Chevy Silverado (C/K) & GMC Sierra (1988 - 1998)
I have been a Chevy owner all my life and I like them because they are
easy to fix compared to others. The only problem I have seen is that
they nickel and dime you to death. I have done nothing but replaced seals in this thing for one, Tail seal tarns, every seal in the front or the 4X4 system is leaking( still is ) heater core, front rotors again, 2 fly wheels, 2 throttle position sensors,oxygen sensor, throttle body base gasket, water pump, i. have always done the normal
maintaince, oil changes every 3000, cap,rotor,wires,rear miff. fluid
change,transfer cans change,tarns filter change, both door buttons for dome lights, all filters etc. The problem I have is I always believe in buying American, my wife bought a Subaru and it is the same year as the Chevy and she did NOTHING to this vehicle, and I mean nothing, just normal oil changes and brakes, it only has 12,000 less miles then my truck, I guess the American auto companies just keep us coming back.
Also, try using the Board Search to find other active Silverado Topics throughout Town Hall. Btw, unless you, or other participants, would like me to keep this topic open for a discussion of older Silverado models, I'll be closing this topic in the next day or so.
Thanks for your participation. ;-)
Pocahontas,
Edmunds.com/Pickups Host
I don't jump on it from a stop or do a lot of towing or let it idle more than a couple of minutes......
I do like my truck and would buy a new Silverado if I could stomach the $400 a month for 72 months......
I hope this thread does take off so older GM truck owners have somewhere to go....
Oh yea, how many miles on your truck jobey1?
Happy Motoring. ;-)
Pocahontas,
love the new forum name too!
(tho, maybe it should be 88-98 GM Trucks?)
thanks again!
Pocahontas,
Edmnuds.com/Pickups Host
Truck is a 97 1500 Silverado, 4x4, 5.7l, auto, extended cab.
Bob
Do you know if what they did to your injectors is what they normally do? I had the injector service done to mine @ 30k & 60k but I think it was just some detergent that they hook into the fuel rail and run the motor for 10 minutes or so...
I've been dumb and followed the service guide to the letter and each time I get the usual big maint. bill but then they find something else wrong, so my bill gets bigger... If I can afford it, my truck's gonna go 400k ! ! !
(of course every nut & bolt will have been replaced at least a dozen times by then)
4x4man, what kind of mileage are you getting?
I do my own service, and repairs, except when the cost of the repair part is more than my deductable. I like working on cars, so my time is never included in my choice whether to repair myself or let my dealer have at it.
My truck right now is getting about 14 mpg in town and 17-18 mpg on the highway. The highest I ever got on the highway, going to Minnesota from Colorado was 21 mpg. Towing by boat (3,000 lbs) in the mountains I get about 12-15 depending on how much my foot is into it!!!
Sorry for the long winded post, just wanted to make sure I answered your questions.
Bob
4x4man: I got 20 once; I drove to Fargo and back to Duluth before filling up, 520 miles on the tank. I drove for 60 miles with the gas gauge below E and with very sweaty hands... mine had symptoms like yours, but it turned out to be a frayed coil wire. When it was running, you could see an arc from the distributor to the air cleaner. I always park in the garage, but one nite I was tired so I left it out. The next morning was when it started doing that. So, I make sure I park in the garage all the time...
jmincher: it was using oil that soon? burning or leaking from a gasket? I've started looking at S-10s with the 4.3. I've always heard that they were very good. Well, my brother has a '91 S-10 with 163k on it and no probs, and my dad bought a '92 S-10 with 161k on it and it runs great too... how are you liking your new truck?
As it turns out the computer set a code 1406, bad EGR. Also fuel pressure was low. They replaced EGR and Fuel pump. It starts much, much better now with the new fuel pump!! They stated because of the low fuel pressure there was no cause to do the injector service..It was late when I picked the truck up, so I wasn't able to get any details about the injecter cleaning...
Thanks for any feedback ya'll can give me.
the diesel exhaust won't tick off your horses, will it? j/k
Any kind words, or words of warning would be appreciated. I have read many references to the injector pumps failing, and some valve/compression issues. I understand that it has a lot of torque, but only 190 horsepower. I am concerned that while it may get up and pull my trailer (high torque) it may not get there very quickly (low horsepower).
Thanks for any help you can provide,
Eric B,
Anchorage, Alaska
just out of curiousity, was it built in the U.S., or in Canada?
My neighbor has a 98 K3500 Chevy with a 6.5L diesel 4x4 and I have a GMC K2500 with a 454 gas 4x4. We both pull a 11,000 lb. 5th wheel camper.
On the flats we are equal. On the hills I can pass him like he is standing still. At the beginning of the hills we are equal, but on long hills his RPM's flatten out. He is governed at 3200 rpm's. I can down shift and go up to almost twice that. My tourque peak ramps up and flattens out. His ramps up and drops down. You can get this info on the internet. The gas milage is about the same. When I want my 454 to pull it pulls. The tourque on the diesel is a little higher, but I make up for the difference on HP. Hope this helps.
I though at first that I blew them with an old boat trailer I'd pulled. Thought I might've shorted-out the turn signal somehow. It blew the right one the day after I pulled it home. Then, yesterday, the other side went out. And I hadn't pulled the trailer since.
STRANGE.....................
keith24
I guess I've been lucky, I've pulled trailers with my truck and all the lights work the way they're supposed to. Then I've pulled the same trailer with a Ford, and they'll blink super fast, or not at all. Then on our boat trailer, when you step on the brakes, all of the dash lights get extra bright. But the Ford is unaffected...
One of the strangest things I've ever seen.
keith24
Because of my current financial situation, I won't be able to buy this expensive of a truck in the forseeable future so this one has got to last. I'm strongly thinking of getting an extended warrenty for this truck because I'll probably need it.
p.s. my tranny went out because the surface where a seal was seated wasn't machined right. so it got chewed up and I lost reverse. but it was under warranty so it could've been worse...
Only problems encountered so far have been a bad EGR, Fuel Pump and Power Steering Unit.
Debating on changing the auto tranny fluid again, just did it at 50K, have heard that if you tow, 15K auto tranny fluid changes are better for the tranny. I only tow during the summer, but now have to face stop and go traffic going to work and home. It's been cold and snowy the past few days here in Denver and I have the DTA (Don't trust anyone) attitude so I won't take it to someone else. Anyone else tow with their truck?? When do you change the auto tranny fluid??
Anyone change transfer case fluid?? How often do you do it??
By the way I had to change my front brakes last summer also, not because the pads were worn, but the bozo that had the truck before me heated the rotors up so bad they were worped and the truck would shimmy when stopping with the boat. Took the rotors down to the machine shop, they had to turn one of them twice to get it to clean up, put the sure stop towing pads on ($44 ouch!!) and it stops like a dream with and without the boat!!
See ya
Bob
I wondered about the treatment of the transmissions that were failing in all the posts I read at this site. I suspected that they were being abused. Now, I’m less inclined to think that way.
I bought my ’98 K1500, (ext cab, Z71, 350ci, 3.73, 4L60E, made in Texas for California smog) truck with 47K on the odometer a year ago.
Within the first month, reverse didn’t reverse. They put in a used replacement (First Extended service contract) that lasted a week before putting itself into neutral just as I reached about 65 after getting onto the freeway. I was told that they had it rebuilt locally this time.
I am driving a rental car at the moment due to the O/D servo unit being replaced. This requires removing the trans to do. I don’t like the effect of the O/D going in and out at a frequency of about a second of time engaged and then a second of time disengaged continuously while maintaining a constant speed from about 45 to 65 mph. It behaved the same in third gear selection at a lower range of speeds.
I towed a 4x8 U-haul (maybe a thousand pounds) once for five hundred miles. The rest of the time ha been easy daily driver and some weekend trips of about 1100 miles a few months ago.
While I like the truck very much, it doesn’t inspire confidence. I have no intention of dumping it and will likely watch for a used C3 in a couple years as a replacement.
Anyone else had the “undecided Overdrive”? Not the same as the “hunt” when it doesn’t know which gear to be in at a certain speed.
Chris
If anybody has any info on this, I'd be most appreciative!
keith24
Thanks for the info!
keith24
Anyway he found this website about this FuelMAX thingy, supposedly it gives up to 20% increase in mileage and some kind of performance boost. Anyone heard of it??
Here is the website:
http://www-mtl.look.ca/~tonyg29/
By the way my 97 Silverado 4x4 5.7l auto 3.73 is getting 13-15 in town, around 17-18 on highway, on a long highway trip I managed to get like 20 or 21, but haven't ever seen it again since.
See ya
Bob
I got her with power windows, A/C, am/fm/cassette/, 5.7 350, deluxe cloth interior,etc. and I spray 'sealed' the bed and chassis before installing a full bed liner and aluminum cap. Even though I live in NC.
She'll be around until 2011....no problem. Question is.....will I?
Thanks for the info. I will watch mine closely. So far it is fine. I am not gonna go out and buy a spare tranny because of it, but as they say take everything you hear and read with a little common sense. I was gonna ask about the strange 8217 things, thought that was some stock part for 2nd and 4th gears.. I do have one question for you, mine is the 4X4 not Z71, but I have checked and mine has the 3:73 positraction rearend, all the skidplates. Is it some special rancho or Belstein shocks that get you that nice sticker on the side? I believe mine would perform as well. I have had it out and played with it in 4hi and works flawlessly. It has actually snowed and iced here in NV. Thanks for any info.
