While waiting in the car today, I was bored and popped out the glove compartment door just to see how the filter is mounted ( I have a 2002). Well with the system on recirculation, the vent door is open and you can see the filter. So, I reached in and felt the filter. Yuck, I could feel the grit and even pieces of leaves or who knows what... I'm glad the filter was there to catch all that crud.
RBB
The changes are very nice. The new nose is very obvious.
With all the dust and grime around here, I'm glad to have it.
We change about every 12 months. Haven't had the van that long, but we'll do the same with it.
-brianV
Is the wiring under those caps on ALL 2003's with the in dash 6cd "Premium" tuner. I also have cassette too. Thanks.
PS: My tranny is still a jerking at cold take offs and other times between 1st and 2nd. They'd better figure out what this "normal" condition is soon! It seems to be worse in cold damp weather like we have now in MN.
Thanks for the info. on the air filter for the cabin...more$$$'s to spend.
Can't say if it's there on all 2003's, but we have an LX with the stock head unit, so you probably have the same wiring harness.
-brianV
How hard is it to install the sub-woofer in the back? Are there wires there too?
Now I am looking at Goodyear Aquatreads (better wet handling), Goodyear Regatta 2 (quieter ride), maybe a Yokohama Avid (heard about it here), and a few others. What kind of experience have any of you had on tire replacements? What is the best tire for the MPV?
Michael
Steve.
I can tell you with certainty that the subwoofer is NOT pre-wired on 2003 LX's or LX-SV'S. They use a different wiring harness from the headliner at the C pillar rearward. There is a connector in the right general location that has caused a lot of confusion, but this connector is apparently for diagnostics, not the subwoofer (nor the power door motor).
However, the tweeters ARE pre-wired in the dash on the LX, and reportedly for the rear as well. I'm not certain about the LX-SV, but it's easy enough to find out (see my post above).
It's less clear about prior model years, but it's safe to say that Mazda is no longer pre-wiring the subwoofer if you didn't order it. I suspect that they didn't pre-wire the sub-woofer in some prior model years either. It may be related to when they stopped offering the super sound system as a stand alone option.
On the other hand, if you have a basic understanding of electrical circuits and access to the wiring schematic, making up your own harness isn't that difficult. The wiring schematic is quite straightforward.
As to cost, you can pick up an OEM sub-woofer for just over $300 from that dealer I mentioned recently (search for "mazda stuff"). It's the only sub-woofer I've been able to find that will fit comfortably in the available space, without getting in the way of cargo with the seats out.
I haven't pulled the rear panels on our MPV yet, but I hope to discover wiring for the rear tweeters when I do. Unfortunately, the rear tweeter covers are integrated into the inside panel, so adding them is prohibitively expensive. I'm thinking I'll either go aftermarket or get a second set of dash tweeters for the rear. They're finished nicely and would still match the interior. The OEM sub-woofer is sitting in my garage waiting on installation...
Someone in Mazda's marketing department deserves to be drawn and quartered for inventing all this nonsense... Why not offer the sound system upgrade as a stand alone option ?
Sorry for the long post, but I wanted to save you folks some headache.
First it's the tranny shifting problem, now this. What the heck's going on with this thing? I thought the MPV was supposed to be one of the most reliable minivans? So far, I must say I'm not impressed with the reliability.
When it's humid (it's always humid in Houston...) and the A/C running (it's always running in Houston...) my MPV "puddles" the garage floor from the condensation dripping off the A/C lines.
If the fluid is transparent and no smell odds are that is what it is.
Leaks: Get the dog and see if he laps it up. If he does, it is coolent. (dog will probably drop dead)
Tj
Eh perhaps because with DW and kids at home all the time I'd get no way to utilize it at home. At least in the car I'm occasionally alone and can blast it a bit. :-)))))
I lik' it alot! Rear lamps are a little like RX-8 with the dark metallic reflection inside. All three had the body colored grills. Loved the look of the rear discs. Interior is pretty cool too, it has a lot of the dimpled plastic like my Protege.
I just want to see the ES model...the wheels should be pretty cool. Dealer says they look a lot like Rx-8 wheels. I forgot to check and see if they fixed the shifter problem (getting in the way of the stereo) but the door lock on the passenger side rocks. My wife might want to trade in our current 2002 just for that feature.
The Titanium gray looks pretty nice, the other was the same ol' gold, and the 3rd was a blue mix (not light or dark). Can't say I care for that blue...it may be similar to the Rx-8 blue, but it doesn't do it for a big vehicle imho. Toy blue is what I would call it.
Frankly, the 4-speaker system is unusually poor, even for stock. I'd call it downright horrible, and I'm not one to spend on sound systems normally. The door speakers are the same ones used in the 9-speaker system, and have clearly been spec'd to have help on both ends of the spectrum.
Adding the dash tweeters made a huge improvement, but the bass line is still completely absent.
A matter of personal preference, no doubt.
-brianV (who listens to everything but twangy country, heavy metal, and rap)
I paid $79 each as I recall. That was for the speaker, UV resistent cover, and cross-over filter as a single unit. They just snap in, and the color matched perfectly.
Hope this helps,
-brianV
Where are you? San Diego dealers say January for new mpv's.
Well, it came in with the plain jane 4 speaker setup.
I screamed, they knocked off $$'s and through in some toy options in for me. Anyway, the door speakers DO rock. Use the fader and you'll hear that the rear ones sound very dead and tinny. By adding the $70 each tweeters in the dash (simple adder I guess) you'll get more high end...but not more bass. My old DC had the INFINITY system and it really rumbled...sad but true, my new MPV's system is ok, but not like that one. I DID email with Mazda Stuff and they are temp. out of GRAY tweeters which would match my dash. They DO just snap into place.
The guy will let me know when they come in. Shipping and Handling extra $$'s.
Tranny deal: Fix is being worked on at Mazda Labs (LOL). There will be no bulletins, just word of mouth when it is released. The service guy mumbled his way through the process; they get a fix, try it in some vehicles and see what happens...how scientific is that! If the fix don't work, they go back to the d-board and try-try again. So it's like we're all ginny pigs while the high buck engrs. figure out this mess...Chrysler Corp., I'll never cuss only YOU again!
I can't type anymore of this sensless stuff for now.
I'm looking for halfway decent sound from a system that looks like it belongs in the vehicle, and isn't a throwback to my high school days...
I actually have a "premium" factory sound system in my subie that I'm very happy with - it sounds great, has the features I need, and it only cost $300 to upgrade the door speakers, add tweeters, and add a small subwoofer, installed. I upgraded to a 6 CD in-dash changer with a cassette deck for another $150. That's a very reasonable value for the money, and something Mazda could learn from.
I could not gut and replace the factory system for $300 or even $450 installed. In fact, when I priced aftermarket systems for the MPV, they all wanted close to 4 figures installed. That's just too much for a sound system, sorry, it's not worth that to me.
On top of that, I was going to end up with a subwoofer box behind the rear seat (and in the way of cargo), plus wiring and an amp somewhere forward, possibly under the driver's seat. I understand that the aftermarket speakers want more power to "light up", so driving them with just a head unit doesn't work well. Not my cup of tea...
I've heard Mazda's "Super" sound system, and it plays my music well. When I found out that the door speakers in the 4-speaker system are identical to those in the 9-speaker system, I decided to see what I could do with the OEM parts, since it was going to be a lot cheaper and involve less rumaging around inside the vehicle.
When I install the OEM subwoofer, I'll be at my $450 pain limit, and have a reasonably well-balanced system with 7 speakers.
If I can avoid cracking the dash, I do. I hate working under or inside the dash. I'm not fond of busting into my door panels either. You never quite get it back together the way it was... The rear quarter panels aren't as bad, because there's no need to seal against water intrusion, and no window mechanism or door lock mechanism to bother with.
Might strike some folks as an odd bit of reasoning, but it makes sense to me...
-brianV
Based on the statistical info available, this still sounds like a relatively rare problem - not that it being relatively rare is any help if you have it of course.
But if the stories of how Mazda is chasing this are true, it doesn't speak well to their business processes.
Ultimately, how you handle the problem is critical to your ability to fix it, and I'm afraid these rumors are not confidence-inspiring.
-brianV
We do sell a ton of MPVs around here...I would say it is one of Mazda's biggest markets for the MPV. Like the dealer said, they were completely out of LX models, which is why they were able to get a few 2004 Lxs.
I see almost as many MPVs as Odysseys around here...(or maybe it is just my imagination!)
Very happy with the package which includes side airbags, traction control, 4 seasons, side skirts, and towing. Mazda seems to have optioned the 2004 intelligently, except the left out the roofrack!
The new 4 wheel disks are fantanstic.
Were you able to negotiate on the msrp? Any rebates?
The dealer said there are no incentives but I think once the 2003 models go there should be $2K, the same as for the 2004 Tribute.
Color-wise, I liked the palette for '03 better than '04. The Whitewater Pearl and Razor Blue are pretty nice, Silver is still available, and some people will like Titanium but it's not one of my favorites.
The big thing is that this dealer is offering $5000 off all '03 MPVs and $3000 off the '04s. Along with the price increase on the '04s, I think that makes the '03s a huge value. The improvements in the '04s aren't worth $2000+ IMO.
-Brian
-Brian
The tranny computer is a 'learning' one, where it learns your driving habits to optimize shifting behavior. All Mazda is doing is adjusting this a bit (and in some cases replacing a valve body). That should clear it up, but there are some who continue to exhibit it. From what I understand, they're working on a new shift program that is supposed to address this once and forall.
-Brian
Thanks again
