Isuzu Modifications/Aftermarket/Accessories
The UNI-T AQII web page on the technology is a good read. Click "next" to read all about it.
http://www.bridgestone-usa.com/tech/index.asp?id=tech_unitAQII
Interesting about the weight. I didn't pay too much attention on the increase in unsprung weight on my larger tires, though I got P series, I feel the performance difference there is pretty minimum for my choice. I ended up going against LT tires, from what I read you get additional load capacity but a little stiffer.
I did the spare too. The $25 (trade/upgrade) cost will be worth it if I ever get a flat and am stuck without a true full size spare. I haven't gotten a cover yet, it looks good without, but I worry about the life of the rubber sitting in the elements without being used? I would take your plastic cover off before you do the upgrade. I forgot and they ripped it a little trying to put it on the larger tire. I took for granted they would try, let alone try hard to get it on.
Here is the link for the full quote and discussion. http://www.4x4wire.com/cgi-bin/ultimatebb.cgi?ubb=get_topic;f=86;t=002171 The quote is by Answerbacker about 1/2 down the page. He also offers the opinion that a flush is better than a pan drop on these trannies.
It was nice to see this quote:
"Flushing the trans with nothing other than new Dexron-3 or Mercon-3 is an excellent idea, much better for the 4L30 than dropping both pans and replacing the filter; but considering how freaking messy it can get it's better to just find a shop with the machine."
...because that's exactly what I did.
P255/75R16 109 load rating and 33 lb. each. I expect decent MPG with these tires, but I only got the standard 13/32 tread depth, not the 16/32 offered only on the LT tires.
On the drive home they were very quiet for an AT tire, compared the the BridgeStone Dueler HLs that were replaced, the AT sound as if I can hear the wind across the tread, but no more road noise. They handling was about the same as the HLs. The Revo ATs share the same dual rubber compond construction that preserves traction over the life of the tire by exposing softer rubber as the tire wears.
-mike
I started looking into lockers? I wish the ARB rear was an LSD/Locked rather than the Open/Locked setup. I think that may hurt onroad snow/ice performance? I am also considering doing the front first? Would I get enough performance increase offroad? Most of the terrain I travel is either mud, snow or sand?
Then of course there is the TBAR upgrade? Or the OME lift? I have sort of ruled out both until if/when I get a winch and will need to support a heavier load up front.
Any good suggestions? So far I have done Tires, OME Shocks, bull bar, thule rack, CB radio and IPF lights.
I have installed new 285/75's on my '99 Trooper. After exploring several choices Bridgestone, BFG's etc., I decided to go with a Cooper Discoverer S/T. Check them out at www.coopertires.com
I wanted something more aggressive than an all terrain but not a full-blown mud tire. After tons of research it all boiled down to cost. $140.00 each x 5 installed. After playing around in North Georgia this weekend, I am extremely pleased with these tires. For anyone considering an increase in size or a more aggressive tread pattern, here is my 2 cents worth:
Pros:
1. Incredible Traction- I stayed in 2 wheel drive (5-speed manual no TOD available) on 2 soft sections of the trail that have required 4- hi in the past. These tires have a 20/32 tread depth that always provided serious bite.
2. Ground Clearance- 1.5" additional lift. Combined with 1.5" OME springs, my trail riding is much less stressful than before.
3. Appearance- Unbelievable transformation. Tires look great and Trooper is easy to find in a busy mall parking lot.
Cons:
1. Performance- Motor can handle the larger tires, but you will notice longer acceleration times from a dead stop. This combined with an 11% slower speedometer reading can be depressing.
2. Noise- Not as bad as I expected, but at a level higher than some may consider O.K. for a daily driver.
3. Wear and Tear- Large heavy tires tend to wear moving parts faster.
I knew that by going this route I may compromise some preferable on road characteristics, but the Trooper has taken the changes in stride and continues to be smooth and responsive. I drive 95% highway and 5% off-road. The improvements on the 5% side more an outweigh the decreases on the 95% in my opinion.
Troopers with those new tires? I am looking for
a set for my Trooper but have not yet decided.
You can insert a photo (*.jpg file) in this forum I believe -- how is that done?
-mike
-mike
I will try to get some pictures taken this weekend of the tires and email them to Mike so people can check them out. The 265/70's look very close to stock.
-mike
I almost added the 1" spacers prior to the tire change, but decided to hold off and try the tires without them. I never felt any contact from the tires, but I took it fairly easy on the trail. My concern with the spacers was cosmetic. Using factory wheels, I felt that the truck with spacers may look too tall and narrow. Of course I made this assumption looking at my trooper with a 1.5" lift and 245/70 tires on it. Now that I have the wider tires, I think the look of the truck would improve with the spacers.
As far as off-road performance goes, I am trying to break free this weekend to push the new tires further. If I feel any contact, I will post A.S.A.P.
I have some "before" photos on a trail in Blue Ridge. We are returning to the same spot this weekend so I will try to get some "after" pictures that show the improvements.
On another note, I received my rear bumper from Calmini and have installed it. Has anyone with this bumper had trouble sliding the receiver hitch into the bumper. Mine appears to be 1/8" to tight. Hopefully it is just the powder coating causing resistance and the shaft can be encouraged to fit.(In other words... beat in with a hammer)
I know one other guy reported a problem like yours with the bumper for 92 - 98 Troopers, but others said theirs was fine.
Bottom line is I think the ball mount is the variable here. With the higher receiver on the new bumper you may need to buy a ball mount with a bigger drop anyway.
-mike
I am a bit novice at this, so help is appreciated. I have a few questions:
- How do I secure the lights to the cut-outs w/o using the stud/bolt that comes with the set?
- How easy is it to pass the wires through the firewall?
- Should I buy a "factory" switch, replacing the cover that in place now for an "authentic" look, or should I just use the kit-provided switch.
Sam
OEM fog light switch part #8971355120
relay part #8970939101
Good Luck,
Lee
I believe there is a plate that can be removed and allow pass through? The one I think it is has a 1.5" hole around it, so if you put wires through it, I don't know how you could cover it up?
Let us know how you get the wires through, I am interested because I am thinking about running more lights and my CB antennae through there.
-mike
Please post your before and after MPG around town and highway.
Thank You BoxTrooper
1. With no vehicle mods, any suggestions on a larger tire size that won't rub, etc? I don't care about speedo calibration.
2. Does a large tire decrease your chances or cause problems when you need warranty service? One dealer I went to gave me the impression that they were looking to make any excuse possible.
Any info greatly appreciated.
Tom
My mileage prior to tire change was 14 city and 18 highway. The 285/75 tires have reduced my city MPG to 12. I have not made a good long distance trip to check highway performance. I'll let you know the outcome.
I have a question for Mike or others that have installed the rock sliders from Indy 4x. If I install these bars, do they provide enough exposed surface to serve as a step into the vehicle? If I can gain a solution to the height issue while increasing rocker panel protection, I'm ahead of the game. I hate to install nerf bars that provide limited protection if this product will do the trick.
Thanks for any input.
Hope this helps.
-mike
http://myweb.cableone.net/bcanderson/trooper/handle/handle.html
Might help you climb in there easier...
What a great write-up on the grab bars. My upgrade list is getting longer by the day. I think with the rocker bars I will hide my excitement and claim them to be a "wife required" purchase. Stacy and I have only been married for 2 months and she is growing very suspicious over my Trooper's never ending maintenance needs. By maintenance I mean off road springs, rancho shocks, mud tires and other goodies. It's kinda funny that her Volvo never seems to need these items.
I believe it's April 5-7 that we are all heading down to Uwharrie, you should try to make it!
-mike
PS: To tempt you more, I'll be making homemade meat sauce, Italian sausage, and bringing 2 dozen NY Bagels.
In Oct we had about 10, last April we had closer to 25. This year they started early planning so it is looking like we'll hit the 40+ mark. The wheeling is fun, but the comraderie is unbelieveable. You put together 20-25 people who never met and you wind up talking til 3am around the camp fire about everything from kids to cars to trucks to politics!
Much fun is had at Uwharrie.
-mike
www.indy4x.com
Poly spacers in 1" and 2" sizes. If you are looking for lift, why not upgrade the springs first? It will add height and improve handling.
-mike
You mentioned that you may add the poly spacers. Have you had a chance to do that yet? Were you looking at 1" or 2"?
I am considering a combination nerf bar/rock slider I saw posted at 4x4 wire. Has anyone else looked at these bars or ordered from this company before?
http://www.4x4wire.com/news/shrockworks/rocksliders/
Any input on these bars would be helpful.
Lee
-mike
-mike
Any thoughts?
Mike, it sounds like the addition of your sway-away bars was a good call in more ways than one.
Hopefully by the time I come to uwharrie, I'll have in the ball joint flip/spacer, and the poly spacers in the rear with my T-bars cranked up.
-mike
-mike
How will a front LSD effect everyday driving?
BTW anyone read the Audi S4 review...they made a comparison to a diesel chevette, quite funny...was that the worst car ever produced? Maybe that should be an edmunds forum.
I've driven a few trucks with front LSD enabled, it gives you a slightly tighter feeling in the steering wheel but other than that it's not bad. Heck a lot of cars have front LSDs now (Subaru STi, Nissan Spec V, Some Audis)
-mike
A guy I knew in college had one, this was in Duluth, Minnesota, which if you haven't been there has very steep hills kinda like San Francisco. This thing could barely make it up the hills, and seemed to take forever to warm up in the winter...what a POS
I am a little concerned because optima's website states that they do not offer a cranking battery compatible with a '99 trooper. The retailer assured me that the battery would work fine with my truck. But $130 will make most people agreeable. My concern is based on the fact that the 99 trooper 5-speed uses a different size battery than the 99 automatic. Is there a reason for this size difference or is it just a matter of economics on Isuzu's part?
On a lighter note, I have spent the afternoon lifting my hood and showing my secretary, my boss, most of my co-workers and a few strangers my new battery. I am expecting a surprise drug test tomorrow at work for all of my efforts. :-)
Lee
Although I suppose I should look at the Optima-type batteries too, when the time comes to replace.
I am adding lights down the road and would be very interested in the configurations owners on this forum are using. (isolators, parallel set-ups etc.) Optima makes a yellow top deep cycle that is supposed to be strong enough to use as a cranking battery.
