-June 2024 Special Lease Deals-
I've had some fun with it. Check it out. https://www.mygmlink.com/main/US/en/gm/home
Happy Motoring,
Chris
Subaru has a similar site; must be some GM/Subaru cross-pollination at work.
From my totally objective viewpoint:
The Envoy looks good for a minivan. The Trailblazer is the only one rugged enough to not look out of place on the trail. However, I can understand that its styling is too aggressive for lesser mortals who are better served by soccer mom vehicles.
I have had the Silverstars in for about 3 months with no problems. When I changed the low beams one side had a Philips at 55w the other had a Sylvania at 51W. The Silverstar 9006 low beam is 55W. The 9005 high beam is 65W thats 5W more than the stock. I believe the people with problems were using higher wattage bulbs that are not street legal. Also one thing to remember is these bulbs will not last as long as the stock bulbs, Sylvania website states 1 year with normal usage. They are not taking into account the that the Triplets have Daytime Running Lamps, so on nice clear sunny days I turn off the DRL's. To add I am totaly happy with my very white headlights. On the downside the fogs don't match they look yellow I don't use them together any more. Sylvania has plans to release the fog bulbs later this year.
Dealerworld is for dealers only. You do need a username & password to access the site. If you don't get your info Thursday and you have an email addy that you don't care about making public post it and I can probably get the info on your truck for you and email it to you.
If you check here
http://www.jetchip.com/DynoSheets/DynoSheets.asp#Chevrolet
They have the envoy on a dyno. Largest gain is 21hp at 4500 rpms. Might just make the jet chip a good investment for a quick upgrade.
and regarding the looks of the envoy vs. chevy. I like the grill better on the envoy, but body and curves definitely go to chevy. I actually decided against the gmc because of those round reverse lights in the back bumper.
For those that are interested, I keep fuel mileage data on all my vehicles. I do it in MS Excel. Have a spreadsheet I have used for years. Put in miles driven, gas used. My DIC matches the numbers I get from EXCEL right on. My overall average is 21.3 MPG.
Those that don't trust the DIC, reset it and try again. I think it is very close on my truck.
Truth of the matter is that all THREE vehicles are pretty much identical and beauty is definitely in the eye of the beholding in the case of the triplets. To each their own, but essentially, we all own the SAME vehicle! They are all manufactured at the same facility (with the exception of the EXT models)!
Geesh!
NEXT SUBJECT!!! Hopefully something a little bit more of substance??
<SMILE>
IExplore2000
PS: Essentially, we all are driving mini-vans in the format of 4x4's! Ha, ha.. Oh.. to tip the scales a little further, ever consider the fact that we are all essentially driving STATION WAGONS without the wood trim on the outside! EEEEKKK!!!
Frank
You won't see me exceeding the limits of course.
My vote is the Envoy for looks. The TB looks more agressive, but don't care for the front grill, headlights or the bubble taillights.
From a practicallity standpoint, I didn't want full time 4wd on the Bravada. Envoy gives me the best of both worlds.
At first I wished I got the XL, but now realize it would not fit in the garage.
So, I'll remain happy with my Indigo Blue Envoy SLT 2002. Even with all the quirks.
ps. still getting better mpg since the software update. I recommend you have your dealer update your code.
Well now I am no longer a cop. Guess I better watch the speed limit in my flashy Black TB. By the way, the TB and Envoy look way better than the Bravada!
Anyone have this done??
What cost??
Any negative issues experienced??
I wish they showed torque gains. That's what really gets the truck moving!!
HP = torque * RPM / 5250
At 2500RPM that comes to a torque increase of 27.3 ft-lbs. 20 at 5500RPM. This is good.
DIC experience. Mine is 5-6% optimistic, not complaining as I think this is accurate enough.
2002 Envoy XL SLT owner.
Happy Motoring.
Chris
Well so far so good 69,000 and still running fine---knock on wood please!! There were some posts a while ago referring to AC problems specifically with a Low Pressure switch. It started last week that I noticed that the AC started to blow warm much longer-- about 20 seconds when first started, then eventually begin to get cold about a mile or so down the road. It is also cycling noticably faster than it had been especially at start up. Once up and running for a few miles it seems fine--very cold! and the system appears to be holding the interior temp. as set. It is happening during every start up now and seems to be getting longer to get cool air. Could this be a symptom of the switch?
Have about 2,200 miles on it.
At 5250 rpm torque would equal HP, something that does not apply to the triplets or most high revving engines. I think you really need to see an actual torque curve to see what the differences are. Many mods that help high rpm HP actually hurt lower rpm torque.
GAM
1. Envoy
2. Bravada
3. Envoy XL
4. Ascender
5. Trailblazer
6. Trailblazer EXT
7. Rainier
- no more wandering mirrors
- no more tiny 18 gallon gas tank
- no more towing my track car in third
- no more choppy towing because a short wheelbase
I wish this had been available when I got my LTZ two years ago. This is MUCH more like it. My dealer was very cool and we swapped my LTZ's black grill insert for the EXT's 'chrome' one. It looks good. Plus, with $4,500 back I lowered my payments.
Torque always equals horsepower at 5252 RPM's.
http://auto.howstuffworks.com/question622.htm
somehow the formula can't be applicable across the charts.
http://www.gm.com/automotive/gmpowertrain/engines_cartruck/other/- 38l67_torque.htm
"so then how does the L67, 240hp S/C GM 3.8l motor produce 285lbs or torque and 240hp at 5200 rpm's? somehow the formula can't be applicable across the charts."
That chart you showed is from the advertising department and may not even be the same dyno pull. The HP and torque bands do cross at 5250rpms on a dyno chart. It is math magic.
GAM
Has anyone installed some good aftermarket running boards on their triplets that would be of this style?
Any feedback would be appreciated.
the jetchip page claimed 246 HP stock on the dyno... someone posted 1yr+ ago that they tested theirs at 190HP????
~Ken
Other than that, I must say that this is by far the nicest SUV we've ever owned. We previously had a 95 Jeep Grand Cherokee and a 96 Chevy Blazer. We had numerous problems with the Grand Cherokee's V8 engine and traded it in on the Blazer after only a year. Then our third child was born and we needed the third seat so we traded the Blazer in on a minivan after only a year. We've been waiting for at least 5 years for someone to build an SUV with three seats, (at least one smaller than the Expedition/Yukon/Suburban.
All in all, we're very satisfied with this vehicle.
GAM
