Nissan Pickup Problems
I have a 87 Nissan Pickup (V6) with 135,000 miles on it. No problems or major repairs ever performed. Just burnt up the catalytic converter and had it replaced. Vibrations begin around 20-25 mph and then kicks in gear. They occur again around 40-45 on occassion. Weird thing is the truck runs fine first thing in the morning. Starts vibrations after it has come to a complete stop and then you accelerate again. Anybody know what to check? I've been told it could be the O2 sensors or possibly the transmission. Also told to check the driveshaft center support bearing. Looking for any hints or tips as to what is causing vibrations or what would have caused catalytic converter to burn up.
Pickup. In the first couple of days I noticed a
vibration that is most apparent in the range of 37
-47 mph and in 4th gear. The vibration seems to be
in the rear. It can be felt through the seat, not
the steering. I brought it back to the dealer and
they said it was normal to this truck and there is
nothing wrong.
I would appreciate responses from any owners of
this truck to get an idea of how 'normal' this
condition might really be. Also, if you have had
this problem, have you been able to fix it? If so,
how? Thanks.
Has your dealer checked the tires and alignment? Another suggestion would be to take your problem to a higher level of the management at the dealership?
If all else fails, you should try a different Nissan Dealer service, or and independent tire specialist to get a second opinion. Good luck. ;-)
Pocahontas,
Edmunds.com/Host
I got a response from AllExperts.com about this problem from a Nissan service manager who reommended having the drive shaft checked for proper balance.
The dealer told me they had checked the balance and alignment but I get the feeling from them that I'm basically being blown off.
I have made an appointment with another dealer to have a look at it. I'll mention to them all the suggestions I see here.
Any other suggestions anyone? Has anyone else had any experience with any of the problems noted here so far?
Thanks everyone.
