Toyota Sequoia vs Chevy Suburban, Chevy Tahoe, GMC Yukon XL
I am looking to buy a new SUV next month and I am considering the Seqouia,I am not to fond of the current Land Cruiser styling and the Seqouia is larger which I like. I will also be pricing a 2500 4 wheel drive Suburban. Tuff decissions.
That's an easy one to answer. It has to do with production capacity. GM adopted Just-In-Time (JIT) practices from Toyota and were able to significantly reduce their overhead costs, mainly in the way of inventory for the production line. Parts are now delivered as they are needed. Plus GM's purchasing division is notorious for getting rock-botton transportation costs.
Also consider that GM is the largest vehicle manufacturer in the world. This allows GM to offer the higher incentives and cash back values. To make up that lost revenue, GM just has to sell a few more vehicles to offset the cost. It's called a Break Even Sales Point. While GM is till losing some revenue with the higher incentives, ther're able to recoup much more of it than the other manufacturer.
It due to GM having a lower Break Even point that will enable GM to lead the "incentive war" and come out on top. Just take any Pricing Course and you'll see what I'm talking about.
My brothers Expedition was similar. $42K new, $15K 4 years and 75K miles later.
As they say, "you pays your money and you's take your choice"!
2004 Initial Quality Study
On my wife's Explorer, I've changed the brakes myself and have had to replace the rotors each time. Fords are especially notorious for running undersized rotos and brake pads. I see a trend on most domestics to go with smaller rotors versurs larger ones like on European imports. It boils down to simple physics, the more mass your vehicle has, the more momentum is has, the more heat generated and the harder it is still stop. Common sense should bear out that full-size SUV's should have at minimum 10 inch rotors all the way around. Or at least vented rotors for improved heat dispersion.
But resale value? It's not really a consideration for when I purchase a vehicle. I look strictly at reliability and ease of maintenance (can I work on the vehicle myself). Plus my overall impression with the vehicle after test driving. I'm a grease monkey at heart and don't mind doing my own automotive work as long as I have the time and know-how. But I have to concede, Toyota's quality outpaces domestic standards. That's what you get by going over to a "Lego" built vehicle with very little variations. GM is definitely heading that way (like Toyota) on their production line. Sooner or later GM will catch up, which will drive the other domestics to follow suit. And that means a better end roduct for all us consumers. But that's my opinion based on much academic research as a Quality guru.
Observations:
Sequoia:
Pros:
- Great fit and finish
- Quality interior materials
- Quiet motor
- More room behind third seat than Yukon
- Third seats slide back and forth to add room
Cons:
- Needs more power, a lot more power!
- Very large turning radius
- Poor visibility out the back
- Dives into turns like a 65 Buick
- Second row seats do not fold flat to the floor, only flip up. Then you must manually secure in place with a strap
- Third row seats very heavy and difficult to remove
- Rear power window requires that you either have the keyfob in hand or roll down using the button prior to accessing.
- Feature set less than would expect for this vehicle
- Experienced terrible mileage (usually 12.5 to 13.0) in town.
Yukon
Pros
- Good power and pulls trailers well
- Many features such as XM radio that are not available on Sequoia
- Tight turning radius
- Great visibility
- Good highway manners and very quiet
- Seats fold flat very easy, with headrests moving out of the way automatically.
- Third row easy to remove.
- Average of 15 mpg in town
Cons
- Interior/exterior fit and finish is pathetic, I mean patheetic.
- Interior materials not up to par with Sequoia
- Not as good resale value as Sequoia
We decided not to have the third child, and when deciding on which vehicle to keep, we chose the Yukon and traded the Sequoia.
Milage is a minor price to pay for engine reliability. Plus with kids you may see the shoddy interior of the Yukon detroiate faster that the seq.
However I understand that fold down second seat issue and the difficult third row of seats to take out. I don't do either very much so it was not a factor in my decision.
You can also use the key in the lock in the rear door to roll the window down! What other "back window down options" do you want?
I use large fish eye mirrors on both sides and it gives me perfect visibility.
I would prefer that the seq had the dissapering seat feature and easier to remove third row feature.
Good luck with your new vehicle, I hope yours is one that stands up to the test of time. I do like the way it looks!!!
http://www.fueleconomy.gov/feg/findacar.htm
Let's take a look at the # of TSBs issued by GM and Toyo for model years '03/'04:
2003: Toyo issued 6 TSBs, GMC issued 112
2004 (so far): Toyo issued 3 TSBs, GMC issued 64 TSBs
Just look that the numbers. Toyo has issued 9 total TSBs for the Sequoia and GMC has issued 176 TSBs!!!
Personally, I weigh data like this much more heavily than I do for JD Power's customer satisfaction survey.
This link only shows 3 TSBs for the 2004 model. If you've got a more updated link, I'd appreciate it!
2004 Toyo Sequoia (dates from 8/19/03 to 5/31/04): 6 TSBs
2003 Toyo Sequoia (dates from 3/05/03 to 5/31/04): 16 TSBs
2004 GMC Yukon (dates from 1/01/03 to 1/01/04): 104 TSBs
2003 GMC Yukon (dates from 5/01/02 to 1/01/04): 166 TSBs
2004 Chevy Tahoe (dates from 1/01/03 to 1/01/04): 101 TSBs
2003 Chevy Tahoe (dates from 1/01/02 to 1/01/04): 157 TSBs
Whether or not one of the two sites that I've quoted are 100% correct, I think gkatz1 and I do agree in theory that the Toyota's dependability, as compared to the GMC and their variants, is far superior.
With the GMCs you can save about 10% off of the Sequoia's price tag, but then you have to deal with 10 times or more the amount of problems with it. To me it's a no-brainer.
We now have 24K miles on our Suburban and not a single problem yet... in spite of hundreds of TSBs. I personally would still tend to believe that Toyota has an edge over GMC in terms of quality, but IMO the difference is not material and certainly doesn't justify the premium if otherwise GMC has a more capable, better looking and feature laden vehicle. While of course looks are subjective, as to capability (greater towing capacity even with base powertrain, more cargo capacity, more power even with base engine) and available features (XM radio, programmable driver center w/trip computer, memory seats, etc., tri-zone climate control, 2nd row captains chairs, OnStar, nav system (on Denali), Autoride suspension, etc.), Suburban/YXL has the Sequoia beat easily.
Besides, as I've mentioned before, the Suburban/YXL/Escalade are in a class alone in terms of ability to carry 6+ passengers and cargo... for those of us with such needs, there is no comparison.
For both vehicles the consumer scores are comparable (9.0 for Tahoe/Yukon and 9.1 for Sequoia).
I'm confused about the editor's score being lower for their first choice vehicle; but, even more than that, I'm confused about the biggest pros and cons of the two.
Finally, I keep hearing that people who have owned Suburbans and Lincolns are VERY faithful owners and "get addicted" to their vehicles. I've talked to some of them and they seem almost sheepish about their need to continue to owning these trucks. But they love them. So, they are on my list, too.
HELP !! Thanks!
http://www.thecarconnection.com/index.asp?n=178&sid=178&a- rticle=7703
Some people are saying these are '06s, others say '07s. Not sure.
Anyone know why ??? Could it be a design artifact, for aestethics, or safety-related ???
My Sequoia, like 99.99% of all SUV's, have all doors in almost similar sizes, except those from GM.... Perplexing ! Do owners not wish the doors were larger ? Just wondering.
Happy Turkey Day everyone....
I love the room and power that the suburban have. But are the newer model suburbans have the capability of surpassing the 100k mark without any mayor problem?
Would it be better to get a 2500 model in order to get the same performance and maybe longer life span?
You input would greatly be appreciated.
Buy what you LIKE !
If its the 'Burb, go for it. If the Seq appeals to you bcos of its Toyota heritage, then go for it as well. You do not want to buy one and look longingly at the other choice every time you drive past one.
Maybe more importantly, what does the WIFE want ?
Good luck !
Could not decide between Tahoe - Suburban - Sequoia. At first it seemed like the Suburban was a little too big - the Tahoe was a little too small and the Sequoia was just right.
We test drove each a few times and cut the choice down to Tahoe VS Sequoia. The pricing difference pushed me to the Tahoe.
I can't recall the exact difference - but it was well over $5K - the Sequoia was new and I could not get any dealer to give me any significant discount.
If you really like both - I would work with both dealerships - see what the best deal you can get on each truck - then ask yourself - is this truck worth $XXX more?
If the price would have been the same (or close)I would most likely be driving a Sequoia - but no way did I see a $5K difference - new model or not.
Power Steering Pump
Fuel Pump
Intake Gasket
Transmission
Exhaust (this was not necessary, but the glass packs sure do sound good)
My two pence. The Suburban is my kind of vehicle, would not own a Toyota at all (unless it was given to me).
-DeaconLew
99 K1500 Suburban Red (Like the blood of Jesus)
350, K&N, Dual Exhaust w/ Glass Packs
Husband and father of five
should be left out. Gas much higher now, and both Seq and Tahoe are now
heavily discounted.
I purchaed a 2002 sub, and my friend purchased a 2002 seq limited. I have
had to pick my friend up at the Toyota dealer 4 times so far, and he has never
had to get me. My sub has not broken yet.
The seq has been recalled twice now, and just this year Toyota has had
to recall 2.6 million vehicles, just recently the hybrid car.
So in my opinion both are very close in equality, get the best deal, and buy
the best deal, because as soon as you drive it off the dealer lot, you just
lost at least 10 grand $$$.
Even the Chevy dealer can't give me the answer.
While installing a brake controller for my RV, I LOST the nut that goes to the fuse box inside the engine compartment, and can't find a replacement.
On the fuse box in the engine compartment, (facing the steering wheel), there are two power poles standing straight up and a bolt that shoots out to the fender (parallel to the ground) where lots of red wires are connected. The nut that tightens on to that bolt that shoots out from the fuse box toward the fender (parallel to the ground) got lost, and the Chevy dealer has no idea what size or replacement I would get.
Right now, I have the cables (which when not connected the car will not start) pressed against the bolt, so the car works, but this is dangerous -- if the connection comes loose the car will die!
All I need is the actual size of the nut that turns on to this bolt and perhaps where I can find it.
It is uncanny that a single 1 penny nut is causing so much problem!
Thanks in advance.
Nathan
Any suggestions would be greatly appreciated.
2006 Tahoe is a brand new model with new exterior/interior styling; more engine configurations with a hybrid coming out soon.
2006 Tundra was just introduced at I believe the Chicago auto show so the "new" model Sequoia would be following not too long after the Tundra starts rolling off the assembly line. Of course, the Tundra/Sequoia is completely redesigned with a new engine as well. Toyota is talking about a hybrid for the Tundra/Sequoia.
I guess the relevant question would be; what is your time frame for purchasing/leasing?
Additionally, Toyota will have a higher resale value even though it is more "pricey."
BTW, just for reference, I owned a Tahoe (2000) before buying an 04' Sequoia. Gotta love the power in the Chevy but after 60k miles and it starting to have problems I got rid of it quick and bought the Toyota. Got about 30k on the Toyo and so far it is flawless.
Hope this helps.
The new 2007 Suburbans are coming to the dealers around April or May and I can tell you I WILL be going back to the SUBURBAN. My take on the Sequoia is that it is HIGHLY OVERRATED AND HIGHLY OVER PRICED. No wonder the Sequoia is said to have a higher trade in value. It's OVER PRICED to begin with. My 03 Burb had many,many, more bells and whistles for much less money($3000 less MSRP) than my Sequoia has. My advice is go for the all new 2007 Suburban as that is exactly what I am going to do. I have owned my first and last Toyota guaranteed! For me its Suburban all the way. After all the Suburban was the first and is the Granddaddy of all the SUVs, as we know them, today. Take notice as to what the U.S. Government is using....Suburbans!!
The key is to get a good hitch set up and dial in the trailer breaks (recommend cam anti-sway control and load equalizer bars). Temps were in the 90's pulling extended grades of 6% at altitude and never had the temp budge. I know alot of people will argue to NEVER exceed weight limits. I am very conservative and never felt overloaded, unsafe or white knuckled. I guess I don't necessarily buy into attorney and lawsuit driven national paranoia of guard rails everywhere and coffee labeled hot.
Having owned a Tahoe and now a Sequoia I thought you might be interested to know that according to Edmunds TMV pricing-
2007 Burb LT 1500 4WD w/ LTZ package & Navigation is $48,267.
2006 Sequoia Limited 4WD w/ Navi is $40,700.
And you were saying? Almost 8K more and in a couple of years the Sequoia will still have a higher resale than the Chevy. Heck, it will most likely outlast it too.
"Take notice as to what the U.S. Government is using....Suburbans!!"
Yes, they are cheap and expendable. :P
