Visitor Agreement.
On a side note, a guy with a Land Rover was sitting next to me in the dealer waiting room. When he heard he will be charged $140 for clearing his CEL, he promptly refused and drove off with half a dozen still lit warning lights on his instrument panel.
I'll search the nabisco archives, and see if I can find a link without linking nabisco.
I think it was a TSB.
Aaron - Can you check your receipt for the Check Engine code number?
-Dennis
BTW, when are you changing your handle? Thought you were no longer driving a blue subie???
My ECU was sent to SoA for a reflash after CE lights in 4/02 and 4/03 (both cases were code P1443). Took delivery of my WRX wagon in 5/2001. No noticeable difference in drivability after the reflash.
Hope this helps,
Phil
http://www.oakos.com/wrx/obdiicodes.htm
I haven't owned a blue subie since I gave up my OBS in 2002. The name kinda stuck and people call me that at meets, so I just kept it. :-) Besides, it not necessarily a good thing for people to know too much about your car (car theft victim paranoia talking).
-Dennis
Other than the lurching and occassional clutch judder, I've had no issues with the car at all. Dealers have not been able to duplicate the judder...
- Phil
-Dennis
Frankly, I think lousy California 91 octane gas and high output turbo-charged cars don't mix well.
I got the impression that they didn't have to drive it, they actually put it up on the rack to check it.
I seen the old parts, there were definite high spots on the flywheel, they replaced everything, flywheel, and all clutch parts. They said they aren't allowed to re-surface the flywheel, it had to be replaced.
Done a great job! I'm very pleased with the result.
Ken
thanks,
Tony T
legacy191
This site has plenty of 1/4 mile stats.
The WRX does it between 14.1 up to 14.9 depending on the mag and test.
The STi does it under 14.
Tires I am looking at are the
Yokohama ES100s as well as
Hankook Ventus Sport K104,
Nitto NT NeoGen ZR,
Kumho Ecsta ASX, and
Falken Azenis ST115
Any knowledge regarding these tires? Thanks
Craig
The problem with getting the Toyos, is that my tire dealer does not carry them.
So far I'm quite happy w/ the tires, but anybody buying these should keep in the back of their minds that these are not easily available.
michaell "Ask Connor at The Tire Rack" Jun 9, 2004 6:06pm
Tony T
Tony T
-Dennis
My WRX is red and the windows are not tinted.
Actually, I'll be getting in the car in a few minutes to go home. It's sitting in the sun and the temp is about 90F today. I'll let you know how it feels!
Craig
But... no problems with my Forester. With the fan on 4 I get icycles on my nose.
-juice
The AC does rob power, and the first year I owned the car, it tended to bog it down, and I stalled often. Since the first two summers, the car has become much better. Seems much tougher to bog down the car. This might be my adjustment to the AC, or the car settling in with the A/C motor or working with the ECU to adjust. Who knows?
Nothing you have mentioned is out of the norm though.
I also don't notice too much of an effect on power, though I agree that you can bog down if you're not slick with the clutch and throttle. But yeah, I was having a good time driving home with plenty of power so I would not say that the AC has much of a negative impact at all.
BTW, the AC clutch in the WRX will cut in and out depending on how much power you demand from the engine (based on throttle). SO it's possible your throttle foot does not have the right magic in first gear starts.
Craig
-juice
Incidentally, I have dark tinted windows and it makes a big difference on the AC's ability to cool the cabin. Worth every penny in my book.
Brian
Craig
As I was driving past the Subie dealer yesterday (frustrated with my car's lack of grunt) I almost stopped in to drive a new Outback XT to see if it, too, suffered in hot weather...but I was afraid that if its performance didn't suffer, I might fall in love with it and walk out with a new car.
Brian
(trying to resist another new car...)
WRX boost in 1st is minimal and there's not much before 3.5k so maybe you're just seeing the already poor off-boost performance get even worse. Do you guys find it responding badly with the AC off and running 4-5k rpm? I can't speak much from personal experience because it never gets REALLY hot here. Our summer days are mid-high 70's F. My Rex is running great!!
Nicholas
My informal timing (one thousand one, one thousand two...) today had it taking over 5 seconds to get past 4k rpms from a stop. That feels like an eternity when overloaded minivans in the next lane are dusting me through the intersection.
Anyways, I didn't mean to go on and on about it...just wanted to chime in...
B
bkaiser1, I think your case is unusual. What fuel are you using? Maybe your ecu senses knock and is retarding the timing waaay back.
Don
If anything the turbo helps overcome changing climates. How appropriate for Subaru, if you think about it.
-juice
Brian
You might want to check into knocking a bit more.
Low rpm high load knock is common but if you are knocking at high rpm and your ecu is not able to retard timing....? you might try lugging your engine (careful YMMV..etc.) to verify you are experiencing knock.
I had knocking problems with a Volvo turbo that was solved by octane booster check (knocking went away), carbon deposits was the diagnosis and mystery oil & steam the cure.
Hope you get your power back soon.
Don
If you find a problem wheel/tire, bring it back to the tire place and have them take a real close look at it. They may need to work on it a little more.
Craig
