Visitor Agreement.
I don't know how many of you have watched the BBC show "Fifth Gear" on the Speed Channel. They recently had an eye-opening test where a Land Rover (equipped with a full roll cage and driven by a professional stunt driver) attempted to swerve around a car that braked suddenly in front of him -- an all-too-common occurrence. At just 45 MPH, the Land Rover flipped over several times. They did the same test in a Jag sedan, and the car merely slid out, even at 90 MPH. The driver summed things up by saying he wouldn't want to attempt the same maneuver with any of the SUVs on the market today.
It might help until we get the matter resolved.
Sorry to deviate from the main topic. '02 Trailblazer still going strong with no problems.
http://www.detnews.com/2005/autosinsider/0502/21/autos-96165.htm
mac24, "Forums Software! Your Questions Answered..." #1836, 17 Feb 2005 4:07 pm
It sounds like you are one of the lucky ones....
I love it when Chevrolet over produces a vehicle and then is amazed they have tons of them left over.
The 1st dealership lubed it several times before putting in a steering wheel support bearing. If this was to correct the problem, I wouldn't have to send my Tblazer in to the 2nd dealership.
This dealership says that they fixed the problem by putting some gasket on. Now it made turning worse!
Does anyone have any idea what I should do in this case? This has become a constant headache. Has anyone have this problem with their TBlazer? What do you recommend?
The dealer kept trying to lube it, but that would only help till the lube was pushed out of the way.
Don't give up. It is mechanical. Mechanical things break or get out of adjustment - and mechanical things can be fixed. It just takes the intelligence and persistence to figure it out. Don't let them wear you down because they are lazy or don't want to fool with it.
Paul P
imadad2, do you think poor quality and low resale value have anything to do with overstock?
Bigger rebates and more incentives will make the situation worse. I don't think anyone is going to be able to trade in an 02 for instance and buy an 05. The trade in price for the 02's and 03's may be next to zero by the time they are done giving everything away.
- WPK
Are all of the Envoy's auto AWD? Does it not have the options like the TB has of 2WD, Auto, 4 HI and 4 LO? If it only has Auto AWD, when did they start this and have the issues been worked out since the 1st year problems?
Greg
A quick introduction for any interested:
2005 Black/Black Trailblazer Every option except engine heater. I purchased this through a Supplier Discount program. Truck is 3 months old and has 2500 miles. I am somewhat pleased with the T/B but have a few quirks.
1: Chevrolet should have left the white gauges(gave it a more sportier feel)
2: Still cannot believe an almost $40,000.00 truck has no under hood or glovebox light.
3: As mentioned above, slow response on the auto 4wd
4: Gas Mileage at Corvette #'s but was expected.
5: Fancy controls on the steering wheel but no temp. control as on the Explorers.
6: Like the idea of turn signals on the mirrors but cannot be seen during the day, should have went with the tahoe's in the mirror design.
7: would have liked to see a power fold away mirror also as in the tahoe.
8: Ride quality is great, smooth as silk
9: not too impressed with the performance overall, but then again this is my first SUV in 4 years. Traded in my Impala for the T/B
I will update more as time goes on.
The Buick/Bravada use a "SmartTrak" system that works differently and doesn't have a low range or 'off/2wd' It is basically engaged all the time and works faster than the "Auto 4x4" of the others.
--jay
You got it. The ride is not as smooth but certainly isn't harsh.
Check my comments at post# 14618 for all the upgrades. The way it's set up now, I can actually make my Envoy "dirt track" on an on/off ramp or spend all day "drifting" on a wet parking lot. Please don't tell my mom!
I think the only difference between the TB and Envoy's suspensions is the wheel diameter. The TBs come with 16" vs. the Envoy's 17".
I recently noticed that my license plate lights were out. I haven't gone to the trouble of checking fuses but all other lights, interior and exterior, are working and the bulbs seem to be OK. I only have a test lamp to check the sockets so not sure if I'm getting juice to the bulbs or not.
Has anyone else had these lights fail and could this be related to the tail/stop lamp recall? I have yet to get to the dealer to get that done.
tranfer case that worked much better than the current one. The current Bravada is similar to the Envoy in that is senses wheelslip between the front and rear axle and electronically locks up the transfer case. It may have less of a reaction time than in the Envoy, but you could still feel it engage with a thunk.
GAM
BTW, I own 2 Ford Cargo vans, I don't know my Ford mechanic by name.
Most of the problems occurred because it was a new design. I'm not saying that's an excuse, just a reason. It's only natural that a company works out problems as a design gets older. Case in point - look at your cargo vans. How much does a van change year to year?
Actually the basic suspension is the same, but there is an option for rear air suspension on the Envoys. The Trailblazer LTZ comes with 17" wheels standard - LS and LT come with 16" std. The Envoys do come with Michelin Cross Terrain tires which do soften the ride vs. the BFG's on the TB.
You don't say which engine you have, but 19-20+ MPG Hwy is not uncommon with the I6 and 2WD. Yours is not quite broken in yet. You can expect better mileage after about 6000 miles. If you have the 4.10 diff, 4WD, and the V8 you can, of course, expect lower MPG.
I ordered mine direct from Hotchkis and the only issue I had is they were out of stock and it took 2 months to receive the part.
I just view it as a maintenance item.
- WPK
BTW my 2002 TB has Bilstein shocks on the rear from the factory. That's what that the label on them says. Envoy and TB share the same part number (15172342) for the rear shocks. Exception is the auto-leveling rear suspension.
