Subaru Impreza WRX
1181182184186187224
    I gotta agree with paisan here.
    An example - look at the C&D test of the Accord, compared to the near-luxury sedans in the same issue. It's a couple of months back. 0-60 the Accord is up there with the best of them.
    But then look at braking and handling. Poorest numbers of the bunch.
    That can be downright dangerous, to have an imbalance like that. The Accord doesn't have the brakes to handle that quick a car, nor can it handle that kind of power when the roads become twisty.
    Chassis/suspension, then brakes, then engine, in that order. The Accord only has the engine.
    -juice
  • hunter001hunter001 Member Posts: 851
    Yes, the Accord with the 3.0L SOHC engine with 240Hp/212Torque is a pretty quick car. When coupled with the 6-speed manual, it is even quicker.
    But Hondas have been notorious for relatively weak brakes in their cars (excepting S2000 and Acura NSX).
    Later...AH
  • prayerforprayerfor Member Posts: 161
    The brakes and RE92s are commonly understood to be the weak links in the REX's stock setup too, though.
    I agree with andmoon that the WRX can lead to a false sense of security/invincibility, since it seems like it can accelerate, stop or steer out of any kind of trouble. Conversely, in the Maxima you're always aware of it's size and weight, and thus its limitations. Naturally the WRX setup is preferrable and the lesser of two evils, but dangerous in a different way nevertheless.
    The best way I can describe it is, in the Maxima you know when you're doing something stupid, but in the WRX, maybe not so much...
  • andmoonandmoon Member Posts: 320
    If a bigger rear sway bar makes the rear flatter/stick better then wouldn't the front slide sooner relative to original setup? Doesn't this make the car understeer more? I am under the impression that a bigger rear sway bar makes the car turn in better/oversteer more/understeer less but I don't understand the physics of how a better sticking rear would make the car turn in crisper when it is the understeering aspect of the car that makes it feel less precise in the first place.
    I am looking to upgrade my sway bars but can't decide if I want to just increase the rears to 20mm or upgrade both the rear and fronts together.
  • robmarchrobmarch Member Posts: 482
    are mainly the lame tires that they put on for nubmerous reasons. Any car with 200hp should get tires that can slow it down respectably. Especially a big midsized sedan.
  • kauai215kauai215 Member Posts: 190
    Recent comments about traction, especially in the wet, are interesting.
    I've recently taken up autocrossing, a form of moderate speed "racing" around cones in a large parking lot. Sounds silly to the uninformed, perhaps, but it is difficult, nonetheless.
    In a recent very wet event, I beat four out of five WRX cars in the rain --- in my, generally, uncompetitive '02 Honda Civic Si.
    Now, I would have thought the Subie would be the best answer for the wet conditions, yet it wasn't, apparently.
    You see, I can't get the power down in the dry --- I'm just spinning my front tires --- and the wet should have been worse, still, I'd have thought. The Subies should have trounced me with their AWD. They didn't.
    I don't understand.
    I want to understand, because I'm thinking seriously of getting a more competitive autox car, and the Subie is one of the options I'm considering.
    The Subie is a great car, no question about it, but I'm wondering if it's really the best choice for autocrossing.
    Would after-market go-fast bits make the Subie better in the wet?
    Maybe the normally aspirated 2.5 RS is a better choice for this bizzare business of racing around cones in parking lots?
    It's odd, but it _is_ fun! :-)
  • jpnmjpnm Member Posts: 22
    If you are beginning autocrossing, chances are the people you were competing against were also. So, the variance in driver skill was probably far greater than the variance in cars. It is only as the driver skill levels equalize that car differences come into play.
  • qbrozenqbrozen Member Posts: 33,753
    You are, after all, talking about an activity that is about 90% driver. Maybe the rain scared them nonetheless or maybe they were just bad drivers or maybe you are forgetting that tires losing grip due to side force really has nothing to do with how many are spinning. The subie weighs a considerable amount more than your Civic, which would add to that force. Tires will make the biggest difference in the rain. AWD only aids in the wet stuff when going in a straight line, keeping the power to the ground even if one tire lifts off of it, and quickly and easily recovering when sliding does occur. If you were able to somehow equal all other factors like driver ability and tires, then, yes, the Subies would most likely reign (somewhat of a pun) supreme.
  • hypovhypov Member Posts: 3,068
    <<In a recent very wet event, I beat four out of five WRX cars in the rain --- in my, generally, uncompetitive '02 Honda Civic Si.>>
    That's not impossible. Like jpnm said, "the variance in driver skill was probably far greater than the variance in cars. It is only as the driver skill levels equalize that car differences come into play."
    <<Would after-market go-fast bits make the Subie better in the wet?>>
    Yes, tire choice for the wet lot plays a role. I find the TOYO Proxies RAs grips very well on wet.
    <<Maybe the normally aspirated 2.5 RS is a better choice for this bizzare business of racing around cones in parking lots?>>
    Between the WRX and RS, the RS is the better choice chasing cones :D
    At the end of the day, it all boils down to the Driver.
    The go-fast-bits is taken out of the equation if the driver can't take advantage of them. Heck, there's this guy with an earlier model Civic I've seen eating up WRXes at the AutoX [time wise].
    -Dave
    Like was posted above it's 90% driver. In my old XT6 I could beat almost all the WRXs the first year they were out. Mostly cause they were n00bs.
    Hypov and I drive the same exact car at auto-x(same as in share the car) and often times One is near the top and the other is near the bottom of our run-class.
    -mike
  • Kirstie_HKirstie_H Administrator Posts: 11,242
    Join us tonight, 6-7pm PT/9-10pm ET for Town Hall Trivia Night and member-to-member chat &#150; come test your knowledge and chat with fellow members!
    http://www.edmunds.com/townhall/chat/townhallchat.html
    See you there!
    MODERATOR /ADMINISTRATOR
    Review your vehicle
    <<Hypov and I drive the same exact car at auto-x(same as in share the car) and often times One is near the top and the other is near the bottom of our run-class.>>
    Perfect example... I'm the other near the bottom :D
    -Dave
    How do you go about getting into auto-x?
    Will Subaru consider it as 'competition' if a warantee issue arises?
    Don
  • mgreene1mgreene1 Member Posts: 116
    The WRX competes in D Stock, where the Integra Type R is the car to beat.
    And that's exactly what one very well sorted out WRX and a great driver did. :)
    Here's a chart of cars and classes and the results from last year's nationals.
    http://www.moutons.org/sccasolo/Lists/2002/stockc.html
    http://www.scca.org/amateur/solo2/prosolo/2002/finale/results.htm- l
  • bruticusbruticus Member Posts: 229
    I filled my tank Saturday morning and calculated the mpg, then calculated it again because the result was 29.6.
    I'm diligent about resetting the trip-o-meters and always fill the tank all the way (never partially as it's more costly of time)
    Granted, the majority of my driving is highway (out of my 28 mile commute 26 miles are on a highway) but that sounds a bit high.
    Anybody else getting numbers close to this?
    I'll keep watching to make sure this isn't operator error.
    DjB
  • c_hunterc_hunter Member Posts: 4,487
    I got 26mpg recently during a week of well behaved driving. My WRX only has about 2000 miles on it. I would not be surprised if I could get up near 30 with more highway in the mix. So, it doesn't seem out of the question.
    I also got 35mpg in my LL bean Outback a few months ago while on vacation. I'm assuming the gas pump was wildly inaccurate, because there's no way that could be real. I think I got a good deal on gas!
    Craig
  • twrxtwrx Member Posts: 647
    Yes 30 mpg is possible. I got it once on my 2002 WRX 5 speed wagon. It was a 250 mile trip on US highway 41 at 60 mph (Labor Day weekend 2002 and Ind.St. Police out in force).
    Don-
    Here are two of many orgs.
    http://www.nasaproracing.com/
    http://www.scca.com/
    Warranty issues. Not to my knowledge.
    I'll those who have participated longer than I have fill in the blank(s) on that :)
    -Dave
  • pathstar1pathstar1 Member Posts: 1,015
    Butting in here (I don't yet have a WRX but the WRX Sti is tempting me!!!). I have a 93 Mazda RX-7 (Competition Yellow Mica colour), and EVERYBODY seems to want to race me (mini vans, SUVs, etc)! I just realized the other day, some of them are just trying to get a better look at the car! I did the same in my Pathfinder one day when I spotted a Viper.
    I DO NOT race. No matter how much intimidation is attempted. People are killed racing, and you can't correct that with any amount of money or justification. There are some very dissapointed Mustang drivers around here.
  • himilerhimiler Member Posts: 1,209
    Those Mustang owners might be even more bummed if you did race them!
  • xcskierxcskier Member Posts: 34
    My best tank so far has been 29.4 mpg. I keep hoping to hit 30, but can't keep my foot light enough to achieve it. I think you could if you accelerated gently and shifted early (3000 rpms?).
    I usually get 24 - 28 mpg. My commute is 32 miles, almost all freeway. This is fairly spirited driving, moderate accelerations, and cruising speeds often approaching 80mph... just goin' with the flow!
    I have about 24000 miles on my wagon.
    My mileage improved noticeably when I switched back to summer tires in the spring and removed the ski rack from the roof.
    You know what the biggest problem is around here? NASCAR fans in pickup trucks with dual exhausts. As soon as I see a pickup with twin pipes and a racing number on the back window, I know it's trouble. These guys have a real attitude, either tailgating or trying to pass all the time. And heaven forbid if you want to pass them, they'll speed up.
    I can't stand those guys, and give them a wide berth. If I'm in the Outback, I just back way off. If I'm in the WRX, I pass them and get the heck away. Some of those trucks may be fast, but it's usually just exhaust rumble....
    Craig
    qbrozen wrote:
    &#147;You are, after all, talking about an activity that is about 90% driver. Maybe the rain scared them nonetheless or maybe they were just bad drivers. . .&#148;
    And hypov notes:
    &#147;At the end of the day, it all boils down to the Driver.&#148;
    I like the sound of this. <LOL!> Please. . . do continue!
    And jpnm wrote:
    &#147;If you are beginning autocrossing, chances are the people you were competing against were also.&#148;
    This is the Milwaukee Region, with lots of folks from Chicago and elsewhere competing. This is the Big Time, with numerous National Champions arising from this bunch. They&#146;re very serious, and very quick, make no mistake about it. Of the four WRXs I beat, three were S-Mod, and one was DS. I don&#146;t know about their experience, though. I should look that up.
    Our first event of the year had over 200 participants. Granted, there is a full range of experience levels, and I&#146;m unable to say anything about the WRX drivers in the most recent rain event, in the FWD Street Tire category (indexed, of course) that I ran in, apart from the winner, who was driving a WRX. And he won convincingly, with a remarkable margin of victory: 3.857 seconds raw time over another DS-classed car.
    (Maybe he&#146;ll permit me to ride along on one of his early runs in the future.)
    I did not win my class, you understand, I just faired better than I might have hoped. Many other FWD cars beat the WRXs, too. I was surprised that the other WRXs did so poorly, when I would have thought the AWD would be a major advantage. Apparently, it&#146;s not quite the advantage I imagined, at least not chasing cones in the wet.
    Actually, seeing the weather forecast the previous evening, I was hoping for rain. Rain can be a great equalizer, especially for us underpowered cars. Considering the outcome, I&#146;ll _pray_ for rain in the future. ;-)
    As a number of you have suggested, there are many possible explanations, not least of which is that I was running the OEM, skinny Michelins, which may have been to my advantage in the wet. Although, everyone was telling me that the Falkens, etc., do quite well in the wet, and should outperform my stock tires, so. . . I don&#146;t know what to make of it all.
    And jpnm graciously continues:
    &#147;So, the variance in driver skill was probably far greater than the variance in cars.&#148;
    This is excellent! This is an especially pleasant and agreeable interpretation of events. After a beer, or two, I happily drift off into a reverie, fancying myself to be Der Regenmeister! It&#146;s a wonderful world, filled with possibility.
    And emissaries from Enzo (Ferrari) will soon be entreating me to sign a contract for next season. Ah, yes. . . You see, Enzo always placed great store in a driver who was quick in the wet; it&#146;s likely that was the reason he hired Gilles (Villeneuve) to drive F1 straight out of Formula Atlantics. And. . . now there&#146;s ME(!), here I am, and, and. . .
    Oh.
    Sorry. I was doing it again, wasn&#146;t I?
    <sigh>
    My momentary success in the rain has gone to my head. Please, you mustn&#146;t encourage me. I&#146;m not well, my friends. ;-)
    But fear not. The next dry event should bring about an abrupt recovery, rudely awakening me from my foolish reveries.
    hpov wrote:
    &#147;Between the WRX and RS, the RS is the better choice chasing cones :D&#148;
    That&#146;s what I&#146;ve been wondering. Would most of you concur?
    I&#146;ve seen a number of folks suggesting that the Mini Cooper is a better autocrossing choice than the supercharged Cooper S, for example. That seems like a similar decision.
    I&#146;m thinking the RS, like the base Cooper, might be a bit lighter, and have more torque down low where it&#146;s really needed in this bizarre business of chasing cones in parking lots.
    hpov wrote:
    &#147;<<Hypov and I drive the same exact car at auto-x(same as in share the car) and often times One is near the top and the other is near the bottom of our run-class.>>
    Perfect example... I'm the other near the bottom :D&#148;
    <LOL!> I take your point! It&#146;s good to maintain a sense of humor in this business, don&#146;t you think? :-)
    So, tell me, does he talk to you? Does he tell you all of his secrets to getting around so quickly? I&#146;ll bet he doesn&#146;t. Not everything. Not The Truth, the Whole Truth, and nothing but The Truth. <heh>
    I ask because I&#146;ve noted a degree of reluctance in others to share much beyond general stuff. Everyone has been agreeable and friendly, willing to share and help --- up to a point. After that, they become more &#147;reticent,&#148; shall we say. :-)
    Last year, while a mere spectator, I asked a fellow, who was tweaking his tire pressures on his Integra Type R, what pressures he was running. He didn&#146;t want to tell me.
    Recently, we were walking the course with an experienced veteran who&#146;s also an instructor. He&#146;s a good fellow. I&#146;m asking questions, and at one point, walking the course, I stopped and asked about a potentially quick segment, &#147;How would _you_ get through here?&#148;
    He replied, &#147;As fast as I can!&#148;
    &#147;Geeze! It&#146;s only our third event. We&#146;re no threat. Throw us a bone!&#148; I complained. He still wouldn&#146;t tell us anything.
    A multi-time National Champion rode along with me on my first lap of my first event. I didn&#146;t know the course at all. (My 55-year-old brain is a sieve. It&#146;s a problem.) I was hoping for some navigation assistance, and some tips and tricks, you know? He was largely silent on my run, the &#147;silence&#148; punctuated by violent swearing from _me_ --- &#147;Excrement!&#148; (or something like that) --- as I blew past the wrong side of gates. I returned to the grid, and we sat silently for a moment. I said, &#147;Sorry about that.&#148; And he said to me, &#147;All _you_ need to do is learn the course.&#148; And he got out and walked away.
    I&#146;m thinking to myself, &#147;Ummm. . . Wait! Come back! I don&#146;t even know what happened! Help me!&#148; Maybe he didn&#146;t like my swearing. I dunno. ;-)
    However, at the recent rain event, I was watching as he unloaded his car from one of those enclosed, racecar haulers. (It had checkered-flag floor tile. &#147;Way cool!&#148; as the kids would say.) I asked him, &#147;Do you give Slow People rides?&#148; He agreed to take me along, which was nice of him. Alas, I was unable to take advantage of my opportunity since I was working Timing and Scoring during his heat, and then the event was terminated at midpoint because of the appalling conditions.
    It&#146;s all good fun.
    And grimly serious, too. :-)
    Thanks to paisan and mgreene1 for the useful URLs.
    With respect to warranty issues with Subaru, I wouldn&#146;t expect any problem, since Subaru _sponsors_ autocross events. Besides, as fast as it is, it&#146;s still not very hard on the car. High-speed, open track autocross events might be another matter.
    Speaking of which, I assume that&#146;s what&#146;s pictured on your website home page, isn&#146;t it, paisan? Did you notice the odd camber of the right rear wheel on the red Civic hatch, number 516, on your page? I&#146;ll bet if you &#147;looked&#148; at this from the other side of the car, you&#146;d see his left rear wheel is well clear of the ground! Just like the old Rabbits in the Bilstein Cup, etc.
    You&#146;re a pleasant lot in here; I like your generosity and optimism. I should visit more often! :-)
    Thanks to all, for your kindness, and for sharing your knowledge.
    -Kauai (who&#146;s contemplating Subies reigning in the rain :-)
    Tire Pressures: If you are running elevated tire pressures in the rain you will get less traction, the slow guys in that rungroup could have been running higher pressures
    Tires: R compounds in the cold/wet will be very ineffective compared to a hot sunny summer day.
    Class: An RS will likely do very well in G-class, where there is less competition than say D-class where the WRX runs. Same goes for Mini-Cooper v. Mini-Cooper S
    Auto-x is a game, to do well you need to know and use the rules to your advantage classing is one of those rules that can really help you out.
    Another factor is too-much power, I know several people who can't handle the power of a WRX and do better driving honda Civic Hatchbacks than their WRX due to the limiting of power that the hatchback has.
    -mike
    One other factor - a turbo is not a "good thing" (tm) in autocross. You need a smooth predictable power delivery, not one that comes on like gangbusters. A driver of a turbo car has to "use up" some of his skill and concentration to control the power curve. One reason my RX-7 is so difficult to drive in autocross' - though it is entertaining to drive a "tail happy" car!
  • WarpDriveWarpDrive Member Posts: 506
    The WRX's tall second gear makes it hard to drive in autox.
    RX7s win their classes easily out here. Turbos aren't in-themselves a bad thing for auto-x, it's a matter of keeping the revs in the right spot for a high-reving turbo. A low-pressure turbo like a lebaron for instance would have no problems at an auto-x IMHO.
    -mike
  • woodywwwoodyww Member Posts: 1,806
    A friend of mine is shopping for a new WRX in Northern VT. He wants: sedan, manual, short shifter, carbon fiber trim, upgraded stereo, & the 17" BBS rims. He's been quoted $700 off MSRP at a Suburu dealer up there. My questions are: can he do better than this price? Also, I'm trying to talk him into waiting for the 17" rims (the dealer wants $1700 for those), & getting the heated seats and sunroof instead. Any thoughts?
    They are telling him they can order the car for him for delivery in June. Any ideas about what options are essential, pricing, etc. would be appreciated!
    thanks, woody
    Excellent advice from all of you.
    Trying to use the rules to my best advantage is good advice, and is why I&#146;ve been asking these questions, of course. It&#146;s an interesting puzzle. What to buy, if the primary (but not only) concern is competitiveness in autox? There are a number of interesting choices beyond the two, apparently, obvious ones: Early 90&#146;s NA Toyota MR2 run in E Stock, and a Mini Cooper run in H Stock. What car, and then what mods, to run in what class? It&#146;s a real head-scratcher.
    Running lower tire pressures hadn&#146;t occurred to me; I&#146;d been told that higher pressures were better in the wet. I was running 48/38 F/R. Hmmm. . . I wonder how much quicker I might have been?
    You&#146;ve all been very helpful. Thanks; I appreciate it. :-)
  • freddyxfreddyx Member Posts: 1
    First, I love my REX! Does anybody know or have any idea of how many 03 WRX's were made??..
     Next, even tho I've only used the air cond. a couple of times, it really seems kinda weak in the cooling dept. Has anyone else came up with the same conclusion? Also, it REALLY does sap what little low end power we have,right?
     Thanks for your responses, & I look forward to more chatting with all of you!!
       Freddy
  • kevin111kevin111 Member Posts: 991
    Article in Grassroots Motorsports, Nov. 2002 does a comparison in dry and wet driving conditions (Auto-X simulation) of the WRX (AWD), the RSX-S (FWD), and the BMW 3-seris (RWD).
    They use the same exact tires (16"-205, BFGoodrich KDWS) at the same tire pressure. The WRX beat both cars in Dry and handily beat both cars in wet. They basically said that the WRX performed identical in wet as it did in dry, while the other two car's performance deteriorated slightly when performing in wet.
    FYI
    I've only had my WRX since January, and haven't needed to use the AC much yet. Surprisingly, it doesn't have as much impact on power as I thought it would, and seems to function fine. Seriously, though, ask me again in July and I might feel differently!
    When I was shopping for my WRX in January, the highest VINs were in the 10000-11000 range, so I know they made at least that many 03s. My WRX had a build date of 8/03 or 9/03 and was in the 5000-6000 VIN range if I remember right.
    Craig
    "My WRX had a build date of 8/03 or 9/03 and was in the 5000-6000 VIN range if I remember right."
    - I am impressed! How were you able to get a car from the future???
  • sensei1sensei1 Member Posts: 196
    C'mon give'm a break Kev.
    Here's a previous post from rexaroo on VIN.
    rexaroo Jun 18, 2002 5:40pm
    should be "8/02 or 9/02"
    I just peeked at the tag, it's a build date of 8/02, and the VIN ends in 057XY.
    Craig
    Driver is indeed the key. On a track day at Summit Point, an instructor was driving Mike Smith's Legacy wagon, and a frustrated Ferrari driver has to wave him by.
    -juice
  • cinosweivecinosweive Member Posts: 166
    I was looking to buy a Yakima bike rack for the roof of my wagon. I remember some folks here some time ago were recommending mounting the bike tray on the outside of the rails so bikes on the rack wouldn't interfere with opening the tailgate.
    Has anyone here tried this? If so, will the recommended 48" crossbars work or do you have to buy longer crossbars?
    Worked on Sunday! :-(
  • dcm61dcm61 Member Posts: 1,567
    FWIW, I have 48" Yak crossbars with double cross mounts on my Legacy Outback and I have mounted the trays outside with no problems.
    DaveM
  • bluesubiebluesubie Member Posts: 3,497
    Steve - There are only one or two '04 owner's here so I'm not sure what the 04's are going for.
    Some people like to have the cost of the wheels rolled into the financing of the car. Others (like myself) would rather save a little money and get different wheels. I bought Prodrive wheels (OEM in the UK) and paid $836 for the set. Subaru-parts.com sells the $1,700 wheels for $1,400 shipped.
    I really wish that the '03's had the All Weather Package. Heated side view mirrors are great for clearing ice and even drying up rain.
    -Dennis
    Then they're not really $1700 wheels! ;-)
    The Legacy wagon is getting a big moonroof and more power, so it might steal away some WRX wagon sales.
    -juice
    Right now, to get an 04 sedan with the premium package (sunroof and winter package), you are paying very close to MSRP. That's if you can find one. If you want an 04 sedan (or wagon) without the premium package, you can get a much better deal.
    I wanted a red sedan with the Premium package. I got one, but I paid :)
  • dallan1dallan1 Member Posts: 8
    Actually, for a black 04 sedan with premium package, I was quoted invoice at 2 dealerships. In the MD area, there is a dealer that has displays their inventory online, and their internet price for 04 WRXs are invoice. I printed out a copy, went to another dealer close to me, and they said that they'll honor that price ($25104 with destination, black 04 sedan, prem package with titanium shift knob, short throw shifter, and turbo gauge). All I have to do is get my down payment together and sell my car to Carmax (I'll get a better deal for my trade in from them, from what I hear).
    Where did you get such a good deal on the wheels?
    I really like the optional 5-spoke 17" OEM wheels, but they're around $1300 a set at most discount parts sites. Add another $600 for decent tires and that's a lot of $$.
    Craig
    Craig,
    It was the very last set of 17" P1's that the Tire Rack had. They were selling P1's for $209 each and P7's for ~$180.
    -Dennis
    What are the names of the dealerships selling O4 WRX's for invoice?
    The MD dealer selling 04 WRXs at invoice is Fitzgerald Auto Mall, http://www.fitzmall.com/index.asp
    Search for their Subaru Inventory, and filter the results with 'body'. The WRXs should be at the end, and they're at invoice. They are selling STIs at MSRP too. I'm not sure how good their service is, but its a good bargaining chip for dealers in the MD area. The other dealer (Heritage Subaru, not too fond of their service though) said they'd honor that price, but I'll find out in 2 weeks if they're telling the truth.
