Outside Rear View Mirror Housing Turns Chalky/Dull (Color/Clear Coat Mirror)
1998-2000 Buick Century, Park Avenue, Regal
1998-2000 Chevrolet Cavalier, Lumina, Malibu, Metro, Monte Carlo, Prizm, Tracker, Venture
2000 Chevrolet Impala
1998-2000 Oldsmobile Intrigue, Silhouette
1999-2000 Oldsmobile Alero
1998-2000 Pontiac Bonneville, Grand Am, Sunfire, Trans Sport
1998-2000 Chevrolet and GMC C/K, S/T Models and M/L Van
1998-2000 Oldsmobile Bravada
Condition
Some customers may comment that the black plastic housing around the outside rear view mirror turns chalky or is dull in color.
Correction
Caution
Sanding dust, solvents and paint are potential health hazards. Make sure to wear an approved mask or fresh air supplied respirator that is appropriate to the task being performed.
Refinish both mirrors (Black WA 8555 with a gloss of 30%) following the GM Approved Refinish Materials Booklet GM4901M-D-2000 (GM4901M-D-F-2000 (French)) under the flexible substrates section. Refer to your paint manufacturer for specific process and application process for plastics.
Warranty Information
For vehicles repaired under warranty, use:
Labor Operation Description Labor Time
A1240 Mirror, Outside Rear View Color/Clear Coat - Right Side Use published labor operation time
A1241 Mirror, Outside Rear View Color/Clear Coat - Left Side Use published labor operation time
1. Does anyone else have a problem with their cruise control not keeping the engine at stead RPM's? Mine goes up then way down then back up again just to maintain a steady speed. I have motion sickness and it is very noticable to me. Seems only driver can sense the sensation of it.
2. I have a creeking in the front left of the car when turning into parking spaces, etc. Dealer doesn't hear it. It's the type of noise that is hard to give exact location and is not real loud.
Anyone else have these problems, or any suggestions....would be greatly appreciated.
I notice that when I go through automatic car washes my mirrors turn chalky too. I think it's that liquid wax they use. I just buff it off with a towel and some of my own wax. I can't believe your dealer can't find the TSB. My dealer "couldn't find" the TSB about the air dam either until I found it for them either.
As far as the cleaning part, what's to clean? There's nowhere for anything to collect. The spinning rotor is going to fling off anything loose that might adhere to it. It's conceivable that some rust flakes or lining dust might collect inside the hat section of the rear rotor but so what? Doesn't hurt anything.
The parking brake (being a drum brake) has a self-adjusting mechanism that automatically adjusts the shoes when you apply it.
One of my favorite repair shops pulled this on me once but it was on a minivan with drum brakes at the rear. I paid them and told them never again.
As I mentioned in an earlier post, if the caliper pin lube dries out, the caliper might stick and cause uneven pad wear. Maybe this is what they want to do. It's a 10 minute job per side so $40 is pretty salty. Lubing the pins should be part of the pad replacement service and the lube should certainly last as long as the pads.
Later I discovered there is a TSB out on the overdrive clutch burning out and that's what happened to mine (probably before I got it.) The dealer charged GM 18 hours plus parts so I suspect it would have been well over $1000.
When I first got my 02 Intrigue, I did not like the way the tranny was calibrated because I was familiar with the way my wife's 99 shifted. It seemed to hang on to a gear forever before it would shift. I like it now that I have become accustomed to it and can feather the throttle back if I want it to shift earlier. The 3.5 does not make as much low-end torque so the tranny is calibrated to shift at a higher rpm. If you are used to driving something that revs higher (i.e. like a 4 banger), I can see where you would question something that shifts so early.
Early on it bothered me. Now I dig it.
The 02's should be the best so your car will likely be a good one.
2018 VW Passat SE w/tech, 2016 Audi Q5 Premium Plus w/tech, 2006 Acura TL w/nav
In regards to coolant sludge, I think that is normal. I have noticed that on the inflow tube also. I'm sure others here have noticed this as well. Right?
My 2001 has over 20k and so far I don't have any symptoms. Perhaps they addressed it by the time mine was built. For any others out there that have this problem, don't let the dealer feed you crap like "steering shafts don't go bad" or "cannot duplicate problem". If you're feeling it, then it's happening. And since there is a TSB for the problem there shouldn't be a need for debate. If they do give you a hard time, insist on the fix. If they still refuse, call GM and open a complaint. My experience with this has been that they'll try to blow you off with the "can't duplicate problem" excuse.
"General Motors Corp. is adding a third shift at its Chevrolet Impala and Monte Carlo auto
plant in Oshawa, Ont. The facility has been running overtime on two shifts,
but hasn´t been able to meet demand for the midsize Impala. North American
sales for the model jumped more than 20 percent last year to 226,000 units."
I wonder how many potential Intrigue buyers went with an Impala instead because of Olds' impending demise. Intrigue production thru April was less than 8000 units.
25,000 impalas were produced in April.
Impalas sales are up for the model year though.
I think sales for all the wbodies are down, except for the impala.
My dealer has sold all of his intrigues and would like to get more.
Does this sound out of line, they want $425 to replace a fuel injector pressure regulator. I priced the part online at Autozone, $77. I figure dealer price is at least $125, if not $150. And, the thing is on the top of the motor, so it can't be that difficult to replace...Sooo, add the $75 diagnostic fee and we have ($150 +$75= $225) $200 labor for this job...Give me a break...I bet it will take them a half hour tops to install their overpriced part.
Anyway, the reason I am here... Has anyone else had this problem? What did you pay?
It ddidn't help.
The mechanic said that it was "wet in the vacuum line", whatever that means.
This was a warranty repair so i do not know what it cost.
I think what is happening is what I thought would happen. People just view an Intrigue like any other w-body, nothing else.
I'll never understand GM not going further with the Intrigue.
Maybe it's things like the ridiculous interior of the Aurora. That "jet plane" instrument panel really cramped the driver's environment. I thought it just juvenile and absurd. Often,GM really seems to have a "lowest common denominator" perspective.
redline : Resale on any w-body has been less than an Accord for years. Like you say though, when you account for what you paid and the lower finance rate you probably got, the difference isn't all that much.
I added strut tower braces (front bracket had to be customized (pictures in photo gallery have been removed-I guess they were too large)? STBs were an improvement in that it tightened things up and bumps became less harsh.
I then removed the sway bars. This made the suspension more independent and the ride was softer but it caused understeer (which I like).
I then got Yokohama Avid Touring tires and this made ride very smooth and quiet. I could have stopped here because ride was right where I wanted it but curiosity got the best of me.
I then got Monroe Sensatracs (Monroe said they will provide a softer ride then Reflex) and everyone else said the Monroes would be less stiff than KYB, Koni, etc. The Sensatracs made the ride firm again (to my surprise) but not bad.
I kept my Delphi struts in the garage. The other day I was examining them and noticed a swishing noise when moving them around. So when I took my car in for the strut bearing issue I popped the trunk and had them look at the Delphis to see if they were defective. It turns out they are (leaking, little resistance, etc).
So, there I stood facing another opportunity to experiment. They said they would replace them all under warranty. I said, if you can put in the AC-Delco Road Response Silver #503-322s and 323s I'll do it. They said parts will take about 3 days to arrive. So next week I'll have another report on struts.
Based on what I've read, monotube struts will have a softer ride. The Delphis and Sensatracs are twin tube, while the Road Response are mono.
AC-Delco says the Road Response Silvers are softer than the Reacteks.
Since the Road Responses can also go on Regal and other cars, and based on other deductive reasoning, I'm assuming the ride will be comfortable.
To be continued...
Are your's still off?
jg28- did you ever get the #s on your springs?
I'm curious to know if all Intrigues have the same springs or are there variations by year, trim, engine, etc?
Will someone post there spring #s for comparison? They are on a tag near the top of the spring.
Front: FJT
Rear: TKS (the middle letter might have been an N, difficult to see and my bifocals didn't help!)
“In the Intrigue's first comparison test at C/D (August 1997) against the Ford Taurus and Toyota Camry, the Intrigue spanked the Taurus and squeaked past the Camry to win top honors. We liked the Intrigue's classy looks, its seamless, strong powertrain, its taut body motions, and its high value. This was news. The Intrigue turned out to be exceptional. Its one unscheduled [service] stop beats the average, and even our long-term Accord two-door required a stop that wasn't in the owner's manual. A few more performances like this one and we'll be ready to acknowledge that the General has equaled the Japanese in fit, finish, and quality.” (Car & Driver June 1999)
Styling-wise, it's a cut above that cookie-cutter blandness you get with some of the big-hitter imports. I think the Intrigue has a lot more personality than competitors such as the Toyota Camry or the Honda Accor, and overall performance than with the old pushrod 3.8-liter V6. Excerpt from The Detroit News footnoted in July 26, 1999 article in Autoweek entitled, “Oldsmobile Intrigue the truth is out there”)
THE INTRIGUE HAS ITS PRIORITIES together. All the pieces that make it go are top quality, and the driving experience is the key to this sedan. ... there's no quibbling about the way this car drives. It's the first mainstream sedan from General Motors that is plainly better than its competition from Japan. (Excerpt from Automobile Magazine footnoted in July 26, 1999 article in Autoweek entitled, “Oldsmobile Intrigue the truth is out there”)
oldsman : I agree with you on the Accord. Even a dressed up V6 isn't all that exciting and the base 4 bangers are brutal. That said, I can't take anything away from the quality and finish. That long running reputation is the reason the car is a best seller.
oscarz, I didn't get the spring numbers cause I don't wanna crawl under and look.
