I just checked an Toyota parts place on the internet, and Sienna rotors go for $80 each, with new pads being $42. For an automotive tech to
a) Put your van on the lift b) Pop off the front wheels c) Remove the caliper bolts d) Pull off old rotors, put on new ones e) Compress brake cylinder, install new pads f) Put it all back together again g) Road test
So your talking about $200 worth of parts, and 2 hours labor (being reaaaallly generous). Shouldn't cost more than $350 for all new front brakes.
Anyway, I had a problem with warped brake rotors on my '01 Accord. The Honda dealer resurfaced the rotors, and it was covered under the warranty. I would think the same would apply for Toyotas as well.
Brake rotor warpage is caused by three things:
1) Auto repair shop monkeys overtightening your wheel lug nuts.
2) Driving thru puddles with hot brakes
3) Sustained aggressive braking.
#1 is the most common cause of brake rotor warping. Whenever you have yout tires rotated, make sure the technician uses a torque wrench to tighten your lug nuts.
Hi! I have a 2001 Toyota Sienna XLE. While everyone else is on the subject, I figured this would be the best time to ask my question about my brakes. Ever since around the 5000 mile service, we have noticed a squeal from the brakes when they are depressed and the vehicle is almost at a complete stop. The problem is still around and we have put on 30,000 miles now. We've taken it to the dealer several times and they keep reporting that everything is fine. I don't know that many owners with Siennas but the ones I do all have the same problem. Though the brakes seem to work fine and perfectly (brake-avoided an accident last week :-)), I expected better from a $30K+ car. Is this a common problem on Siennas? Or is it just my friends and I?
But sometimes I also get dirty looks for it : ( and by the way the person just infront of me tries to keep more distance than me which is good for me ! : )
I haven't read about this problem yet. You know when you change gears, each gear on the dashboard lights up ie. the "P" for park light, then "R" for reverse. Well, today I noticed that the "D" for drive doesn't light up anymore.
Does anyone know what is involved with fixing this? Is it complicated, or is it something I can do myself? I also have something, like a loose screw, rolling around somewhere in my dash area, so I'd like to find it. Drives me crazy every time I make a turn.
Is there an online manual, perhaps, that might aid me in removing the dashboard?
My wife just got back from a Girl Scout camping trip and I noticed that something hit the rear wiper and now the base is bent away from the rear of the van and doesn't work anymore. Has anyone replaced the rear wiper assembly? How much is it and can it be replaced easily or should the shop do it? Thanks.
Whenever I take the '98 Sienna on a long distance drive I experience the bottoming out in the rear suspension. Now I do not tow a trailer but have luggage and 4 passengers...certainly not at full load. When I drive over a bump it bottoms out. I can prevent this by having a set of rear air bags installed in between the springs. What other alternatives have Sienna owners done . I am open to replacing the spring or struts as an alternative to using an air-bag. Those that have done the 'air-bag' out here in the Rockies have said this has cured the problem, especially for swaying and bottoming out.
Having Break Squeal on the older model year Sienna(especially '98) is common. I thought they had fixed this for the 2000 model yr but I guess not. After every brake inspection my dealer adjusts them, or does whatever to prevent the squeal. It comes back however before the subsequent service. Sonow its become a line item on each of my service visits to stop the squeak.
I have been really happy otherwise with the brakes on the vehicle. I had both the front rotors replaced as part of a Toyota Service bulletin for my '98 Sienna, years ago now. Since then the rotors have behaved themselves. The new rotors do not warp and when I brake hard it works as expected.
I got Costco Michelins (X Radial Plus) for my Quest around 45,000 miles ago. They were great the first two years, but now I'm thinking I should have gone for a tad more performance and less treadwear. They are just all season tires, but the good snow traction they initially had pretty much disappeared after the second winter.
This spring excepted, it usually doesn't rain much around here so that's not a big concern. I just have this niggling feeling that I could have spent a bit less and planned on new tires in ~3 years and enjoyed the ride a bit longer. The X-One clones are showing plenty of tread still so it's hard to justify dumping them just yet.
Or maybe I've just been reading about "performance" tires too much over in Tires, tires, tires :-)
My '98 Sienna LE came with those soft Dunlops that I , and many others, had to replace at around the 20K mile mark. The Dunlops were a P215 tire, slightly too narrow for this vehicle and low in quality, but ideal for tire swings. Since then I'm running Michelin Alpins in the winter, enough said, and the bigger Michelin X Plus P225's the rest of the year. Even though its an all season tire, I do not use run the X in the winter and elect to do the seasonal change to the Alpin. When you drive in winter to Winter Park and to Vail you want the assurance of the Alpin's. Sure I may of lost a few mpgs , by going to a wider X tire, but this tire looks good on the vehicle, it is stable as a rock at highway speed, and with the tires square edges it handles better than those low quality Dunlops. I actually gained the mpgs back when I switched to a Valvoline oil w/ MOA along with the use of a premium fuel. 27000 miles so far on the X radials and no visible wear, but again the X tires have not been driven in winter. The warranty is 80K miles, incredible. Costco has them. I would recommend them for this vehicle. Definitely there viable alternatives out there. My choice however was the Michelin X Radial Plus, since I only use them in non winter months.
The Brake Squeal, or 'brake howl' as it's technically termed, has been now finally fixed on my 98 Sienna, hopefully. The remedy was the "Adding of Wheel Weights to the inner back of both rear wheel brake backing plates". When I look under my vehicle you can see on each side 4 weights attached to the round backing plate. Each weight is about 3/4 inch wide by 6 inches in length. Total cost was 16 dollars. The key for me going forward is to keep the rear drum brakes cleaned on each brake inspection.
The Bottoming Out, has also been addressed without installing the so called 'air-bags' inside the springs. The solution was "to add Insulator Cushions under each of the rear coil springs". This raises the rear of the vehicle slightly but it's not noticeable. Its Toyota part number 48257-44010. Cost: each of the Insulator is around $17 dollar each plus the labor to install. You can notice the vehicle rides slightly better, The test will come this summer with my east coast trip.
The Rotors, as I mentioned in my earlier posting , were replaced by Toyota, years ago, at no charge to me via a Toyota Service Bulletin.
I have been reading on the internet that Toyota did something to the engine head on the new Siennas that reduces the temperatures that were causing the sludge problems in the 1997 - 2002 models. Does anyone know about this. Was this put in place on the 2003's or not until 2004?
Going up 1 size to the 225 will likely be a 60 series tire, meaning the height of the sidewall is slightly less. The diameter of the tire is then very close to the factory 215-65 (I believe). In effect you are changing both the tread width and the height of the tire sidewall by going up one size. I did that with my Bridgestone Turanza LS-Hs.
I tried to pull out the rear brake drum on the Sienna but it would't budge. I had no trouble with my Accord; the drum was pulled off easily Has anyone done this already, please give me advice. Thanks.
Looking at various specs for 225 vs. 215 shows they can increase the diameter of the tire up to an inch and a half depending on brand. For example my standard Firestones have a diameter of 26 inches. A tire bigger in diameter would cause a loss of torque I would think plus could cause the engine management computer to mis-read information due to different RPM vs. speed.
Don’t get me wrong I like the idea of the 225’s I just don’t like increasing the diameter of the tire.
Don't you wish there was a Haynes repair manual for the Sienna's? These manuals have been an excellent resource for troubleshooting and repairing my other cars, but Haynes has yet to publish one for the Sienna. Now there's a new model (2004), and the first Sienna's are almost out of their 5 year warrenty, perhaps there is a market for the manuals?
I wrote to Haynes when I first acquired our '99 CE van in 2001 (it had 310,000 km on it!!!) and asked if they were planning to publish one. They wrote back and said "not yet", but keep checking our web- site.
Why don't we all write to Haynes and ask them about the repair manual...maybe they'll realise there's a market for it? Write to info@ haynes.com
We currently have a 1999 (5/1999) Sienna van XLE with 60600 miles. The van has been problem free until 2 weeks ago when we had a check engine light ON while driving and as we had an appointment for 60K service it was dropped at the dealership. Initially the diagnosis indicated celluloid failure, then we were told torque failure and then yesterday the transmission itself. Now this would be a big dent on the budget as the transmission ($4200) and torque ($1600) etc. and as it is just 600 miles over the warranty I am trying to see what the dealership can do apart from the 'goodwill compensation' as this is our 3rd toyota. But reading thru few forums here as well as cartrackers.com it appears that there are many owners who have experienced identical problems at or near 60K miles some even earlier. I had been maintaining the van thru the same dealership (e.g. 15K,30K,45K service) and I donot tow boats etc. so there is no abuse as claimed occasionally. I think there is a real issue here with the transmission. How come so many have the identical issues at or near 60K miles.
Thru the forums I gathered that few cases were reported at NHTSA site as so many cannot be wrong.
We are disappointed too in the premature failure of the transmission as we believe this transmission problem is either a manufacturing or design defect.
Does any one had similar experience and could they get any results from the toyota national office.
bmwx5-I am starting to think that transmission problems seem to occur on most if not all minivans.We had a windstar which was well known for transmission problems.Chryslers problems are well known as well plus I understand Honda was having a lot of issues with the Odyssey.I am no car maven but I wonder if it is just that these things are bigger and heavier than cars and the transmissions are just prone to fail because of that. We have 50k on our Sienna and have had the transmission fluid replaced every 15k miles as insurance.If that will be effective down the road who knows.Hopefully Toyota will step up in your case-seems insane that right after your warranty expires your transmission goes.Good Luck.
reply to Yaman: Thanx and I agree but this is so un-usual (i think) well for now I got a split on the total cost (as they claim warranty expired), but still has to pay the half. My suggestion would be to take an extended warranty if possible to 100K if you plan to drive for few more years - as you never know.
I got a 2002xle and experiencing this type of noise(woobling/humming)started @7000mi.This is noticeably at the speed of 28 to 25 upon releasing gas pedal w/out steeping on brake.The dealer checked the vehicle but cant fix it,ive already spend three days without result.first,they said of cleaning the brake.Second time the master mechanic said about the bearing.Third time said it is the tire so they changed it, still same brand (affinity)
in USA. I presently have 4 vehicles with transmission problems: 1) '89 caravan, 2) '90 Honda Accord, 3)'93 saturn SL2 4)'95 Windstar. I also had '84 Astro & '82 Dodge Ram cargo Van with Transmission & Engine problems plus many other problems. Up until recently I would consider buying domestics because of their bigger size & it supported Local Work force. Whenever I went to Transmission shops, I would find chryslers, Fords and very few GMs and don't recall imports. But based on my 1990 Honda Accord transmission problem which dealer incredibly replaced in 30 days & below 500 miles, I have come to Conclusion that transmission problem is Design & Manufacturing Defect because my present car which was exchanged has transmission problem too. And I am sorry to say that even IMPORT Brands which use Transmissions & Engines Made in USA, hence have problems. Even on this Forum, I am sure we all will agree that Automibiles Made in Japan are better than USA. Although Honda, Toyota & others are making vehicles here for quota restrictions & many other reasons, the quality of Japan build is better and is why they still make their expensive Models in Japan. Unfortunately, like others have mentioned that Dealers call their problems Normal because they don't want to admit the problem exists and they cannot fix it either because they cannot fix it UNLESS company fixes the problem in transmission design & manufacturing. In my experience, the aftermarket transmission was better than the factory but even re-conditioned transmissions don't last long and are never same in driving as original & problem free transmissions. The main reason I still have those vehicles is I have a mechanic friend for past 10 years and I have never taken any vehicle to Authorized Dealers for service because as per my experience all have been like LEGAL LIARS & RIP-OFF SHOPS.
Transmission & Engine is like a Heart & Soul of any Vehicle, and if they have a problem then the experience of Owning & Driving is completely Disastrous. I will continue on this topic next time.....Sorry gotta go
I agree as said by bobbya2 "Transmission & Engine is like a Heart & Soul of any Vehicle, and if they have a problem then the experience of Owning & Driving is completely Disastrous." In fact we pay a premium to own these vehicles over others because of their reliability and safety. We needed the mobility and had to pick the van from shop with a new transmission but we are seriously debating whether to keep the sienna anymore.
bmwx5: My brother in law has a 2001 XLE. Our families took a trip to the Smokey Mtns. in NC two months ago. On the way back, his XLE's xmission went out doing 75 mph. The van had 55K miles on it, so he was lucky for it to go before the 60K warranty. The tranny did need replacement. He got a remanufactured unit vs. a new one. Stranded him in S.C. for three days. Now, I'm not a proponent of Chrysler products, but my '95 Voyager with a 3.0 and 102K miles on it has been one of the most reliable vehicles I've ever owned. That 3.0 is a Mitsubishi motor, which I'm sure is why I've had such good luck. Most of Chryler van engine problems are with the 3.3 and the 3.8 which are manufactured, I believe, by Chrysler. So, there appears to be an obvious design flaw here that's disappointing a lot of Sienna owners that are out of warranty. It'll be interesting to see if the new 5-speed auto on the '04 will have similar problems. Hopefully, you will have luck getting relief from Toyota on this obvious flaw.
I am no plans in 'not keeping' my Sienna around for years to come. With all the experiences noted above about the Sienna's tranny problems, I think one solution folks is to protect yourself from the high expense of having to posibly replace it , especially once out of warranty. My current warranty is for 6 yrs/60 miles, whichever comes first. My 98 Sienna w/48K miles on it will hit the 6 year expiry next Feb. I am considering looking into a 'Used Car extended warranty' to cover myself, not just in case the dreaded 'Check Engline' light comes on , while in SC, but for other items such as power window motors.... I plan on keeping this vehicle for another 5 years so it may be in fact feasible to consider such as a warranty as 'piece-of-mind' protection. What is it with all these tranny problems on the Siennas...just the fact its a moving part...driving habits...too much towing...or does the darn fluid need more frequent changing...
My '98 75k Sienna had the engine sludge problem and Toyota fixed it for free in a one-time "Goodwill" gesture without any hassels. While I'm very grateful for this, has anyone else had their engine fixed? Has the repair lasted, or could the same thing crop up anytime, even if you change the oil every 3,000 miles?
I have a 2000 Sienna that I've been thrilled with thus far. Presently, though, since my family has grown, I need to max out my van for carpool purposes and have found that the rear center seat belt is not a safe situation for a small child. It's not a shoulder belt, which is really what I need since four of the five kids are out of harnesses. Even as a lap belt, it doesn't retract and I've never felt comfortable with those locking clips provided by the car seat manufacturers. I can't believe that I'm the first person to have this problem. Does anyone know if Toyota has done anything to retrofit the seat to resolve this problem? Thanks, in advance, for your help!
2001 Sienna with a "jingling" sound over irregular roads, not rough or big potholes, etc., just not completely smooth. Sound comes from dash in front of driver, seems to come from left side of dash area. Sounds like change in your pocket, or maybe a washer or two hitting each other?? Anyone else experience this and have it fixed?
I don't know the answer to your question. I asked a question earlier about whether the engines in newer models had been fixed to prevent sludge and received no answer, so I have been trying to do some research. There is a very good resource for you right here on the Edmunds site. There is an archived discussion called "Engine Sludge/Oil Gelling Toyotas Customer Response". I found it by using the key word "sludge" in this site's search engine.
I am sure when I read the sludge discussion I saw a reply stating that it is not supposed to be a one time deal as you were told. I think you are covered for the 8 years, no matter how many time your engine sludges, as long as you can prove some sort of reasonable maintenance.
I have still not found the answer to my question. I have an opportunity for a fantastic deal on a used 2003. If the engine was not modified to prevent sludge and because the 8 year policy only covers through 2002, I could be out of luck should this problem arise. Anyone know if the engines were fixed in 2003?
As you know the dealership installed a new transmission at 60600 miles . Does anyone know how many years of warranty one gets after that? 'will it be for next 5yrs / 60000 miles or otherwise ? Any info is helpful.
From what i remember the engines affected were 98-01 (194hp 3.0). The PCV was "modified" and the new 3.0 is a VVTi engine cranking out 210hp (02-03).
The warranty is for 8 yrs if sludge is the reason but am not too sure whether it covers the 02-03 engines. Since the sludge topic surfaced in early 01 and died in late 01 i would assume everything has been solved. We have a 00 and have had no issues.
it most likely will be one yr or some mileage whichever comes first. you will NOT be getting anywhere near 5 yrs IMO. at 60k youre probably out of the origial warranty.
I believe most extended warranties simply require that the vehicle still be under warranty when it is purchased.
So, when I decided to purchase my leased Blazer, I was able to buy a 7/100,000 warranty on it as it had only 30,000 with 6k more to go until the warranty ran out. I know that is how it worked with that warranty and I would expect that is the case for nearly all extensions.
In my opinion, too many people buy them up front and wind up paying interest on them long before they ever use them.
you can buy an entended toyota care warranty before the 3yrs/60k kms or equivalent mileage is up. i bought mine a week before the 3 yr anniversary. Basically youre buying peace of mind.
Deepan, from what I have read here on Edmunds, the sludge discussions were halted about this time last year (2002). Also, I have read that the 8 year sludge policy covers the engines in the 1997 through 2002 models. It is also clear to me that there was a major redesign of the 2004 engines. It seems like the 2003's may be caught between the two -- not covered under the 8 year policy and prior to the major engine redesign in the 2004's. I am beginning to understand why I am being offered such a great deal on the 2003. It may not be worth it.
i know the 02-03 engines were "modified". I am not sure as to what yr (02-03) the sludge policy covers. having said that i've seen & heard fantastic deals on new 03 since toyota had to get rid of them before the 04 arrived which is a bigger van (engine, interior & exterior dimensions etc). I personannly wouldnt worry about the engine as its been a proven unit( camry, avalon, lexus lines all have the same engines). IIRC the sludge apparently affected only 0.01% of the engines.
Having said that have you looked at the 04. the older gen sienna which we have is a little small IMHO.
Sienna did some modifications to the engines between the introduction and 2000, and also between 2000 and 2001--including boosting the horsepower, but I don't know if this was sludge-related.
One thing I noticed when buying my Sienna in late 2001 was that they were only available with the Tow Package--not with a Tow hitch but with a transmission fluid or oil cooler--I don't know which. I found it curious that they
The oil sludge issue is way, way overblown. The cases were pretty few based on all the statistics I've seen. Probably alot of them were not maintained properely (Lube shops do not always do what you pay for!) On the other hand, there were some cases that seemed to indicate a sporadic problem (and one can understand why those people are upset).
If you change your oil every 3000 miles or so, then you will probably never have this problem--and use Toyota to do it just in case.
And thanks to cblake, we now have the extended warranty on engine sludge by Toyota in case there ever is a problem.
I wouldn't worry about the engine. Yhe reason you are getting such a great del on the 2003 is they are trying to get them off the lots. Plsu as I understand it, the dealers get allotted 2004 Siennas based on previous model year sales. If you like the 2003 compared to the 2004, go for it. You'll get a very safe, reliable van for a great price.
When my wife drove her 02 Sienna on uphill roads the other day, she heard the engine knocking a lot. She uses regular gas. Do you think this is something that can be corrected with higher octane gas, or is it something more serious? How damaging can knocking be to an engine?
My 2001 does the same thing. It has some type of engine noise under heavy acceleration, particularly uphill, though I'm not sure I would characterize it as a knock. The phenomenon does reduce with higher octane gas, though it's still there.
Thanks Carguy and Steve for the quick response. I guess it is more of a pinging noise rather than a "nock." I still would like to know though, how bad is it for the engine to ping? We live in a flat area, very rarely drive on hilly roads so the pinging is rare and not an everyday phenomenon.
2003 Honda Odyssey EX-LRES - Midnight Blue Pearl 2004 Honda Accord EX-L Graphite Pearl 2007 Honda Civic EX - Atomic Blue 2013 Honda Civic LX - Crimson Pearl
Our 2001 LE had the check engine light on..dealer info says: code P0174 system to lean. A/F lean malfunction bank 2. Rear manifold. This van has 44K and is 2.5 yrs old. They tell me the airflow sensor needs to be replaced and want over $500 to fix. Can anyone advise?
g) Road test
AJL1000
Seems to be present on the majority of 1999-2003 models.
sorry couldnt resist.
Dedicated winter tires are great for snow country; I have a set for the Outback to use to go skiing next winter.
But what diameter are these? Most 225 are around 1/2 inch more in diameter than 215's.
What model did you install?
for the manuals?
site.
info@ haynes.com
Or visit:
http://haynes.com/na.html and click on Ask Haynes about our manuals
Paul
'99 Sienna CE
323,000 km (no problems)
So whatchoo need a manual for?
-Mathias
'98 LE
'03 CE
I'm in a rut
anymore.
Thanks for all replys.
I've experienced premature transmission failure on a Dodge minivan and would hate to have the same problem on my 2001 Sienna.
Of course so far (2 years, 18,000 miles) the car has been flawless.
See the "Engine Oil Sludge" petition at
http://www.petitiononline.com/TMC2003/petition.html
Maybe try a different brand of gas or a different octane.
