-June 2024 Special Lease Deals-
I have heard of some manual tranny's that use automatic transmission fluid (with a more frequent service interval for fluid change), but have never heard of a manual that used engine oil.
On a sidenote, if you think 30k is ridiculous, then you would be real annoyed with my 2005 Yamaha Vino 125 scooter. I had to change the tranny fluid after only 600 miles! And this is thick 80w-90 gear oil. After the first 600 miles, I have to change it every 4k I believe. Oh well, it's worth it for the fun in the sun and the 80mpg
75W-90 Gear Oil
And I'm still going to change it every 50K, especially since I used fully synthetic, Hyundai be damned!!
Warranty is almost done anyways . . .
My dealer did a 30K service for my 02 GT two months ago and everything has been normal. But I just notice that the coolant level is slightly below the "low" mark when vehicle is parked for several hours. Is this a problem or should I add some more to bring it up? I don't see anything leaking since I always park my car in the same places. If I need more coolant, do I need anything specific for my Elantra GT?
By the way, just a few updates for my GT.
Bought new in Oct 02 and it has been quite normal. It only refused to start for a few times during cold weathers but I could start the engine in 2nd or 3rd try. Little problems I have now are:
1. Clock stops working (has been quite some time now) but not completely. I don't care that much so I didn't ask dealer for repair.
2. There are some weird sounds coming from steering wheel column during the first few minutes driving. It sounds like the wheel rubbing something. It disappears quickly.
3. A couple of rattles could be heard when driving on broken roads. Actually, there was almost none before I did my 30K routine service. During the service, my dealer insisted on replacing the blackout tape on my driver's door, which had been replaced before, since it started to peel out once again. I didn't care much but eventually let them do it since they said it wouldn't take long, and you know, they earned money from doing it. After a few weeks later, I started to hear rattles in my driver's door and I am pretty sure they didn't do a perfect job when putting my door back. I will talk with my dealer about it during the next visit.
Other that those, everything has been good. I am still on the original tires and battery.
All in all, my GT serves me well and the problems listed above are OK with me considering it is a 3-year car. I will recommend it to anyone looking for a reliable car for commute and A-to-B use.
I have done a little research for the all-season tires and Yokohama seems to be quite good with longer thread life and excellent price, do you have any experiences with them? I know Kumho is cheaper and gets good review too, but do they have long thread life? Any advice is welcome. Thanks.
I don't have much to say about the tires because I tend to go more for high performance tires rather then long life touring tires. Both are good name brand tires though. Much better value then Michelin and Goodyear.
I recommend changing the battery before it conks out. Here is why. When the battery conked out on my Grand Caravan, it made the electronics act stramge. The symptoms were not what I expected from a dead battery. The van was still under extended warranty, and that covered towing it but only to the nearest dealer. Because of the weird symptoms from the dead battery, I told them to go ahead and run a check on the car. Bad mistake. The total charge was something like $180, including a way-overpriced battery. Better to pick up a battery on sale at Sears or similar I think, when you are in control and can find a good price and are not desparate to fix it no matter what.
The BEST all-season tires I have ever owned (on my 3rd set now on my GT) were the Bridegstone Turanza LS-T (yes, they are T series, but unless you like drive over 115 mph a lot, it doesn't matter). They had outstanding rain performance, even close to the end of their treadlife. Mine lasted about 70K miles, which was MUCH better than the original Michelins. I replaced recently with Falkens, to save money, as I had to replace tires on two cars at the same time and did not have the funds for more Turanzas!
Read your manual about proper break-in driving. This is VERY important! Things such as not keeping the same speed on the highways (don't use your cruise control during break-in), not running the car past 3,500 RPMs (no reving the engine), braking intermittently and carefully, etc.
Here's my maintenance schedule (which may not match Hyudai's official schedule, so check your manual):
Oil and filter (semi-synthetic oil & Wix or Bosch filter) every 5,000 miles
PCV valve every 15,000 miles
Air filter every 20,000 miles
Coolant drain & refill every 40,000 miles
new spark plugs every 25,000 miles (check them for proper gap and carbon build-up in between changes, every 12,500 miles)
Manual transmission gear oil (full synthetic) every 50,000 miles (manual says to do this more often)
[If I had an automatic, I'd change the fluid every 25,000 miles]
Tires rotated every 7,500-10,000 miles
Brake in advance whenever possible, using intermittent pedal pressure (don't press brake pedal continuously unless in emergency situation).
I think that's about it (I may have left something off).
Read every detail of that warranty carefully!!! Paint is covered for only a short time period, as are some "external" engine parts (some are not covered under the 100K powertrain warranty). Hyundai dealers/reps, in some regions of the country, don't always like to perform warranty work - find a good dealer and hope your area is not covered by a crappy Regional Rep. Unfortunately, my area (middle-west Tennessee and North Alabama) has such a rep . . .
Good luck and have fun! The Elantra is well worth the money!
When I conferred with a HIGHLY-reputable independent shop, the manager thought that sounded odd and said he would recommend that I have the water pump replaced as the bearings on the current water pump might have a hard time adjusting to a new (tighter) timing belt and could fail.
Anyone ever heard of this "simple pump" stuff before? I am wondering if it is a ploy for further labor charges if my pump fails after paying hundreds in labor for the timing belt replacement.
Anyone?
I miss my old rear drive 1980 Buick, as it's water pump was veyr easy to replace, although the car had horrible reliability!
I know, I know, the speed limit is 70. But my favorite motto: "Speed doesn't kill. It's that sudden stop that gets you."
My engine is stuttering upon startup each morning now. So, I think it may either be spark plugs or battery. I have not changed either.
With hot and humid chicago, a/c smells nasty upon startup.
I think I need alot done:
Oil Change
Coolant Change
I think timing belt needs to be changed?
Tranny fluid flush?
Fuel Filter change?
Let me know what i should be doing at 60k (or what should have been done by now).
Do you suggest an alignment when you do not notice anything while driving? the tire shop suggested it after i got new eagle GT goodyears.
On the alignment--if it ain't broke...
It is unfortunate how much money is spent on uneeded services. Such as the GM dealership that advertised that not servicing the automatic transmission every 15K miles "might" void the drive train warranty. I equate such tactics as theft.
I would change the plugs and wires. I didn't do that to my Aspire until 90k, but it was behaving just as you describe. Afterward, it was like brand new! I doubt a bad battery would give those symptoms; in my experience the car just quits when the battery dies.
tuneup, like alignment, is corrective, not preventative. One thing to look for with those symptoms is plug wires, they do go bad now and then.
If you have not replaced the gear oil or coolant by 60K miles, do it ASAP. The manual calls for 30K changes for gear oil in the manual tranny. I recommend Mobile One fully synthetic gear oil. It's a relatively easy do-it-yourselfer if you want to save some cash.
Forget the fuel filter unless you still experience problems after your spark plug change.
Your spark plug wires should be OK for now, but I'd recommend replacement at about 90K miles for the wires. Spark plugs should be changed (or at least checked) every 20K miles at minimum.
If you haven't replaced your air filter yet, do that ASAP, pronto!! Every 20-25K depending upon your environment for the air filter!
I just replaced my timing belt at 96K miles - wait until at least 90K before paying the big bucks for the labor on that job (California Elantra manual gives 100K miles on the timing belt due to stricter consumer protection laws). I only paid $190 + tax for the labor and found a Continental Contitech timing belt online for about $50 (Original Equipment brand). Always find a VERY reputable garage and avoid the dealer to save big bucks. Finding an honest, reputable garage is often difficult, however. . .
Good luck!
feeling quite zippy on the freeways as i have regained lost power (probably due to the spark plugs). Gas mileage is increasing as well i assume.
bad incident though...i ran over a huge honkin' rock (those landscaping rocks) as i was manuevering and believe the catylytic convertor may be damaged. not sure if its the converter, but its part of the exhaust manifold. it was slightly smokin' and looked like fibers were loose (looks like a frayed wire). when i tried to backup from that rock, i was stuck. so i brought out the jack to jack up the front. it worked, but i have some damage done to the jack because it moved in the wrong direction. the jack then got stuck between the ground and the radiator (luckily didnot punture the radiator). bent my intake vent next to the fog lights a bit. its mainly cosmetic i believe.
it was all surreal...I could not believe it happened to me. just paid a butt-load to get maintenanced and then i have this happen. i've lost confidence in my driving. gosh, i am glad that it was at low speeds that i ran over it.
car feels fine thus far. does the damage to the catylitic converter warrant another look at without any symptons?
My 2002 GT has 21K miles and runs like a top. I just commute with it. It still looks pretty new. I'm hoping I can get 5 more years out of it before I buy my Midlife-crisis mobile. Had seriously considered adding a blower or turbo until I read some guy's Blog on how much work it was. I'll just try to be happy with my 135hp.
I do not see why it would be transmission problem because you are idling and not moving any gears.
I this very problem on my 91 Colt Vista. I never changed the spark plugs on that car. It stuttered with the AC on. I think it was a weak engine to begin with, plus i tossed it before i ever changed the plugs.
So don't go and change your spark plugs right away, but i just know that my car is smoother on startup now. Before changing, it had hesitation unpon start up.
I have 120,000 on my '02 GT, been through a few problems, but still love the car.
I have a crack in the converter/manifold, and called the dealer for info.
They say the recall affects 99-01 Elantras. I am wondering how many people have this issue, since the engines were probably made in early 02. What are the chances they will recall 02? I am obviously out of the warranty (long drive to work everyday).
Anyone have any ideas??
Technical Service
Bulletin
Subject
Group
Number
Date
Model
CIRCULATE TO: [ ] GENERAL MANAGER
[X] SERVICE MANAGER [X] SERVICE ADVISOR [X] WARRANTY MGR [ ] SALES MANAGER
[X] PARTS MANAGER [X] TECHNICIAN
CAMPAIGN
05-01-001-1
MARCH, 2005
1999-2002 ELANTRA,
1999-2003 TIBURON
EXHAUST MANIFOLD ASSEMBLY INSPECTION AND
REPLACEMENT CAMPAIGN - V04
This TSB supersedes TSB# 05-01-001 to include additional part information and
part return shipping instructions.
IMPORTANT: DEALERS MUST PERFORM THIS CAMPAIGN WHENEVER AN
AFFECTED VEHICLE IS IN THE SHOP FOR ANY MAINTENANCE
OR REPAIR AND PRIOR TO RETAIL DELIVERY.
IMPORTANT: WHEN A VEHICLE ARRIVES AT THE SERVICE DEPARTMENT,
ACCESS HYUNDAI MOTOR AMERICA’S WARRANTY VEHICLE
INFORMATION SCREEN VIA DCS INTERACTIVE OR DCS ON-LINE
TO IDENTIFY OPEN CAMPAIGNS.
DESCRIPTION:
Exhaust manifolds on some 1999-2002 Elantra and 1999-2003 Tiburon vehicles with
2.0L L4 engines may crack and require replacement.
Inspect the exhaust manifold for cracking and, if necessary, replace the exhaust
manifold with a new part using the following service procedure.
NOTE: This photograph shows an example of an exhaust manifold crack. This is
for illustration of a possible crack location. Cracks may be smaller than
shown in this photograph.
Page 2 of 8
VEHICLES AFFECTED:
• Models: Elantra and Tiburon vehicles with 2.0L engines
• Affected Production Date Range:
• 1999-2002 Elantras: Produced through January 31,2002
• 1999-2003 Tiburons: Produced through January 31,2002
I am considering adding a Hyrdocarbon Oxygenator system to my car to improve my engine's efficiency (should increse fuel efficiency at least 5-8 mpg). I'm almost at 100,000 miles now.
