality program. If so it sounds like they will become the GM of Europe. Letting the customers discover the faults with their "new" hardware was precisely what GM-USA did in the late 80's and early 90's. More than one mechanic told me that and I had personal experience with the 94 LeSabre which had 2 or 3 new components, one of which was the rotary AC compressor. Mine started to degrade just 3 years old and if I had kept the car long enough, it would have cost 3 times as much to replace it as the old piston type compressors. So I traded it for my current 96 E320, which at 120K miles just needed a head gasket and a water pump. Am I happy going from GM to MB ?? I'm not sure, mostly because the MB is a far superior car. But I have to wonder about the legendary robustness of a MB car.. Oh, it isn't just the head gasket and water pump; it is now on it's third set of front brake rotors and fifth set of front pads. But maybe I'm too hard on brakes, although this is the first car I've owned with that kind of problem.
    The top speed of any car may not have a direct relevance on US highways, (I typically drive 70 on freeways), but it has a lot to do with brand image and market leadership/bragging rights - it proves why your make is better than the competitors. This is part of the reason why we have Daytona and Indy racings. Why bother traveling at 200+ while you can drive safely around the circle for 70?
    The top speed has everything to do with gearing, hp, drag, chassis design/aerodynamics, etc. I am curious to know how the E sedan would do when coupled with a 7speed - 180 is merely my guess. Do not take this statement to the bank!
  • boiler1boiler1 Member Posts: 56
    180 mph might be a stretch for an E320 or E500. My current Road and Track lists only 1 car for under $100K that has a top speed of over 180 - the Dodge Viper SRT-10. In the $100K to $300K range there are a total of 10 cars in their testing universe that top the mark. As a matter of fact, the E320 and E500 are both electronically (should I use the term!?!) limited to 130 MPH in the U.S. and I seriously doubt there is another 50 mph left in either of those two models. The E55, on the other hand, is another matter altogether.
    I wouldn't take much of what footie says seriously, he's a MB basher to the core with no real knowledge of anything about Mercedes-Benz, other than what he's read in a survey. What I meant about being proven is that in order to reduce the number of potential problems, Mercedes has always introduced gradual advancements in their cars, it's been the case for over 100 years. They've hardly introduced all new engines/trans in a totally new car all at once, this is nothing new and nothing like GM's practices.
    M
  • westcoast323westcoast323 Member Posts: 4
    anyone know what to pay for the E55?
    Westcoast: I would be wary of paying a nickle over MSRP for an E55, preferably less. I have owned AMG cars in the past, and my neighbor recently taded his E55 for an SL55. They (perhaps with the exception of the SL) do not hold their value particularly well. Regardless of what the blue books say, a 2000-2002 E55 will generally sell at a discount compared to a 2000-2002 M5.
    The new E55 with it's significant power increase will capture the "gotta have more" buyer attention for a few months. But, in reality, the former E55 offered more power than 97% of the buyers could handle. The problem with the C32 and E55 in particular are that, after the power infatuation wears off, they are not as dynamically balanced or fun to drive as their BMW M3 and M5 6-speed counterparts. That's my opinion, having owned both, but it also seems to be supported by resale values.
    If you happen to be someone who would buy a 2003 E55 to hold on to for 10 years and 150k miles, then pay whatever you want. But I suspect that MSRP or below will be possible shortly. My neighbor got his SL55 for exactly MSRP.
    px260, et al: 180 mph for an E500?!? Be honest - you skipped physics classes?
    Forgetting lift and stability issues which would make the E-class a suicide car to drive at over 150 mph, just based upon air drag, wheel friction and other forces, 180 mph would require roughly 57% more power to achieve and maintain than 150 mph. The current 302 hp E500 is drag limited (not gearing limited) to about 155 mph. So it would take about 474 horsepower to achieve 180 mph. Factoring in lift which goes up exponentially with speed, you'd likely be airborne after about 175.
    If you have driven the autobahn, you will notice that the E-class is not usually in the faast lane. The S-class has better high speed stability as does the BMW 5 & 7 series, Audi S8 and a few others.
    I agree with epn2's analysis.
    I am taking as much advantage of being able to drive on speedlimit-free autobahn in Germany. I have driven the previous gen. E320 up to 125 mph or so, and did not feel much lift at all, same with BMW 530i. I did have a chance to test drive an M5 and gone up to 165 mph indicated (accounting for speedo error, more like 154 or so) and I could feel the front end getting lighter ever so slightly. This is the reason some of the German tuners will recommend aerodynamic and suspension pkg with the Vmax module.
    imho -
    I agree with epn2's analysis too.
    There's an article by John McCormick in today's Detroit News comparing the new Porsche Carrera to the Ferrari Enzo. The effort to get to real high speeds takes a special design.
    The Porsche has a V10 with 612 hp and a 6 speed transmission and is supposed to reach 205 mph. It's an incredible vehicle with a carbon fiber body designed from the ground up for very high speeds and incredible handling. These are areas that both Porsche and BMW have had as forté's for a long time.
    I don't think that an E Class will come anywhere close to 180 mph. That's not what it was designed for, nor will a 7 speed transmission make much a difference in its top speed.
  • benzownerbenzowner Member Posts: 20
    The Highest highway speed ever recorded: a Mercedes-Benz at 271.5 mph.
    I too don't think a stock E500 would be able to reach 180 mph, the E55 on the other hand would probably top 200 mph. The SL55 was clocked at 208 mph on the autobahn with the limiter completely deactivated, and the E55 carries less weight than the SL55. MT got AMG to tweak the limiter on the CL55 and it reached 187 mph with no sweat.
    M
    Don't tell me you also skipped your physics classes??
    The new E55 has 17% more horsepower than a M5. All else being equal (aerodynmaics, lift, etc), that would suggest a top speed of perhaps 6-7% higher than the 170+/- mph the M5 is capable of - or roughly 178-182 mph. From my experience and what I have read, however, the E55 - even the new one - is not as aerodynamically stable at high speeds as the M5. My guess is that I would have a greater likelihood of throwing a baseball faster than Randy Johnson as the E55 would be of hitting 200 mph (and the driver living to tell about it).
    As for the "clocking" of the SL55 at 208 mph, that sounds more like an urban legend than reality. Granted the SL55 has a few more horsepower than the E55 and is better designed for high speed, but, based upon my back of the envelope calculations, a 400hp Ferrari 360 with a top speed of 180 would need another 170 to 200 horsepower (i.e. 570 to 600 total) to achieve 208. And it's three quarters of a ton lighter and considerably more aerodynamic than the 493 hp SL55.
    By the way, in it's latest crop of engines, AMG has prioritized low end torque at least as much or more than maximum horsepower. That does produce some pretty impressive acceleration numbers. But 2800 rpm torque has no relationship to top speed at the top of the rev band. Many slightly modified muscle cars of the 60's and 70's could achieve quicker 1/4 mile times (under 11 seconds) than the best of the current AMG, BMW, Ferrari and even Porsche offerings thanks to 500-600+ ft. lbs of torque. But very few of them had a top speed that could match the 153 ft. lb Honda S2000 (150 mph).
    I'm no physics professor, but I attended enough classes to be highly skeptical of the projections or claims of 180, 200, or 208 mph for E and SL class Mercedes.
    Has anyone tried using the Auto Sharp Pen for touching up the stone chips in the front end of your MB? It was advertised in the MBCA STAR this past month and they have a website at www.autovisuals.com
  • linardlinard Member Posts: 59
    Actually, Auto Und Sport (or something like that) magazine did get the SL55 to 208 on special tires. And according to Car and Driver...
    "It seems most European customers (and a small number of Americans) have the restrictor removed. Unrestrained, Mercedes reports the SL55 AMG can run to an intoxicating 208 mph—on the Papenburg proving ground, of course. The problem is tires. No road tires exist for these speeds in a 4400-pound car, so even the "unlimited" SL55 is constrained to 186 mph..."
    Car and Driver took their long-term E320 a few years back to Brabus and tried to break 212 with it but they kept running into a variety of speed limiters on the car, I believe the last one they ran into was around 190. The car had a ground effects kit and they commented that the car never had any problem maintaining 180+ with the aircon on and CD player playing. However, there were significant mods on that car structurally.
    According to either Top Gear or CAR, the current C32 is able to reach 178 unlimited and the previous E320 (with 224 horsepower) was able to reach 147.
    The SL55 was clocked at 208 mph by the magazine mentioned in the above post. It was also shown on Auto, Motor und Sport TV, of which I never miss. No urban legend to it. Likewise the S600 has been clocked at 191 mph unrestricted, also by Mercedes-Benz.
    I didn't say the car would be stable at that speed, I just said that the E55 could probably reach that speed since the SL55 has done it with more weight. Mercedes' have always been able to reach relatively high top speeds with less hp than you might think. The W124 300E could do 137 mph with only 177hp, and that was back in 1986. Anyway it really isn't that serious to get into applying all the calculations and what not, as they don't always give you the correct outcome. My comment about the E55 was just speculation, the SL55 was not as it has been proven.
    M
    Intel recently announced an in-house test where a Pentium 4 ran at speeds making it the equivalent of a Pentium 8.
    "It's the fastest processor in this class" said Flip Slick, in an article in IntelIntel, their monthly marketing magazine.
    Intel performed the test at their California headquarters in a special laboratory housing which included a debris shield.
    A 100 amp power supply, 1 terahertz NIST clock, and liquid hydrogen cooling bath rounded out the set up.
    No-op de Loop, a reporter from the monthly enthusiast testblog, "Toast and Crash", was on hand to witness the event. "Dis vas grate. You coult see the packedge shaking wilolently yust before it wexploded".
    Mr. Slick pointed out that this package was very, very similar to the ones that you could buy at Compusa. "In fact they are so similar, this package uses the same kind of energy as the commercial P4s, electricity" he said tongue-in-cheekly.
  • fshxprtfshxprt Member Posts: 8
    Has anyone driven both the 2003 E 500 and the E 55? If so , how does the E 55 " comfort " setting of the suspension compare to the E 500?
    Is the softest setting on the E55 comparable to any setting on the E 500 ? I have an intermittent bad back and would like to have an E 55 if I can get it to sometimes ride more comfortably that the past model did without the adjustable suspension.
  • topdog047topdog047 Member Posts: 12
    Can anyone rec. a good shop in South Dade. Not looking for the cheapest - There must be somebody better that the dealer-
    Also - Just replaced the orig. contis on my 2000 E-430 with Turanza's - MAJOR improvement - like a new car- price was excellent- $193 incl. bal. and new valves. (Firestone Co. Store !!!)
    My opinion is that the new E55 achieves both better handling and a smoother ride than the previous model. I have a 2002 M5 and thought the previous E55 (neighbor had a 2001 model) was a harsher ride than my M5. The new E55 I drove briefly several weeks ago was noticably improved. I did not try the "comfort" setting, but the standard setting seemed quite good to me.
    I suggest you try to find one you can drive yourself. I also have occassional lower back pain and stiffness. The M5 has never bothered me, but the BMW M5 seats fit me better and offer more support than the Mercedes "multi-contour" or AMG sport seats.
  • johnmanijohnmani Member Posts: 1
    Hi
    I am purchasing a E320 (2002 model) from Boston
    and need to ship to California (San Jose).
    Any recommendations on moving agents will be most
    welcome. Is this a safe thing to do ? Do these
    companies offer any insurance, and if so, should
    I avail of it ?
    thanx
    -john
  • kevinc5kevinc5 Member Posts: 204
    I'm getting intermitent ABS/BAS/ESP warnings. 2000 E320. Any guesstimates what the problem might be? I plan to take it to the shop in a week or so.
  • weldone99weldone99 Member Posts: 26
    All you will need is one sensor that takes care of it all, if you notice you have also lost your cruise control, it's all tied in together. A quick job, not sure what it will cost, mine was under wuarantee.
    Its anyones guess about Kevinc5 problem. I had the same problem just leaving my driveway. The curb would sometimes effect the sensors in just the right way to fool the control. The error would be terminated by stopping and turning off the car. This has not been too much of a problem since it has occurred less than 5 times in the last 49,500 miles.
    If your light continues to appear, take it in and have the system interragated.
    For the rest of this forum with cars approaching the end of their warrantee, let me share my experiences. Since the 49,000 mile mark I have had a window regulator, cd changer, and an oxygen sensor fail. All were replace under warrantee.
    I asked the service manager if this was an indication of higher costs after the warrantee expires. Their most frequent problems are cup-holders that have been victims of sticky spills, rear window regulators that have not been used regularly (they have never replaced the drivers regulator), air-mass sensors, and oxygen sensors.
    All of these repairs are the same cost, if not lower, than domestic repairs. To illustrate how MB prices can be kept down, look at the brakes. The soft pads dust like crazy but protect the rotors. My front brake pad replacement at 42,000 miles was $165.
  • merrelmerrel Member Posts: 45
    OK boys & girls: We are up to 15,000 miles on the new 2003 E320. Brakes replaced twice and still sqeeel at every stop light. People stare and it IS embarrassing!!! Last week the rain sensors decided to furiously swipe back and forth in bright daylight; the headlights would NOT go off in bright daylight (set to auto) and the LED radio display which should show white backround and black lettering in daytime, and dark bardround and white lettering at night, did not work. Got a loaner and car was tied up 3 days. Its fixed, but for how long?
  • mark156mark156 Member Posts: 1,915
    Merrell said, <<<<Got a loaner and car was tied up 3 days. Its fixed, but for how long?>>>>>
     I think you have 7 weeks, 5 days, 18 hours and 5 minutes and your car will totally self-destruct. LOL! Just kidding.
    I really like the style of the 2003 E but my 2000 E430 sport is running perfectly and I just can't imagine trading it until I have problems. Mine will go out of warranty in October. Currently I have 21,500 miles.
    I've had only a few items under warranty that have been done besides the regular maintenance. Both vanity mirrors/sunvisors replaced (both vanity covers broke), an oxygen sensor and a malfunctioning fog light assembly.
    The one thing I like most about my E is that the air conditioner is the coldest and strongest I've had on any car. My 2002 ML500 is almost as good. I have noticed that the brakes on the ML sqeel like your E does. My E is quiet.
    Just my .02 worth, Mark156
    2010 Land Rover LR4, 2013 Honda CR-V, 2009 Bentley GTC, 1990 MB 500SL, 2001 MB S500, 2007 Lincoln TC, 1964 RR Silver Cloud III, 1995 MB E320 Cab., 2015 Prevost Liberty Coach
    I had the oportunity to drive the 211 E320 while my 2000 was in for servicing. There was no noticeable change in handling, noise, passenger room. The trunk is significantly larger. The interior mirror is mounted in the ceiling and feels very close to the drivers face. The dash has nice, flowing lines with a touch of chrome along the wood. I prefer the large gauges of the 210.The seats are comfortable but cannot be lowered as much as the 210. Rear seat leg room is less with no space under the front seats for your feet.
    I got into the 2003 E320 thinking that it would blow me away. I got out of it with a greater appreciation for the 2000 E320.
    As an aside, my Bridgestone Turanza LS-H tires are quieter, better handling, and smoother than the new MXV4 XSE on the 2003.
    Before I jump to the 211 series, I would have to try the new transmission, the air suspension, and an upgrade in engine to the 350 or the new direct-injection technology.
    Don't take this as a MB bashing. I just think that the base E320 is not improved all that much in 211 form.
    Thanks I read with great interest your comparison. How did the steering effort compare between the two?
    The boost and ratio of the power steering seem to be similar. There may be a slight stiffening in the anti-roll calibration--translating into a slightly flatter posture in the turn. The one difference that many people may not notice occurs on rural roads that have a lot of crown. In straight line driving there is a slight boost and feed-back in the steering as the car traverses a change in the crown. It does not cause any change in the line that the car holds, but it was reproducible with every change in the road. I have never had that response with the 210 E320.
    Other than the above observation, the overall character of the steering has not changed with the newly designed rack and power boosting.
  • jparrottjparrott Member Posts: 15
    '98 E-320 with 25,000 miles: I moved the shift lever to reverse and heard something drop inside the console. Now the shift lever is not connected to anything.
    How do I get the console apart to reconnect the linkage?
    Seems like a simple enough repair if I could just get access. Fortunately, this happened in my driveway after doing 4 hours of errands all over the Washington DC metro area!
  • cdbrycdbry Member Posts: 3
    I have read about this problem in earlier posts, but I do not remember if there was a recommended fix for a rubbing noise coming from the steering column.
    This is the 2nd time taking my wife's 02 E320 AWD in for this problem, & the noise has returned after 3 months. (and it's more severe this time)
    Any suggestions on how to make this the last time getting this item repaired?
    Otherwise, the car has performed well.
  • r1_97r1_97 Member Posts: 181
    I had the same problem with a '98 E320. Car wouldn't go into reverse. Dealer had to replace the entire transmission. Luck it was under warranty. I believe that drive trane issues are covered by longer warranty. btw, I got rid on the '98E - still have an '01. Hope nothing similar happens.
  • e2000e2000 Member Posts: 7
    I was also getting intermit ESP/ABS warnings lights and I was able to get around by turning off and on the engine. Now these indicators comes on permanently. I am out of MB warranty and like to know if someone has idea of the repair cost. I am hoping that it is the sensor as some other members experienced.
    Maybe these sensors are all failing at the same time. I just had the SL in for service after all the brake warning lights on the dashboard lit up like a christmas tree. They replaced the left rear wheel ABS sensor. It was done under (an extended) warrantee so I don't know the cost.
    This was the first major failure in 42 K miles and nearly 5 years for this car.
    The ABS/ESP and the Cruise Control are all tied to one sensor. One sensor will fix all three.
  • jctcpajctcpa Member Posts: 1
    should "punt"? Love the look of the car, but reading about the repair problems is really scary. Anyone out there had good luck with a 2003 E320?????????
  • laurasdadalaurasdada Member Posts: 5,362
    My previous trip I met a guy who had just bought an '03 E320. So, I see him again this trip, ask about the E. He said he loves it, the dealer and MB are treating him really well since he's been having so much trouble with the electronics/computer. Nice loaners...
    I too am considering an '04, but so far I'm not getting any warm and fuzzy feelings from this site...
  • retnavretnav Member Posts: 25
    For posts 5136 and 5137; I bought a new 2003 E-320 in January 2003. So far I have had no problems through snow and humid heat, but in all fairness I only have 3150 miles on this car, but almost all in stop and go traffic. On my wife's Subaru they recommended turning the key one notch and allowing the computer acouple of seconds to warm up before actually starting the ignition. I have done that with the MB and the few times that I have had a malfunction warning were when I failed to do that. Each time then I turned the engine off and restarted and no malfunction light appeared.
               In all other respects this E-320 is a great car so far. I,too, had reservations reading this board beforehand, but went ahead and so far have had good luck. For what it is worth in 2002 The Subaru boards were very concerning, but I finally went ahead there also and bought my wife a new Outback. So far that car has been outstanding.
                I read these boards carefully for heads up info and quiz service advisors about them. About all you can say is cars are cars and problems do develop. My previous Acura 3.5 was a great car, but it had rattles in the sunroof the dealer never could stop and they worked hard several times to fix it. Best of luck, I think the MB 320 is a good car.
  • jawdocjawdoc Member Posts: 6
    Counting the days to dump this car (lease up next Feb). It is a wonderful car to drive with plenty of cargo space, but...
    new tranny at 45k (3 visits to get in right
    new pulley and oil pan at 55k (3 visits)
    abs/esp/yadayadayada light show on and off for
          first two years (2 visits)
    clunky tranny always
    new dash lights twice
    esp activation on gentle ramp exiting
    2 radio
    etc
    "Other than that, Mrs. Lincoln, how'd you like the play?"
    Am occ. considering a new E500 or S500 but can't seem to overcome the concerns about more electrical/tranny problems and general unreliability (and am tired of Dodge neon loaners). Anyone else have similar concerns RE: 2004 models (4matic) coming in fall? With warranty and maintenance covered for 4yrs/50k, my dealer is overloaded with cars in for service-I just doubt MB reliability.
    Maybe a Cayenne TT??
