New VW Golf Uses A LOT of Oil
Help Anyone,
I just bought a new VW Golf base model. In my first 5 months and 5000 miles, I have had to put in almost 4 quarts of oil. I am very distressed. My 1974 Pinto didn't even use this much oil. Here is the funny part.
Does anyone believe this from the VW dealer?:
The service manager told me that this is perfectly normal for the Volkswagen engines, particularly the Golf.
*** Is that true or is he pulling my leg?***
Thanks for any advice.
Bruce
Bruce
Some things to keep in mind.
1 oil consumption will drop once the engine is broken in. Should be by now.
2 Might try mobil 1 oil. Conventional oils have more tendancy to Burn up (for lack of a better word)
3 make sure you check oil on perfectly level ground. The crown of the road mades a .6 qt diff on one of my vehicles.
I would change the oil now with Mobil 1 (or any synthetic oil) and check to see if consumption is any better.
Other than this issue, I really do think that the Golf is a terrific little car. After my last VW, an 85 Jetta that leaked water into the driver's side floor everytime it rained (among other things), I said I'd never buy another Volkswagon again. But I did, and now I'm starting to have familiar worries.
Wrote owner of dealership a week ago and told him that when I bring it in next, he can keep for as many weeks or months that is necessary to make the problem go away. He has yet to reply. It ticks me off because I have a 1998 Grand Caravan. Granted, it is a much different vehicle with no sporting pretensions. Nevertheless, in 42,000 miles, I have never added any oil to it. Needless to say, this grinds me to no end. Anyone out there with any comfort?
If the oil consumption continues to deteriorate, you will reach a point during warranty when it will be "bad enough". If it stays at a quart every 1,000, that's what you'll have to live with. I myself wouldn't be alarmed at this consumption, but if it drops to 600 miles a quart, they'd better fix it or you'd better figure out how to blow it up before the warranty runs out.
What year model?
From what I understand if it's diesel engine then that's normal to eat oil a lot (to compensate for better gas mileage) otherwise it's a concern.
Thanks in advance.
I'm going to look into Texas's Lemon Laws and continue researching. Worried about Catalytic Converter when burning that much oil.
Al
I know oil consumption on new cars is pretty common...at least a little bit. My father bought a new 2000 4Runner, and even it has consumed about 5 quarts of oil (in 30,000). Toyota is (in my opinion) probably one of the best built cars in the world. If a Toyota does it, shouldn't it be ok? Please advise!! Thanks!
Sean Spurlock
People really need to get it out of their heads that oil consumption per se means there is a problem. It doesn't.
By holding your lease payments hostage, you will ruin your credit!
And Mr. Shiftright is, as usual, correct.
ALL engines use some oil. They have to. We have become spoiled by cars that will go 5000 miles without having to add oil.
I think German engines may be looser. Our BMW used to burn a quart about every 1500 miles. This was not a big deal, just a function of the car.
Years ago, I remember a Chevrolet dealer telling a customer that anything over 800 miles per quart was acceptable.
I should probably be more vigilant with my Hondas. I rarely check my oil until it's time to change at 3500-4000 miles. The oil is always on or nearly on the full line. If they ever start using oil (unlikely) I could have a problem!
any comments on this, Also was told that Subaru's consume oil any one have this experience since i am thinkin of buyin a 2002 WRX.
The 1975s were eventually recalled by the EPA because of excessive hydrocarbon emissions -- too much oil was being burned. The fix was new valve stem seals.
the laws regarding revolving credit and leasing/simple interest loans are completely different... you have protection when you purchase items on your credit card (which vary dependent on how far from your home address the merchant is).... a lease/simple interest loan is a completely different story...
and i REALLY doubt you've called your credit card issuer "often" and still are with that issuer... we used to create neat little reports with people who did that and we most of the time chose not to re-issue to them....
-Chris
So, if you really have a bad oil consumption problem (I agree with others on this thread that some oil consumption in and of itself is not a bad thing), putting your problems in writing and insisting on a proactive solution could get your dealer's attention. Now, as long as this next engine is o.k. . . .
