Isuzu Modifications/Aftermarket/Accessories
I'll describe the diagrams the best I can. Basically, there is a note that says "If the speaker wiring in your car is as illustrated in Fig. 1 and Fig. 2 below, DO NOT connect the unit using that original speaker wiring."
Fig. 1: Shows the stereo with a + and - line running to each speaker. The - lines to both speakers have a connecting wire running between them.
Fig. 2: Shows the stereo with a + and - line running to each speaker. The - lines to both speakers are broken. At the point where they are broken, there is a symbol that looks like a short horizontal line with three diagonal lines underneath.
Fig. 3: Shows the stereo with a + and - line running to each speaker with no additional symbols or wiring connections.
If this description isn't enough, I'll try to replicate the diagrams and post them later. Thanks for you help.
Luke
I
Not having a volt meter, and not really wanting to buy one (I will if I have to) do you have any idea if this test would answer my questions...By touching the + and - speaker wires to the + and - terminals of a 9 volt battery the speaker will make a popping sound. If the - line to the speaker is grounded, do you know if the speaker will still pop?
Luke
The - (negative) side of a speaker should not be
confused with nor connected to chassis ground !!
This will fry the audio amp chip in most current
auto stereos (unless stereo's instructions say otherwise)
The Fig.1 description means the -sides are common and in Fig.3 they are not.
Fig.3 should be the right choice. To verify use an
ohmmeter to check for an open or very high resistance from each -side to another and to a chassis ground, with the wiring harness disconnected from the stereo.
Connecting a 9V battery will not be accurate, but will be helpful if you want new speakers!
Does anyone know if the 2000 Rodeo speakers are wired according to Fig. 3, or will I have to test the wiring to find out?
(I'll try posting the pictures here, but I'll also post a link where the three diagrams can be viewed, just in case)
In case the pictures do not show up, check this web site:
http://www.geocities.com/bama_luke/diagrams.htm
Thanks again for your help.
Luke
Usually you can not go wrong if the wiring to all the speakers is run with a + and - lead from the unit. Then its a simple plug in--otherwise if you can not verify that you would need to run new speaker wires.
There are some cheap continuity testers. You might try Radio Shack. Also what unit was in your Rodeo?
Do you know where to get one from?
On the Isuzu site I can see this(for the new models), but my Canadian dealer has no idea
http://www.isuzu.com/rodeo_accessories_rearroofspoiler.htm
More parts to break for sure, but well made with dampening door hinges and a smooth mechanism. I took the chance, if it breaks I hope it's within the year of warranty it has. Just don't let the kids use it as a french fry holder.
>>Have you had any problem seeing the white LED display in bright sunlight?<<
Not a problem. BTW, you can reduce the gaudy index by turning the display motion function to OFF. It will then display only the time, "CD" or the radio station you're on. No other fireworks.
I checked out the other units also at Best Buy, Sound Advice and Circuit City. Yep, the Alpines look really nice (did you see the one with the flowing dolphins color LCD?). But for my money the Sony couldn't be beat and the 3 position bass extender feature can't be found on the other players until you hit the $300 mark. Good luck.
Islander
If you check out my site http://www.iace.com/isuzu you can find a few places that sell the OME springs.
-mike
Cheri
Luke
-mike
The correct Rancho RS9000 shocks are
part no.: 9214 for the front, and
part number 9215 for the rear.
I have put these on, and really, really like them. They are adjustable, so depending on your mood or load you can always find a setting that you like. Also, note that Rancho often runs a "buy 3, get one free" offer in the spring, so it should be on soon if they are repeating the offer. I paid about 60/ea for four, online.
As for the springs, the Old Man Emu springs will give about a 1" lift in the rear, and will really firm up the sway/lean/bounce in the Trooper, or so I have heard. I have opted to keep the stock height, and so ordered Valley Spring Works springs, which are progressive rate (25-45% firmer than stock, depending on load) but keep the same height. I have yet to install them.
-Ken
-mike
I'll try to get some pictures to post of the installation soon.
Luke
I'm looking forward to your FAQs. It is comforting knowing that common concerns and solutions for the Trooper will be just a click away. I have some information that I have been compiling from the boards, and I will send the info to your email address on your web page. You probably have some or all of it, but whatever.
Unfortunately, I do not have the part numbers for the VSW springs; nor do I think they call them by part number. You just tell them what the application is, how tall you want them over stock, and how stiff you want them over stock. I think they just take the stock numbers and go from there.
I can tell you that they were about $215 (incl. shipping) for the pair; the person to deal with is named Bill, who seems to be the owner; and their numbers are 707-678-3944 and 800-287-2645.
-Ken
http://iac.tzo.com/isuzu/ or http://www.iace.com/isuzu
-mike
http://iac.tzo.com/isuzu/nudge.html
or
http://www.iace.com/isuzu/nudge.html
-mike
Product: Bushings For 1" Diam. Sway Bars
Sku #: 88ZX7546P
Unit Price: $9.95
Product: Bushings For 3/4" Diam. Sway Bars
Sku #: 88ZX7540T
Unit Price: $9.95
I installed these on my 95 Trooper. A very easy and inexpensive upgrade. They reduce body roll a decent amount especially when combined with aftermarket shocks. I believe that Isuzu might have increased sway bar diameter in later model years, so suggest you double-check your own year before ordering.
Regards, Marty
95 Trooper LS
or
-mike
-mike
An old piece of carpet would be useful too as you will be laying on the ground under the truck for a while!
Good luck, Marty
95 Trooper LS
Also, are the OEM headlight bulbs replaceable without having to replace the lense assembly? And will the OEm wiring handle a 60L/100H watt hella bulb?
-mike
-mike
From what I've read, Bighorn isn't the name of the accessories company, but is what the Trooper is called in Japan.
If anyone has heard of a way to order the Japanese accessories, please let us know!
for the details and pricing. E-mail me if you want in. mike@iace.com
-mike
There are two wires in each connector: a green/blue pair in one and a gray/gray pair in the other. I no longer assume that gray or black = (-). So which one is the (+)??? Identifying which connector (left or right as viewed from the rear of the speaker) on the speaker itself is the (+) also gets you a prize.
Additionally I noticed that these Polks are about 1/2" deeper that the stock ones and rub against the plastic bracing strips on the rear of the speaker opening. I don't know how well the cover will snap on once I get those guys screwed in. Any feedback on this issue would be appreciated.
Islander
If anyone knows how to get an order thru to this company please let us all know. Thanks.
To find out the wiring for the speakers , take a 9 volt or any battery and a piece of wire. Split the wire and tape an end of the wire to opposite ends of the batter. Write down which wire coming from the radio went to which speaker spade. Disconnect the speaker and put the wires from each end of the battery on each speaker terminal until you see the speaker move out. When the speaker moves out note the side of the battery that is positive going to the coinciding terminal on the battery. Match that spade to the appropriate color that you wrote down with the wire from the positive side of the battery. That will be the positive wire coming from the radio. I hope this makes sense.
-mike
