Two years and 21,500 miles later and I'm still in love with it.
I havent gone back to investigate but am wondering if this has happened to anyone else and if so, What might it be?? just bought the car a month ago and has 145k miles. any clues? thanks
No idea why the car wouldn't shut off...
door chime goes off without the key being in ignition. previously the key had to be in the ignition for the warning chime to go off.
interior dash lights are out. the warning light indicators and temp and radio light still is on, but the gauge illumination lights are all out.
AND the headlights will not go on! the signals work fine.
does anyone know what may have burned up to cause this? thanks for any help!
Sometimes is does not pay to live in Michigan. Anyone down south want to adopt me for the next 3 or 4 months? :-)
However, the road is very hilly as you are driving through the mountains of Pa.
I think that affected my milage. I also noticed tahtthe car was not as agressive while in Pittsburgh. Dont know if the elevation had anything to do with it. Of course the other explaination is the extra four people and luggage in the car.
So the 17's are summer-only wheels ehh? I thought you got some MXV4+'s for them. You could've gone with some summer tires. Did you put snows on your 16's? Or just all-seasons?
Henri, 5 people, luggage, and hills means 23.4 mpg is actually pretty good. It also depends on how you drive, and what speed you tend to go. Mileage at 70 mph is typically worse than at 60 mph. Maybe it is the light antelope color? You might want to trade it in for a newer black Aurora. You'll make the money back in gas savings once you get that slick black paint. (Hey, I'm telling you what you want to hear. And besides, you once believed a salesman that told you the wheels on the 1995 pivoted to reduce the turning radius over the 1996 model.)
http://www.autotrader.com/findacar/vdetail.jtmpl?car_id=146395281- &dealer_id=&car_year=1999&make=OLDS&distance=75&a- mp;max_price=&model=AURORA&end_year=1999&advcd_on=n&a- mp;min_price=&address=33442&search_type=used&advanced- =n&start_year=1999&color=&cardist=0
You may be able to find some 2003's, and maybe even 2002's still on the lot new. Any GM can repair/service the car (like your local Caddy dealer). You can go to GMBuyPower.com and search for cars on the lot. You used to be able to search really wide areas, but not anymore. Though you can plug it different zip codes to see what is available further away (or just talk to your local Olds dealer...)
There is no 2004 model out for the Aurora. 2003 was the last model year.
My garage at home does really well with staying cool in the summer, but for some reason it gets really cold in the winter. So my products get to live out there for 8 months out of the year, which is nice, but once the outside temp starts to dip below 50 degrees on a frequent basis, I have to haul it all in. I think I get disgruntled about it because it signifies the end of summer for me, and the end of car-washing season too. I've got nothing against winter, but I hate having a dirty car!
-Brian
http://www.epinions.com/content_69706026628
Henri
I can't get enough of the IMSA stuff. IRL was cool, but they only competed against Infiniti there. IMSA was world competition.
Well us being gear heads and all I though I'd tell you how my new 01 ssei did at the track. Performance mods so far are Thrasher CAI, one size smaller supercharger pulley and belt 3.4in, Intense shift kit and 180 thermostat. Best run out of 7 was a 14.736 @ 94.62mph. My 96 aurora non autobaun ran 15.6 with RSM intake and TB. Never got a run with the Corsa's on. I was pretty happy with my times even though wheelspin was a major problem, there was a lite mist of rain right when I got there. I got my 7 runs in fast and it started to rain, got free pass to go back. I know I could of hooked up better at the lauch, oh-well. Next time. Next mod planed is a limited-slip-differential aka=front wheel posi. This should help my traction problems big time and elimante torque steer.
see ya around
You could probably pretty easily go to a higher-lift rocker before contemplating cracking open the engine. On pushrod cars, the rockers are real easy to change.
I notice exhaust work is conspicuously absent from your list of mods. Any plans in that department? You'll have to weigh your choices carefully after having been spoiled by the Corsa's. The way they are still silent while cruising is just so dang impressive. Let me/us know how it goes!
Oh, hey, any 60' times? I'd bet better hookup at launch would put you under 14.5 with no other changes. That trap speed is pretty impressive.
Bob
Keep that torque monster going..........
R/T----.704
60'-----2.321
330'---6.265
1/8----9.548
MPH---75.10
1000--12.363
1/4----14.736
MPH---94.62
I'm sure I could of gotten a 14.5 or lower if the track wasn't slighlty wet, my 60's couldn't hook up. Just roasted the tires down the track. Next time I'm sure I'll do better, thinking about picking up some cheep rims and throw some drag slicks on.
As for exhuast, that's right stock for now. I heard that Corsa is develpoing a system right now for the GTP 3800SC series II. Can't wait, holding out for the sweet, sweet corsa's. Should be available spring time I hear. I just want the mufflers and tips, might leave stock tips on.
Pulley size, your right RJS don't want to go lower than 3.4 untill my mod list gets bigger. Going to get some TOG cermaic plated headers and proabably some 1.91 high lift Intense Rockers, after those two mods I can run a 3.25 pulley. Hope to get this all done by spring time. Think I might be come a track junkie, getting hooked.
I noticed the GXP still has that variable ratio steering. I'm not sure I'd like that as much as the variable effort/fixed-ratio Magnasteer II of the Aurora. The variable-ratio steering in the new 5-series is of course all the rage with the auto magazines (even AutoWeek who said they had to turn the car off every 10 minutes to reset the system as the wheel no longer centered properly while driving [nice, ehh?]) and is something GM has had for a long time.
http://www.detnews.com/2003/autosinsider/0311/04/autos-314583.htm
But man, the way the beam is cut off vertically, while great for oncoming traffic, sure as heck makes it hard to see street name signs at night. My wife and I are looking at houses, and sometimes I go to drive by some before we decide whether to look or not, and at night on roads I'm not familiar with, it can be quite difficult to see the little blue street name signs...
The brights light them up like daylight (they are the brightest brights I've ever seen), but I can't always flick the brights at each cross-street... Unfortunately brighter low beams really won't help because the light pattern is still so well-trimmed vertically.
Anyone else have this problem (probably only 2001+ owners)?
http://www.popularhotrodding.com/enginemasters/articles/chevrolet- /bigblock/0305em_turbo_bb/
l67 aftermarket rocks, i want a ssei someday. i was impressed on there interiors. i know my step moms 93 ssei was horrible inside, but i like the 2k bonnie's more than the 95 aurora's inside.
if you got a 15.6 without your exhaust work, maybe i can get a low 15 if i go to the track, with my exhuast & autobahn advantage.
Mostly small, weird stuff with simple fixes like the vent sucking papers out of the glovebox.
Look at the build date, it's possible that the car is basically a 2000, as the 2001 was a very early release. Not that there is anything wrong with that. Just something to be aware of. Also, 54,000 miles, while more than your Intrigue, isn't really high for a car that's about 3 years old.
There was also a suspension change at some early point in 2001 which firmed up the ride a bit. Look through the archives on http://service.gm.com/index_en-US.html and you'll find it. I can't remember what article it was in, but I remember seeing it.
Let us know how it goes. One plus of Aurora ownership (besides owning an amazing car) is the awesome board here on Edmunds. I check a fair amount of boards, and this is one of the best (imo)...
I bought my 95 in September of 2001 with 64,000 miles for about $9800. Now she has 80,000 miles. And she's all mine.
I was thinking about getting rid of her and buying a new Mustang GT convertable, but you know -- I love the Aurora. Power, luxury and that sexy body.
I think maybe I'll just pick up a late 80's Mustang this summer for a couple grand as a blast-from-the-past car. (my first new car was a '87 GT.)
And keep the Aurora as my "real" car.
anyway.... just rambling.......
HC ppm (that's Hydrocarbons in parts per million)
Limit: 67 ppm My car: 0 ppm
CO % (that's percentage of carbon-monoxide)
Limit: 0.37% My car: 0.01%
NO ppm (I'm not sure if it's really all NOx's or just NO it measures)
Limit: 524 ppm My car: 1 ppm
So, as you can see, just because the car passes emissions doesn't mean the emissions haven't gotten worse. They could be substantially worse and still pass (like 3000+% worse). Just thought this might be interesting to someone.
I suspect part of why it doesn't seem quicker is that it isn't really that much quicker. You'll mainly notice it on the highway when passing. But also, the Aurora accelerates very smoothly so it isn't as noticeable (not that the 'trig is rough, but the Aurora is smoother).
You could have lined up at a light next to the salesman. Then you could really see which is quicker...
The shifter bulbs would require the trim removal. This shouldn't be hard, but I have heard several people say the mechanic chipped the wood trim. No problem if the shop does it as they then have to replace it, but if you do it yourself, there is that chance you'll need to buy a $300 trim piece.
It sounds like we can safely say welcome to the board...
I think I just confused myself after thinking about this. If the build date is 9/00 and the 01 was an early release, wouldn't that pretty much guarantee this is an 01? Or am thinking backwards here? (I'm not being a jerk--I'm just wondering if I'm wrong).
Also, the 01 was the first year of the redesign, right? If so, I would guess that would be easiest way to tell for sure.
At any rate, the price is phenomenal for what is in the car noted.
A 9/00 would typically be a 2001 model, and usually about the second month of production (they generally start up in August). However, there are definitely some 5/00 and probably 4/00 cars as they went on sale in May of 2000. These would ordinarily be the end of the 2000 model year, but were instead a very early start of the 2001 model year Aurora. So even though they were called 2001's they were about as old as some 2000's. That's all.
Hey sda, did you mean that several changes were made in 07/00, not 01? By July 2001, the 2001 model run had probably stopped and the factory was retooling for 2002's. They typically stop around May to June and start up around August.
24mo/24000 mi $1511.00, 36/36000 mi $1950.00. Not much price reduction by increasing the deductible to $200. This is the "Gold" warranty. With the failure of other third party extended warranty companies I've read about, I feel a little more comfortable with AAA. False security, I don't know. Advice: car has 53000 miles, clean Car Fax, but no maint records. A/C currently inoperative, but dealer says they'll fix. Should I buy the extended warranty, or just take my chances as I have in the past? Thanks for your input.
Gotcha!
I just got a pair and the dealer had to locate the mats cause GM is not supplying them anymore. YUP, the mushroom interior is going the way of the 442. So if you want OEM matts . . . .
Henri
I think you still have to get them programed at a GM dealer but the key and fob is much cheaper.
Good luck with the new toy !
