Isuzu Modifications/Aftermarket/Accessories
Pat.
I think my Trooper's ride is overly soft and the body roll a little excessive. I'm planning to replace the shocks first. I've had good luck with the Rancho RS-9000's on other vehicles so I thought I might try a set. Anyone else have any shock recommendations? If new shocks don't fix the whole problem - what should I try next? Bushings, sway bar, new coils?. I don't want to buy / install any more new equipment than necessary to get a reasonably firm / better controlled ride.
I'm also planning to add a hitch. Might try the Hidden hitch after reading favorable posts here. I've installed several Draw-Tites, U Hauls and other similar brands. Is the Hidden hitch as well built?
I'd like to replace the factory hood protector. The one that came with the Trooper is too flimsy - it rattles and taps on the corner of the fenders at speed. Anyone found one that works?
I also want to install some nice fog lights. Anyone have a recommendation here. I've read a couple posts on the Hellas - people seem to like them. What sort of specifications / light pattern should I be looking for and where's the best place to get a good buy on a set?
Thanks in advance for your help.
To echo other comments, replacing the front and rear speakers in the Trooper makes a huge difference in sound quality. New 6 1/2" front and 4" rear fit perfectly without any problems. Even I could do it. I would recommend getting wiring harnesses to attach the Trooper wires to the new speakers. I couldn't find any at Circuit City nor Best Buys, but I understand that Crutchfields has them. Finally, the 6 CD changer in my 2000 Trooper has never skipped under any driving conditions. I would recommend it to anyone wanting to install a CD player since it also fits nicely into the slot below the radio.
Lights: I swear by Hellas. They seem to have the best reflector and lens quality. I have Hella 4000 130w European Beam Driving lights mounted on my Nudge Bar. They are excellent especially upstate NY on the mountain roads.
Hitch: The hidden hitch I installed is great. I tow a 3500lb boat trailer with ease and haven't had any problems. The hidden hitch is nice because the only part you see is the reciever, everything else is tucked up under the bumper.
Check out my web-page for various vendors of lights, hitches, etc. Ken Beard over at susquehana motorsports was a great help with sorting out lighting.
-mike
http://www.iace.com/isuzu/trooper
-mike
Troopin.
-mike
-mike
Pat.
Not sure if they'll ship to US, but most likely will.
-mike
have the nudge bar.
http://www.sportsrack.com/storesense/scripts/store.exe/
then go to "vehicle gear" then "steel horse" then "misc auto accessories".
http://www.4wdcars.co.uk/pages/isushow.htm
Good luck!
http://www.iace.com/ia/trooper
-mike
-mike
A couple of points to consider.
#1 lifting truck with t-bars only adjusts ride height. The suspension will only go down so far. So if you lift with the bars you start to limit travel.
#2 Adjusting t-bars will REQUIRE a new alignment.When the suspension moves the camber moves.
#3 On MY 99 I did not notice any real change in ride quality.
Good luck and happy tweaking.
Troopin.
with the 3" lift, what size rims and tires are on it?
Another bonus of this package is the wider rim allows serious airing down. For the uninformed you can air down to 10-15 psi in snow and sand to improve traction. It allows the tire to sqat and float over the soft stuff. When we went on the glacier I was running 8psi! If you try this just drive slower and make sure to air up before you hit the road. I'll stop rambling now
Later Tom.
-mike
-mike
In October/November, the quality of the Optilux bulbs fell below the high standards that HELLA demands. The manufacturer shut down their production lines to rebuild and recalibrate the line to introduce a new, higher level of manufacturing quality and quality assurance testing. We are no longer selling this line of bulbs until the New Optilux bulbs are available and have undergone a much more rigorous quality testing process.
I am now told by Hella that the Optilux Bulbs will not ship until after the first of the year. That means I won't have them to ship to you until the second week in January. There is a small chance they could ship earlier, but I wouldn't count on it. I would just as soon Hella and the manufacturer take their time to make sure the bulbs are right this time!! Bookmark this page because when I start shipping, I will change this message.
Regards, Ken
Might be worth waiting for?
PIAAs, Cheapo Blues, Hellas, Phillips, etc. etc.
I've found the Hellas to be the highest quality, longest lasting of the bunch. Especially for Auxiliary Driving lights, i've found them to be far better than any stuff you can get at pep boys or JC Whitney.
IMHO wait for the new Hellas.
-mike
I needed to change wiper blades recently, the dealer wants $15.00/ea. (wiper assy not just the
rubber). Go to NAPA and get p/n 60-020-1 EXACT FIT
blades, 8.00/ea. both were installed in 5 min. they work really good.
-mike
Also a gripe, the washer fluid refill opening in the back door is impossible to hit without a funnel. I had to go to Target and buy a funnel set. Minor observation of mine.
Still enjoying the troop approaching 15K miles.
Andy
Troopin.
The reason I got familiar with the spare tire cover and tire was so I wouldn't have to struggle with it as much if I ever got a flat.
I have a 99 Trooper, stock height and P255/70/16s. My goals were to get the on-road stability improved without sacrificing off-road performance. For my needs I also decided that I wanted a stock ride height. I put on Edlebrock IAS and poly swaybar bushings, which made a substantial improvement; still wanted more. I found a pair of Calmini bars that a guy just didn't like. I installed the front only. Based on his claim of excessive stiffness in the rear I left the stock rear bar with poly bushings. I then installed a set of the Airlift 1000 airbags inside the rear coils. On the installation I chose the dual airline feed so as to add a bit of roll control to the body rather than forcing the air out of the low side; bag and into the high side bag.
Results WOW! The Trooper is just as normal a driving vehicle as there ever was, the ride is terrific, suspension movements well controlled and body roll is minimal. I use approx. 10lbs of air in the bags (range is 5-35) and carry 50lbs of gear. With medium loads (4 adults + the 50lbs of gear) 20 lbs is awesome. I would suggest that the IAS's run out of steam with a couple of hundred lbs and 4 big folks. Ranchos, KYBs etc. might be a better choice if you load down heavy. When pushed in the turns the Trooper has a bias towards understeer (although not excessive), which is good. A wagging tail suddenly regaining traction could be catastrophic considering the CG. I suspect the addition of the Calmini bar in the back may bias it towards oversteer and it would certainly hurt the ride. The other really nice thing is there is no appreciable loss of articulation in the rear and only a small loss in the front (i.e. still cool as anything off-road).
For those of you searching for a great set-up I would say at the very least do the shocks, bushings and Airlift. The Airlift is awesome even if you don;t load down heavy! Hope this is of interest.
Chris L.
I also have winter blades on front too, but I stick with Trico brand...Anco is OK to, but there are a lot of crappy blades out there too.
I tried to engage the wiper and stop it partway, but there still wasn't room to lift the arm. I also took the spare cover off, but that didn't help because there is a plastic back plate behind the tire that is really the problem.
After a couple of tries I can get the spare cover off in a matter of seconds. Just get your fingertips behind the lip and yank it towards you, pulling from both sides near the bottom - it's not as fragile as you might think!
I don't worry about it anyway, because soon I won't be able to use the cover when I get bigger tires...
Just got a new Trooper and would like to install racks to the hardware under the plastic roof inserts.
Before I start prying the plastic strips off of my roof, does anybody have advice on how to remove them without damage?
Thanks in advance for your help,
Koert
You can see a troop and where the brackets go. I used this setup.
click the following:
www.overlander.com
products
Trooper 1992 and up (also Acura SLX)
Aluminum Expedition Racks
Good luck: Troopin.
On your advice, I am putting in Hell 100w fog light bulbs.
First, wow, is the plastic case around the rear of the lamp brittle! I think I had broken the latch in about 30 seconds, which may be a record for me!
Second, the electrical connection was too loose with the new bulb, and I had to use pliers to squeeze the female half of the connection to make a secure fit.
Finally, how on earth are you supposed to get the rubber cover back onto the rear of the bulb assembly? Maybe it would be easier at 70 degrees than at 35 degrees, but that sucker simply will not go back on. (It might have helped if I hadn't started the job at sundown, and if I had more time.)
Any suggestions? Helpful tools?
-PA
"Paisan", not "Paisa"
"Hella," "not Hell"
and
"PP," not "PA". The spell checker said that the words would be replaced unless I pulled down the "From Text Box" button from the menu. Which I DID.
Whatever.
I pushed on the connector by hand as far as I could get it to go, and the same with the boots. I was a little worried about the boots not being as snug as stock, but I've had em on since June and the bulbs/reflectors are all fine, and I've used em all winter here in the Northeast with much wet salt on the roads w/o a problem. Also driven through 1-2' of snow with it and not had a leakage problem into the reflector area.
-mike
