Oldsmobile Aurora
12425272930112
  • andyl2andyl2 Member Posts: 84
    Email me at AndrewLobsenz@TX.SLR.COM
  • zinc1zinc1 Member Posts: 133
    Replaced the plastic panel under the radiator this morning (GM p/n 25614711, $23.00) but it didn't come with the air dam (or scoop) that you can see protruding underneath. The drawings on the Olds dealer's computer didn't even have that piece(?) If anyone's replaced theirs and kept the receipt, I'd be interested if the p/n was on it.
    If you're getting the error 32 on the CD, it won't last long. I couldn't find anyone to repair, or even replace the CD unit. Had to go an extra 20 miles to an Olds dealer who dealt with a local shop who sold 'reconditioned' assemblies (CD, tape, radio, and panel) for $320. Otherwise, you pay $750 for a new, complete assembly.
    A great site for BRIX Aurora pics here.
    Henry, you have something against us elements?
  • tommyboisxty9tommyboisxty9 Member Posts: 8
    Hi--I'm currently in the market for a used car --
    I'm looking at the 2001 Olds Aurora 3.5L
    and the 99 Acura 3.2TL
    I've done all my research on the TL and was almost 100% sure of getting that but now I've seen a few Auroras and I love the interior -- I drove a 98 a while back and remembered it felt solid. I am, however, worried because Consumer Reports gives teh 95-99 Aurora's a "Spotty" reliability record & teh TL Exceptional -- I have a TBird now taht has been nthing but a pain -- rattles, tranny probs, etc. etc.
    My next car *HAS TO* last me thru college (about 7 years --- 120K miles probly)
    So NE how -- how have ur 2001's held up so far?
    Likes dislikes?
    Are there any body kits/GFEX avail?? I know theres a kit for the 95-99's.... I haven't been able to find one for the 01 + models though. Also is there a forum like www.acura-tl.com, http://forums.maxima.org, etc. like a big web based Olds/Aurora Site??
  • garnesgarnes Member Posts: 950
    Tommy - Edmunds here seems to rate the Aurora pretty high for reliability - the 4.0's at least. I believe the 4.0 has more of a track record and possibily a better record than the 3.5.
    Yeah, you're college all right - I remember goofy login names like that from some. Did you get that from MTV or make it up yourself?
    As much as I'm biased in favor of the Aurora and a lot of domestic cars, I'm sure you can't go wrong with an Acura for reliability, but you are right - the Aurora interior is the best looking ride from behind the wheel. It's killer. And if you get the Bose stereo, you will flunk because you won't leave the car.
    Don't college kids bum rides off the ride board anymore? Or has the wealth of the 90's made it possible for college kids to get nice new cars?? I must have missed the boat somewhere. I'm 35, an engineer and doing fine and I just got my first nice car - a 98 Aurora this spring. But yeah, I am a cheap-[non-permissible content removed]. I milked a 91 plymouth sundance for 131,000, and an 86 sunbird for 161,000. I must have worn 10 years off my behind on that crummy sunbird seat! Why??
    Zinc1 - Wow, thanks for the great pictures. I've printed 2 and saved them.
    I finished my air box mod as descibed in other posts. It's better. It's quiet too unless you stomp on it. Then you get a nice low growl as the air rips through the box freely. It's got to add at least 10 HP with the K&N filter. I did not cut the metal hole bigger. Not going there. I've more than doubled (maybe 3X) the air intake area into the lower box and most of it is straight up into the filter too - that's good enough. I used a "dremmel" tool with a nice cutting blade to cut the plastic on the lower box and cut the buttons that hold the upper box inner liner. Where goggles! I'll watch for how this handles wet pavement - I hope no water gets up there. I don't see how it can right now though. I got a new "spare box" now too - just in case.
    I'll bet at least one was a fire-breathing Aurora. Kent has 2 Auroras on his "favorites" page, a fire breathing GTS-1 and a WSC (World Sports Car) Aurora front shot - funny how they never take shots from the back. I recently colorized a GTS-1 scan here.
    Okay, how much was the extra box? Do you have the part number? The Wheel to Wheel endorsement pushed me over the edge.
    And, hey, I discovered that my '96 isn't so old. Here's a website that's still introducing the 1996 Aurora - on a site that was last updated in 1995, whoa.
    And here's another '96 website describing the Le Mans Aurora debut - the Internet is getting old enough to be nostalgic about websites now.
    Zinc1 - thanks for the Le Mans thing.
    Just call any GM dealer and tell them you need the air intake box. They will look up the part number and order it. With 5% tax, it was $140. I got mine from a Chevy dealer. When you're done messing with the existing air box, it is obvious that you need a "spare" in order to go back to stock if needed.
    BE careful removing the inner liner from the top portion. The portion in the outlet port hangs up a little and you end up pulling on it, and it is easy (I did) to break the little plastic guard around the temp sensor. The sensor was not hurt though and all seems OK. I'd maybe cut the inner liner from the port a little as well so it all slips out easier after you remove the bottons that hold it in. This will make sense if you take it apart and start looking at it.
    The "plastic thing" that drops in a hole in the bottom air box piece has to be pulled a bit to get it out. It is surprisingly easy to get back in though. I put everything back stock just to make sure I could and I was not stuck. Then I went back to the modified deal.
    Cut the plastic hole in the bottom piece to take advantage of the existing hole in the metal under the air box. File down the rough edges. Just wear goggles the whole time!
    If you do this, be sure to remove the filter and check the inside of the air box for crap after driving in the rain - highway and everything to make sure nothing gets in. I have no experience with this yet in wet conditions.
    Oh yeah, after modifying both pieces, make sure to blow out any crumbs of plastic or debris - don't want that in the engine.
    When you get it done, you will realize how "bottled up" the engine is to keep noise down at any throttle.
    Hey tommy boy - check out an Impala too. I have one of these too and love it. Get the 3.8 V6 - it has been a winner for a long time. It's all cast iron (none of this cast iron block with an aluminum head stuff that blows head gaskets.) Give me iron on iron, or aluminum on aluminum.
    It's very roomy, actually has a good looking interior, is really comfortable, quick, high safety rating, rides like a smooth quiet luxery car with some sportiness too, and costs way less. The new 2002's don't have the funny looking tail plastic either on many of the colors. It's definitely a "road trip" car. Be open minded and check out a Chevy -really. It's not as snazzy as an Aurora, but it is great.
  • blk97aurorablk97aurora Member Posts: 573
    Henri,
    Sorry to be confusing. I will post something more coherent when I understand my topic better. No periodic tables will be required.
    fjk57702,
    Thanks for supplying info about your '98's speed at 2000 rpm. My '97 also shows the same 66 mph at 2000 rpm with stock size tires (235/60-16). Both have the 3.48 transaxle.
    Can any of you autobahn (3.71 trans) owners check your car's highway speed at 2000 rpm with trans in overdrive and torque converter locked? This is harder to determine than I originally thought; need to be slowing down slightly or on a down-hill grade, otherwise there will be slippage in the torque converter that will give you an inaccurate, lower speed.
    garnes,
    Great work! I have a few things to report also. Sunday I removed the horizontal panel below and just behind the front bumper, thinking that opening the area under the fender would supply cooler air to the airbox. Surprise!! If you recall my temperature sensor in the airbox, I observed temperatures 2 to 3 degrees F higher than my dash indicator when the car is up to speed. With the panel removed it is consistently 14 to 16 degrees higher. Somehow hot air from the radiator or engine has found a path to the airbox. So the panel will go back on. I think your good work on opening up the airbox needs to be complemented with a scoop or some other means to bring in cooler air.
    Jetchips has what they call a power control unit (PCU) for our cars -- $260 msrp; claim 10 to 12 hp increase. Zinc1 reported this several messages back -- part number 68003. From everything I have been able to find, it is a reputable company. Does anyone have direct experience? Hypertech does not have a programmer for Auroras.
    Yesterday I tried two more 0-to-60 runs -- a 7.85 and a 7.37! This last one is the only run of the 10 or so I have made that felt good coming off the line. I staged with brakes on and engine at 1500 rpm; traction control on. When I hit the gas, I got a small chirp from the front tires before traction control kicked in. I will make some runs with traction control off after I feel I have a good understanding of performance with it on.
  • matrixfrogmatrixfrog Member Posts: 180
    garnes and blk97aurora - great to see some people trying to make there aurora faster. I read from a couple of posts that your testing out some air intake designs. Im wondering if you took off the black plastic thing on the air intake and covered the hole with something? Seems like that would be restricting some air flow. I'm also wondering how important the sensor is connected the air filter box because I know of some people that made a home-made cone air intake. Wouldn't be too hard to make one for the aurora and if it had an easy installation then you could just use it on the dry sunny days. Then again I could just go out and buy one. Pretty expensive though.
    I want to get a new exhuast system. I don't want something extremely loud, just something that will increase the HP and sound a little deeper and throaty. Any suggestions? Prices would help too.
    I've been saving up a little money and in the next 3 months I hope to get an air intake, exhaust, and a PCU. If after those 3 things I can beat the kid who drives the grand prix GTP in my town, you'll see me driving around with a big smile on my face.
    BTW on the Borla Stealth Aurora it says that he reprogrammed his electronic tranny. Anyone know how much of a HP increase this could give and how much it would cost?
  • fjk57702fjk57702 Member Posts: 539
    Reprogramming the transmission will not increase the horsepower. The horsepower peaks at some engine speed (5600 RPM's on stock Aurora's) and changing the transmission shift pattern does not make any difference. However, if you change your engine, then the transmission should be upgraded to optimize the new power available.
    I have checked goodyear, and 235/55-17 tires are a 0.1 inch bigger diameter (27.1 vs 27) than the 235/60-16. The 17's are standard on the 01 models. One can do the speed in third gear too, but the torque converter needs to lock up, so the highway is the best place. In third gear my car runs at 3000 RPM's at 66 mph. Overdrive is .68 to one.
    Thanks for the info fjk57702 but it leads me to another question. You say reprogramming the tranny would not be neccasary unless changing the engine. What if I had a new PCU installed along with intake and exhaust. Would I need to reprogram then? Or is reprogramming only needed in the case of super/turbo charging and NOS?(Borla Stealth Aurora has NOS)
    Also wondering if anyone has put any tires on there Aurora that are a little less wider?
    BTW what is that black odd shaped box on the intake for? To quiet down the intake?
    OK, some rain this morning and I got it out. I checked the air box and I saw one drop of water in there and the paper filter (I put the paper back in to detect moisture better) was very very slightly damp in one spot. This is not encouraging, but I saw almost no wetness down under the air box through the hole. Maybe the water came in through the stock side inlet and its normal. Air does come inside the fender through the front, and I would expect water to come in. Maybe this is normal. I saw no moisture on the upper box or the intake hose.
    Bottom line - I am going to have to experiment with my backup "stock" airbox arrangement to see what happens for comparison. No matter what though, I will forever lose that inner lining from the upper box piece. I wonder if this is not worse than the lower box arrangement. That has to add a little boost by itself.
    matrixfrog - see my post 1384. Wheel to Wheel (they make the GM pace cars) told me they use Corsa. They said that they are not loud under normal around town driving. Corsa said they don't have a Cat-back for the Aurora now, but can/will do it - eventually. They said they will look at one to see what is needed. Maybe their Caddy STS system only needs slight modifications. In stainless steel, it would be about $1,000. Pricy. But it should give you a 270 HP Aurora by itself. Call them at 800-486-0999 and ask for Jim Browning Jr. Show some interest.
    Matrixfrog - I removed the plastic thing and left the hole open for more air flow.
    Blk97aurora - thanks again for the cool time stuff and your experiments with the air. Wheel to Wheel said they made a little "scoop" that goes inside the fender to push more air through the stock opening (for their project Caddy). They are checking to see if they have/can make one for me.
    I wonder why the times listed on edmunds are so much slower (8.1 is the best listed for 97). Speaking of which, did you see the review for the new Q45 here at Edmunds? Infiniti claims 5.9 but the BEST Edmunds could produce was 6.7. Big difference. They ask "where did all the HP go?" It's rated at 340 HP. As Elmer Fudd often said "there's something awful scwewy going on awound here". I kind of wonder about the entire 0 to 60 game. It is so competitive that I wonder if the rewards of a little false advertising aren't too tempting. The 200 HP ford taurus is "claimed" to do it in 8.0. I've driven one - no way. The wife's Impala 3.8 is listed at 8.2 - the same as the Aurora. Now I have an autobahn, but still, these two cars are just not even close. I'm going by feel of course, but my Aurora would eat the Chevy. I'm sure of it. I'm sticking with Elmer's assesment right now.
    If you redo your engine so peak horsepower is at 6500 RPM's instead of the stock 5600, then reprogramming the transmission would make sense. Or if you supercharge it and perhaps the peak horsepower is at 5000, then reprogramming make sense. I am not really an expert on this but I think that the transmission is programmed to shift based on the peak torque/horsepower points to give best performance.
  • HenryHenry Member Posts: 1,106
    Explanation - The editor drives a GS400 (a.k.a. "the Nemises").
    Still no Aurora. I think a total of 12 minivans have dusted me off to date, but I stopped counting.
    Henry - dusted by a minivan?? Huh? What?
    Wow, with the totally stock air box and the paper filter back in - I swear there is a noticable difference. The "opened up" box (top and bottom)with the K&N is just more responsive.
    Yes, I think that "plastic thing" in the bottom of the air box is to reduce intake noise. It's funny how the ports are different lengths - as if to cancel or produce some sort of resonance.
    Blk97 - I gave it a small try at 2000 rpm. It's tricky. I think I'm doing about 62 or 63 at 2000. It is tough to do, but I did try to follow your instructions. I'll give you more info in the future. I bought the 98 with only 13,000 on it and it has the MXV4's (very little wear), so I assume it is an autobahn.
    If I have to scrap the bottom opening idea, I'll just use the bottom part of the "plastic thing" in the hole, but open up the side really big where the air currently enters. If I get dampness on the filter with the stock set-up as much as the modified set-up then I'm staying with the modified of course.
    The jet chip thing involves wiring - according to them. I'm not to sure that sounds so great.
    Want an old Aurora brochure?? I got them from PJ's auto literature. 319-345-6760.
    If you put the transmission in normal mode instead of power mode, it will tend to stay locked better. With the autobahn your speed in overdrive should be around 62 or so at 2000 RPM's.
  • gisomgisom Member Posts: 144
    comes on after dropping off the expressway and into regular street traffic. Any suggestions?
    fjk - thank you. I'm not sure where I had it. I'll be trying some more. Hope it helps you guy figure stuff out.
    gisom - just bring it in. The dealer will hook up the diagnostics to it and the car's computer will tell you what is happening. They seem to go off on many cars for all sorts of reasons. If the car seems to run fine with the light coming on, I'd bet it is nothing big.
    Henry - maybe I'm clueless, but what does the "ATS" mean for the Aurora??
  • aurorabillaurorabill Member Posts: 22
    Thanks to the person who mentioned that performance button on the close side of the shifter. I must confess that although I have used it, I never understood it until now. Since someone else may be as naive as me, let me tell my story.
    When you are going 50-70 mph and do not have this button pressed in, you will sometimes experience a lack of responsiveness when trying to accelerate quickly. That's what that button is for. By pressing it in the RPMs go up into the low 3's where your torque seems to kick in.
    In the last few days I now have the hang of it and am experiencing a new level of enjoyment.
    My right headlight is showing moisture again. It was just changed 3 weeks ago. The mechanic looked at it this morning and pulled a newer designed one out of a box. Another Aurora owner is on vacation for 5 weeks, so he's giving me his!
    You can see rubber gaskets coming out of some of the rear holes and the tube routing is different. I'm getting it changed Tuesday.
    This condensation is a problem that has plagued many brands, Japanese and American and who knows who else.
    Aurorabill (95)
  • wingnut396wingnut396 Member Posts: 50
    Hi guys,
    Been travelling a lot for work lately, and have not had time to catch up on the boards.
    As Henry would understand, there is nothing like driving your aRoaRa. After over a month in and out of rentals, I always was looking forward to my Olds.
    I drove several Tauruses and Sables. What a plain car and talk out no power. Those cars just had absolutely no character. Blah, Blah, Blah. And the seat, what a pain in the rear! No joke. I drove about 5 hours strait in the sable, and could not get comforable.
    Got a Expedition one time, and what a hulk. Henry complained about parking the Aurora, this thing sucked. It was slow, ponderous, and just a pain in the [non-permissible content removed].
    In Knoxville, I got a Subaru Outback. That car had character and handles great, but just didn't have the oomph to handle the hills while passing. It did save my butt though when I hung a rear tire off of a mountain road near Gatlingburg while executing a 3-point turn. The all wheel drive just sucked me back up off the sub-frame! Great AUTOMATIC tranny for engine braking as well. A bi-turbo or something and this car would be superb.
    Anyway, each time I looked forward to driving a different car, and was dissapointed every time. I missed by tons of white lightning.
    All the performance stuff is great. If I only had the time and money......
    Its time to buy a warranty for the car soon, guess I know who I won't be dealing with. From other boards, it looks like 1st source will be the best. They do their own admin and that seems to be the bulk of Henri's problem. I like the fact they have rep that admins their own board here on Edmunds. That says something about a commitment to customer server.
    Well enjoy your Aurora (real or virtual) and keep the excellent postings up!
  • redskin024redskin024 Member Posts: 110
    SEVILLE STS=SEVILLE TOURING SEDAN
    AURORA ATS=AURORA TOURING SEDAN
    I belive Henry made up his own version, because ive never heard Olds call it the ATS.
    ATS is aROARa Touring Sedan. But the 17% you are missing is the reason I call my car this. I put the Seville STS performance chip in the car and the ATS is my way of recognizing the TRANSFORMATION!
    Gison - if you have a 95 I know exactly what is causing this. It is the reason my car has stayed in the shop for so long. I only point to 1995's because the two folks that had this happen both had 1995's.
    The error codes you get should say EGR valluve problem and the torque lock-up problem. If it is just the EGR valve consider yourself lucky.
    If it is the torque converter, I hope you have a good warranty in place. Otherwise, you may be added your own verses to the Chi-Lites "Have You Seen Her."
    If is turns out to be the the troque converter, I hope you are near me in New Jersey, cause I would just tell you to go to Norman Gale Olds in Ceder Knolls, New Jersey.
    The torque converter code will eventually require a complete overhaul of your transmision. If this is the problem, sell the car NOW!
    If you choose to keep her, in about 2 to 3 years . . . . .
    Have you seen her . . .
    Tell me have you seen her?
    I believe the part you are looking for is 25677742, group 7.833, called "deflector, f/end fascia" for 95-99. The panel you replaced (25614711, deflector, rad air lwr) is shown in three places in my parts microfiche. Two of those do not show 25677742, the other one does.
    blk97aurora - Now that is some good info. I'll check on it right away (funny, I bought the microfiche too, but can only view it at work, but I'm too busy at work to get a look at it). Anyway, I'll let you know how it turns out. BTW, the panel I changed made a 10-15 degree difference on the freeway.
    Aurora Tip #143: While waiting for the AC to cool the car on a hot day (105 here today), open the center console and place your right arm over the coolest vent in the car. When wearing a short-sleeved shirt, the air will go right up your back. Caution: Don't attempt this with people you like in the back seat.
    Wingnut - Did you use the spell checker by any chance?
    ahh, very nice. A little ditty to the Transformers(the cartoon/action figures) song would fit your car nicely. I dont remember quite how it goes or id do it myself. Heres a different one to the tune of My Little GTO:
    My little 4 point 0,
    shes really looking fine
    Oh my little 4 point 0,
    she really blows my mind...
    and sat in the aurora they left open and of course loved it...but I'm confused -- those nice driving/fog light looking things on the the 2001's down on the bottom of the bumper/air dam?? ARE THEY fog/driving lights??? I couldnt get them to turn on if they were....
    ALSO -- what's with the 18 different positions and two switches for headlights on the lever?? can someone explain
    How do you measure the difference in temperature? Your numbers are consistent with my observations with the panel removed. I'm using a Radio Shack indoor-outdoor thermometer with the remote sensor positioned in the intake air stream on the clean side of the filter element. Do you have a way to access the OBDII data? The only thing I liked about my '86 Toronado was being able to access its On-Board Diagnostics data from controls on the HVAC controller. I was disappointed to find that I cannot access the same data on my Aurora.
    I found the center console vent also. Very useful.
    matrixfrog and garnes,
    That black plastic thing in the air intake is a silencer, I think. The parts microfiche does not show it as an individual component -- it is part of the duct going from the air box to the mass airflow sensor and throttle body. I replaced mine with a plug I made from PVC pipe parts.
    I'd be concerned about removing it and leaving the hole open as it is on the clean side of the air filter element.
    Whatever happened to those Aurora pictures that people were going to post? I thought the aROARa crew was going to be posting pictures of themselves with the car.
    Zinc1 did you get any photos showing the owner with that "proud pappa smile"?
  • hardestyhardesty Member Posts: 166
    There are two rotating rings on the stalk. The outer one is for headlamps. I leave this one in AUTO 99% of the time. Only turn it to on when headlights on is required during daytime. Only use PARK or OFF at night. The auto feature works very well. The inner ring switch is for the fog lamps. Three positions, OFF, FRONT, and FRONT and REAR. The front fog lamps will only come on if the parking or low beam headlamps are on. The rear fog lamps (VERY bright red) will only come on if the front fogs are on and the ignition is on. Push the stalk forward to activate the photon torpedoes (high beams that push things off the road ahead of the car). Pull the stalk back (momentary) to flash the high beams. Oh, yeah, the lever also does that old turn signal thing. Don't worry about being one of those people driving while constantly turning left, the Aurora will ask you (via the DIC) if you mean to keep your turn signal on forever.
    Blk97 - No, I'm talking about the plastic thing that drops in the hole in the bottom of the air box. I think that is for noise too. I removed that for more air flow from below. (I got a little moisture in the rain so I'm back to a totally stock set-up to see if I still get moisture - trying to see where it comes from and what's normal)
    I left the funny thing that's on the intake tube (clean air side) in place. Yeah, it's probably for sound too, but I don't see how it hurts leaving it on. It really doesn't block air flow.
    Check out the Lincoln LS board. There are some guys that have been messing with the air box too as well as cat-back systems and then dyno testing. Brian (who did the dynos) didn't seem to have experienced the gains from a K&N that K&N claims (2 to 4%). With the air box opened up and the filter, he thinks the gain would be 5 HP. Of course it all depends on how bad the stock box is (which he noted). Trouble is, I don't have a Lincoln LS air box to compare to the Aurora. The Lincoln and the Aurora are rated about the same for HP, so I think the comparisons are helpful.
    I need to find a place to dyno test.
  • dishwishdishwish Member Posts: 11
    How do you tell if you have the autobahn package in your Aurora? Can you identify it by the VIN? Please let me know.
    Just stopped by my local dealer. Both of our 2002 Oldsmobiles are scheduled for build the week of 27AUG-31AUG. The Aurora out of Lake Orion, MI and the Silhouette out of Doraville, GA. We live in northern CA so it will be a build and ship race to see which arrives first. They might come in on the same truck.
    There is an error in the Chrome configurator that most sites (Edmunds, KBB, GMBuyPower, Yahoo!) use on the 2002 Aurora. For 2002 there are 3 radio options. Base, Bose, and Navigation are seperate exclusive options. Navigation can not be had with the Bose system. That makes my new 4.0L $430 cheaper, and my hearing will probably last longer, but I really wanted it all. I chose the new toy (nav radio) over the big sound. 2002 cars all come with the LATCH system for child seats which is good for us as we have three boys, one age 6 and two age 3.
    blk97aurora - No, I haven't accessed the OBDII data - a friend of mine has the obscenely expensive diag scanner - but I hear Autotap.com sells one for $290. I'm going only by the stock meter-movement gauge for the temps. The deflector itself, when installed, holds a front plastic strip in a position that seems to do the most to direct air to the radiator - w/o deflector/90+ degree weather/75mph/AC on = 230° or more; w/deflector/same conditions = 220° or less.
    Henry - I haven't pushed the Aurora owner pics, it's hard enough to get people to snap their cars 8^) But I'll do a me-and-mine soon (btw, I put a pic of the Aurora on my profile here at Edmunds).
    dishwish - Give the Parts Dept at a GM dealer the last 7 (or 8?) digits of your VIN, and ask them if you have option QQX (Autobahn).
    garnes,
    I saw a Riviera today and got to wondering what it's intake tract looks like. Since the Riv and Aurora are built on the same platform, I'm thinking what comes on one may fit the other. And the Buick engineers may have designed a better-flowing intake for their supercharged engine.
    Yes I do have a 95 and it sounds like it could very well be the torque convertor. The service light goes out when the car changes a gear but if I don't make it change gear and keep the light on, it makes a loud noise when I try to put it in reverse or drive from a dead stop. It sounds like the trans slams. I do not have any warranty on my classic but I just can't see how I can get rid of her unless I get an '02'. I live in the Chi-town area, so we are about 1500 miles apart.
    Blk97 - now that's a great idea and way to go for think outside the box. Oh that was bad. If I see one in a used car lot or something, I'll check it out. The Lincoln LS guys are talking about the new 2002's having 10 more HP from a redesigned air intake. I'm seriously going to call around about some dyno tests. I'm going to keep calling around about a cat-back system too. The LS guys really seem to love their Borla systems. They say it is not to loud for regular driving and sounds sweet when you hit it. Maybe they have something for the Aurora. I'll pester the Corsa guys again too.
    We got a lot of rain today so I tried out the stock air box system - and the paper filter got a little damp (where it normally gets dirty) so I guess this is normal. I drove it hard with some full throttle stuff to try and pull a lot of air and get the worst case scenario. I drove on the highway too and got some spray off other cars. I then switched to my modified box and it really started raining buckets. I put in a new dry paper filter too. I ran it the same way as before around the same approximate route. The paper filter was a little damp as well. About the same - even though the sky was falling for that test. So, It seems this mod is not too bad for now and so I'll stick with it and put the K&N back in. However, I'm keeping the stock air box set-up in the trunk with a paper filter and a screw driver and a 10mm socket just in case. I'll keep monitoring things. I wonder how the sloppy snowy roads will do.
    Dishwish - If the car has the original tires and they are the Michilin MXV4's, that's a good indication you have the 3.71 transaxle. Also, like some of the guys here have pointed out, if the car is at 2000 rpm, going somewhat downhill (no acceleration) you should be doing about 62 mph. The regular 3.48 transaxle will have you doing 66 - according to others here on the board. The math works out too I guess 3.48/3.71 X 66 = 62+/-. It's tricky to get the car "locked up right" to test this.
    I did some more checking on this and yeah, I'm doing about 62 @ 2000. It's difficult to do. I think blk97 described how it works best on post number 1400.
  • scottc8scottc8 Member Posts: 617
    We just got the word from Lincoln that the improved '02 airbox will be retrofit-able to our older LSs, so I think a lot of us will be holding off on DIY modifications and wait for the factory parts to become available. I appreciate your report on the water-ingestion experiment.
    I owned a black 95 supercharged Riviera. As I recall the airfilter box was very similar to the Aurora's, but did not have the protusion off to the side. My supercharger ate the gasket that sealed it to the intake manifold. Had them puzzled for a couple of days after they tried replacing other parts. The factory knew what was wrong though. That car would burn rubber with the traction control on. Starting up on icy roads was impossible without the traction control chirping away.
    I nevr do a speells chek. What iz teh ponit?
    (Did I horribly screw up a word or something, or just my typical bad grammer?)
    "That says something about a commitment to customer server."
    I just thought this line looked like one of the spell-checker substitutions. It looks like the spell-check prog was updated though, doesn't do that anymore :)
    Your post said a lot about what's available out there. I remember test driving quite a few cars after trying the Aurora, they didn't compare either. Haven't had to rent for a while, though. Once rented a Vauxhall in England, but I was so intent on staying on the wrong side of the road that I hardly remember the car itself :P The last rental was something in Maui, I can't even remember what it was now, but I drove the entire north shore road (don't ever try it) and when I got to the hotel I read the rental agreement, which stated that they wouldn't cover any claims on that particular road.
  • jimseyshellesjimseyshelles Member Posts: 1
    Hi everyone, just bought a 99 aurora and love it, best car I've ever owned. It onley came with one keyless entry, have a second one but don't know how to program it, does anyone the procedure?
    LOL, "customer server".....
    Just proves that I spend too much time around those things:P
    Guess I should start reading rental agreements as well.
    jimseyshelles - Welcome. I had to have my remote programmed by the dealer, it was free with the $65 purchase of the remote. However, I bought another one for $19 (not from the dealer) and the dealer said they charge $60 to program them. It would have cost less to buy both at once the first time.
    wingnut - I don't usually read the rental agreements because there's nothing important in them. Don't know why I read that one, but I guess it's a good idea to check them out. That *road* was tricky: it gradually went from a two lane, asphalt road to a less-than-single lane dirt road, and there was no place to turn around, being on the side of a hill. I didn't want to risk driving in reverse all the way back either, so, 10 miles later, at 5mph, I find the other end. One of those unforgettable experiences.
    An Aurora convertible.
    dishwish,
    There is yet another way to determine if your Aurora has the autobahn package. Every GM car has a service parts indentification (SPI) label. Our 1997-1999 Auroras have one glued to the bottom of the spare tire cover -- a dumb place IMHO for something containing information very specific to each unique car including its VIN. I believe the 1995 and 1996 Auroras had their SPIs in some other location, but I do not remeber where.
    This label lists all applicable regular production option (RPO) codes; QQX is the one for autobahn. You will see dozens more. These include sales "options" from the window sticker point of view, but the complete listing is more like a high-level bill of materials for manufacturing the car.
    Thanks to all who responded to my request about road speed at 2000 RPM in overdrive. Without exception, responses have been 66 MPH for standard transaxle ratio (3.48) and 62 MPH for the autobahn (3.71). The math (3.48 vs 3.71) works out the same, too.
  • shucknetshucknet Member Posts: 98
    You guys are missing the easiest way to identify an autobahn Aurora. Look at the tire sticker on the driver door. If it calls for V rated tires you have an Autobahn Aurora.
