FWIW, as I understand it, Chrysler "upgraded" the clutches in the 2007 transmissions to some sort of a Kevlar composite that is far more robust than previous versions of the clutches, however, they apparently have a different coefficient of friction and that is what is causing the problem.
Keep us posted.
Best Regards,
Shipo
Papers are signed, just waiting for the hearing.
Best Regards,
Shipo
Does anyone know if the lifetime warranty will cover computer updates?
...keep up on your tranny flushes (every 30k miles). Don't xpect your vehicle to do something it's not designed to do and then when you've ignored that advise, don't go blaming Chrysler for the tranny blowing out when you've clearly abused it.
Interesting advice. Per the manual for our 2003 DGC ES, a manual written by Chrysler that recommends (among other things) the proper care and feeding of our van; the transmission fluid NEVER needs to be changed. I'm quite happy to say that I've adhered to that rigorous maintenance schedule on our 2003 and so far at least, the transmission seems to be quite happy, of course it only has 102,000 miles on it so there's still plenty of time yet for it to go Tango Uniform. :P
Best Regards,
Shipo
Best regaurds
Brokenspoke
Uhhh, "Say what?" If you check the language of the "Lifetime Warranty" offer you'll see that it clearly states that all new/unsold 2006 and 2007 vehicles as fo 26-Jul-2007 get the warranty, period, full stop, the end. In addition, Chrysler announced that owners of some (most?) 2006 and most (all?) 2007 vehicles could purchase the warranty for a nominal fee of $750 (with a $100 deductable) or $900 for no deductable through late September, after which the price doubles, and therein is the basis for my statement about the OP being lied to.
Best Regards,
Shipo
thanks jay.
My experience has been chrysler dealers first response to any warranty problem is to blame the customer in some way, until they change there ways they will continue to lose market share.
Best regards
Brokenspoke
Some had previously said it fixed the problem (simidave), some said it improved but not completely fixed (tom166). What about issy and izzy5, did it fix yours. I am asking because it didn't fix mine. It was a lot better after the update, but it gets worst with time. The manufacturer is trying to make me feel as though I am the only one out there for which it didn't work. Here was their response : It has been our experience that the bulletin service, properly completed, has been very successful in bringing the symptoms as described to a satisfactory conclusion . So could you give an update on your transmission so I can see if I am really alone in this? Thanks
Brokenspoke
The total operation of any vehicle is subjective in nature which would result in differences of opinion.
You may bug them until they fix it, but I'm warning you, I was already told by the dealership that they can't do anything more than what the sofware update did.
I have my CAMVAP hearing on next Monday. I'll let you know what the arbitrator had to say.
It might be mentioned that a lot of owners use a 7-pin to 5-pin adapters when towing their boats on trailers with brakes. These trailers typically handle no more than 3,000 pounds.
That said, I still wouldn't recommend a T&C for towing a boat. Since AWD is no longer an option (after Sto 'n Go was introduced), one shouldn't count on front wheel drive to pull a boat out of a public access going uphill on a wet ramp.
Immediately afterwards the Van "jerks" when slowing down to around 28 mph after being in the 4th Gear at about 40 mph. We never had this problem before. What might have caused this problem to suddenly start and is there an adjustment to the AT that could correct without a major tear-down/ repair?
Be nervous, be very nervous. Your transmission does NOT call for a fluid service of any kind, regardless of mileage (unless you're towing, I think). A few questions spring to mind:
- What caused you to opt for this service in the first place?
- Why did you opt for a "flush" instead of a pan drop, filter replacement, and top-off type of service?
- While your transmission may well have been refilled with ATF+4, what was it flushed with?
- Who did the work, a dealer, a Jiffy Boob, an Indy shop?
I'm thinking that the first thing that I'd do would be to swap out the filter and top the transmission off again. Drive it a few thousand miles, pump out as much fluid as you can and top it off once again.
Best Regards,
Shipo
1) It is true that the 41TE transmission in late model minivans need to learn and adapt to the driving style of the main driver, in fact, this has been true since that transmission was first brought out nearly twenty years ago. That said, due to the nature of the heavier duty clutch material that is used in the 2007 and later transmissions, it seems that they take longer to adapt to the driver, even after the firmware has been upgraded.
2) Honda has had a significant issue with their transmissions as well (some say they've been corrected, some say otherwise), so if you're going to buy Honda, be prepared to deal with tranny problems as well. FWIW, every Odyssey in our neighborhood (all three of them) has required a new transmission, one of them twice (and the second one wasn't covered under the secret extended warranty, that was an ouch to the tune of $4,500).
Best Regards,
Shipo
buying a honda may not be the answer but it probably would be better to buy from a company in better financial shape that can afford to stand behind their products.
Best regards
Brokenspoke
For all the hoopla I believe Chrysler builds a better minivan transmission than Honda, about as good as Toyota does. GM probably builds a better one than any of them but they aren't in the minivan business anymore. I am currently at 174,xxx on my original Chrysler transmission and it is going strong. Flush it every 60K and that is it.
I don't understand why all the companies have transmission problems yet only the American companies get blasted for it. When an American transmission fails its "I'll never buy from this company again". When a [non-permissible content removed] transmission fails its "Oh well at least it was better than an American car".
Any help would be greatly appreciated.
The problem seems to be a consistent one so I thought the answer might be also. Thanks.
How did the transmission act? Were you getting hard shift between 0 and 20 or a hard shift as you were coming to a stop. Hope the new transmison works for you. I was told that if they replaced mine I would still have the problem. Good luck!
Your feedback is greatly appreciated!
Happy New Year!
By the way, the car has a "hesitate" start for over one year, especially in the cold days in NJ. When we started the engine, it almost does not move, like in neutral gear, after step heavily over the gas panel for several times, it finally moves. after running over 10 minutes or so, this problem will go away.
