Visitor Agreement.
I would like to be included in the Tech Center tour Friday the 19th and if possible I would like to try to join you for the cruise up (or down) Woodward and at the dinner at Copper Canyon. I've eaten there before and it is a very nice place with a nice atmosphere. At this point it will have to be just me as my wife has prior commitments. What do you need from me to make this happen? Looking forward to meeting other 300M lovers.
Scott
; I have a 2000 300 and lately when I start it up, or put it into park the rpm's go up to 1800 and stay there.
That's a loaded question. Many, many things could cause this problem. Could be a very dirty air filter, a bad oxygen sensor, or a problem, mechanical or electrical, with the AIS system (AIS=Automatic Idle system). If you have access to a diagnostic machine hook it up to your OBD plug under the dash and check for trouble codes. Good luck.
Scott
Can't wait.
Scott
I should have proof read my post. AIS = Automatic Idle SPEED not system. It's a little motor and valve that controls the idle speed. I had one go bad on a 86 GTS and it would sometimes idle down the road at 35 mph.
Scott
Scott
I traded my '99 Platinum M in late December for an '05 TL (great car). It had 67,000 miles and was relatively trouble free, but after 5.5 years I was itching for something new. While I still miss the M, I'm really diggin' my Zaino'd Abyss Blue TL and would recommend it to any 300Mers who are looking for a suitable replacement.
Oh, yeah. If you decide to trade your M in (at a non-Chrysler dealer) don't expect them to love the M as much as we did! I almost kept the M after three different trade-in offers were even lower than I expected.
I see on the 300 Club board that you are listing me as scott1096, it's scott1094. That comes from my first ten second run in my old 70 Dudter 340 at Milan Dragway. I am still a go for the Auburn Hills briefing and the cruise on Saturday meeting at your hotel before 9 a.m. I expect that I will join the 300 club when I meet with you guys or would that be wrong?
We have the Central Gratiot Cruise this weekend then a week off to prepare for Woodward. Just finished the Telegraph Cruise and we still have the North Gratiot and the Harper Cruise to go.
Scott
Regards.
Donald
Friday which should be interesting. Then after we cruise Woodward on Saturday, we will be heading up to the 300 plant in Brampton, Ontario on Sunday for a plant tour on Monday. Wish you could all be there for this great event. This is the 5th year 300M'ers have been going to the Cruise,and it will probably be the best with the Auburn Hills briefing. I will post a report after the Cruise. :shades:
http://carfiche.com/manuals006/2004_chrysler_300m.zip
2004 300M, Concorde and Intrepid
Technical Publications
Supplement to be used with 2003 Body Diagnostic
I had nearly the same outside temp reading problem (bought new 300m in 2004).
I've changed overhead unit (C/T) and now the reading of outside temp is 2 or 3 degrees C higher than the real one (compared to test readings from other thermometers). Any solution? Can I somehow calibrate temp readout by myself? (It would have to be lowered for 2 or 3 degrees C).
Is it possible that just temperature sensor is malfunctioned?
I simply can not believe that the cheapest digital thermometer from Taiwan works accurately to 0.1 degree and thermometer in my 40 k$ worth Chrysler is just giving me a bad impression about outside temperature.
I'll try anyway just to replace at least the sensor and than I'll inform you what happened.
BTW, does anybody regret that 300m is not produced anymore or you find a new c300 as fair replacement for excellent 300m?
(I really enjoy driving my 300m in Europe, where Audis, BMWs and Mercedeses are dominating; it's nice to leave them behind; they simply don't know what struck them ;-) )
Here we go: First, I was driving on the highway, pushing about 75 mph and car suddenly dies, no warning signs, no check engine light, nothing, car just died. The car wouldn't start. I left the car in a road side rest area and came back 2 days later and the car popped right off.
The car ran fine for about a month then I started having problems with the car not wanting to start. I had the starter replaced and we thought this fixed the problem...Wrong. We're still having car start problems. Now when we try to start it makes a loud "clunking" sound, like something is grinding when we try to start it, along with a clicking sound, almost the same sound we had before replacing the starter.
I am really starting to hate this car. Here is my question. Is there any way the factory installed alarm could be causing my problems or is there some deep rooted problem I need to look at?
If it's both, it sort of sounds like you have some broken teeth on your flywheel. But that wouldn't explain why it would start right up a couple of days later, not to mention the chances of that happening are astronomically remote. :confuse: The clicking sound you mention definitely sounds like a starter and/or battery issue. I'd have the battery and all the cables checked; especially the power cable going to the starter. I'd also have them check the starter relay.
However, since you say it stopped cold on you while driving, there's more than likely a problem with your ignition. Have your ignition and it's relays checked and/or replaced and it will probably be good as new. The ignition may be overheating and tripping the relay. Have you ever noticed that your key is hot sometimes after you've driven the car?
I'm thinking of taking off my 18 inch Special wheels and putting on 17" razorstars. My goal is less noise/harshness at hwy speeds, a better look with the chromies, possibly better gas mileage, less stress on the suspension parts, cheaper replacement tires when the present ones wear out and a wider selection of tire brands
Loving my new Black 2002 Special.
EZ
On my 2000 silver M, m y first set of razorstars leaked air quite a bit (didn't notice any corrosion) when I was using the Yokohama tires. I thought it was the wheels, but maybe it was the valves or tires. They may have been ok with a bead sealer but I got a great deal on a practically new set of razors so I went with them and no more problems.
What do you think of razorstars on a Special.
This was combined with starting problems. When I attempted to start car, there was silence, as if no electrical connection. I found out by mistake, that if I turned the radio on, or lights on the connection would be made and the car would start.
This has improved as the temperature has become much cooler, and it doesn't happen that often any more.
ANY THOUGHTS AND COMMENTS OUT THERE, BASED ON YOUR PAST EXPERIENCE???
It's also possible you a have a loose or dirty connection at the battery. Check it for corrosion and if necessary, remove battery cable from the battery and clean it.
Dealer, says there there are no service bulletins on the problem.
I have seen the inside dash gauges flash once. They go completely out when they did this so I know it's not just a dimmer switch issue. I'll get a rebuilt Body Control Module (which I am told is under the dash) if it continues to be a problem.
I'll get some Rubber Black and wipe the seals around the windows so that doesn;t burn their motors out. I'll ignore the rubber around the headlights. I also noticed the headlights are pointed just a tad low (probably normal). In these days of giant SUV's blaring their headlights in your car I certainly won't mind re-aiming these just a tad higher (adjust them up just a few inchs while pointing at a wall, then try them by parking about 20' behind another car on a flat surface to ensure they don't point into that car). This headlight re-aiming tip works makes a HUGE difference most of the time.
For the $12,500 I have into it I hope it lasts another 100k!
Hal
http://public.fotki.com/Scotian/300m/lighting/hids/
http://public.fotki.com/Scotian/300m/lighting/projector_foglights/
I still have a vibrating growl noise at low speed, particularly when first accelerating in the morning. It sounds like a loose heat shield, but maybe it's the belt. The dealership said that my catalytic converters are rattling, but I don't know if that means anything.
October '05 Scotian wants a two seater convertible roadster next year to complement the 300M. We'll see what April '06 Scotian feels about that. Morning Scotian is known to often be upset at Evening Scotian, so there may be some disagreement...
ROFL!!!!!! :P
