Visitor Agreement.
If that's a problem, you may try running a complete fuel system cleaner--one that will clean the combustion chamber--like ChevronTechron or Redline SI-1. A fuel system cleaner, periodically, is always a good idea.
You too can win this battle against Toyota. Be persistent, keep diligent records and be prepared to go to arbitration. It didn't cost me any money, just my time.
If you do need another transmission, try to get some 'relief' from Toyota esp. since you have performed all the required maintenance.
First, they said i had a dirty mass airflow sensor.
Second, they said that the thermostat was operating corectly but they put a new thermostat in that lowered the coolant temp 10 degrees F.
Now, this did help as long as I ran 93 octane.
So, for the last 40k miles i have been running 93 octane. But just recently i have tryed 87 and its not pinging or knocking. Weird?
Like stated in one of the recent posts. These siennas have a high compression ratio engine. Naturally they will require a higher octane. Toyota just doesnt want to tell us this.
Thanks to all who contribute to this town hall. Lots of good info here.
1) Steering had a clunking noise when turning right after backing up the van.
2) The exhaust system had a squeak/rattle/noise coming from it during hot weather and long uphill drives.
The steering issue was located and resolved. Loose bolts in the front of the van I was told.
The exhaust noise was from the donut gasket between the header pipe and the secondary muffler. This one took several days to repeat and solve, but it was finally fix.
I only have one thing left "wrong" with my van and that is a squeak/rattle from the dash or driver's side of the van. I just can locate the source of the critter just yet.
When should I have the fuel injection system cleaned? Is it really time (years) or mileage dependant?
My story...
Two weeks ago, my 1999 Sienna had the 90K-mile full service maintenance. I paid around $890.
Now it started to have some whining noise. I could hear it once the speed reaches 30 mph. I brought it back to the dealer where it was serviced two weeks ago. Now they're telling me that it has some transmission problems. I also went to another shop (not a dealer) that specialized in Toyotas and Lexus and confirmed that.
Now, this is supposed to be a Toyota that I had always trusted. It just have 90,000 miles and now I have transmission problems? I couldn't believe this is happening to a Toyota.
I also have some sliding door. It won't work anymore. Same dealer said that the ECU and motor need to be replace. The cost to replace it is around $1,800.
I think I will never buy a Toyota again.
FYI, you can get the A540e transmission from phoenixhardparts.com for $895 plus shipping. A shop would probably charge 6-8 hours labor to install it. Much less expensive than the $3500+ that the dealer gets....
Thx for the info-big difference between what the guide says for 90k miles (less than $300)than the $890 paid.
Thanx for the wonderful link to maintenance guide.It's wonderful and informative.
1) I noticed the clock is not working
2) The Steering Wheel mounted controls for the sound system were not working
3) The next time I drove the vehicle the sound system controls WERE working fine, and still do.
4) Now I discover the external mirror controls don't work.
#1 only was reported to the dealer last week and fuses checked out OK. Cost quoted to replace the clock is so ridiculous that we would never consider that.
Any suggestions?
Maybe you have a similar problem. Or maybe a dead relative is trying to contact you.
It sounds like the motor is overloading and going out on high load or temperature - then it has to cool down. Isn't there a thermistor in the motor? Should I tear the door apart and lubricate? Any suggestions are appreciated.
I know if I take it to my friendly dealer it will need a new window motor, switches, brakes, engine, paint job, ball joints, and ECU.
Needless to say I was distraught! The reason I switched from a Dodge Minivan to Toyota was the Toyota reputation for Quality. I called Toyota Corporate and they opened a case file and referred me to the local dealer's "Customer Relationship Manager". My Sienna was not safe to drive anymore (really making a distinct grinding noise) so I took it back to the dealer and left it with the Service Manager.
Since, in my opinion, I had paid a premium for Toyota Quality I opted not to buy into an extended warranty plan at the time I purchased the van new. My fear now was that I would personally be out the cost of a replacement transmission (since the warranty period at the time was 5 years or 60K miles). I swore to myself that if it came out of my pocket I would get it fixed then trade it in - never to buy another Toyota product!
Now for the good news - the Service Manager has ordered a replacement transmission to be installed and fully paid for by Toyota. No one, either at Corporate Toyota or local Toyota, has acknowledged that Toyota has recognized the "bad batch" of transmissions installed in '98 '99 and 2000. My guess is that they wish to treat this on a case-by-case basis (without the negative publicity that would result from a documented recall).
The moral of this story is that if you have transmission problems with your Sienna (at least the '99 model) take it your dealer, be nice, be firm, provide your service documentation (if necessary) - you can convince them to pay for the cost of a replacement Transmission. This experience has, at least for now, restored some of my faith in Toyota products. It is unfortunate that I had to convince them! In my opinion both Toyota Corporate and the local dealer had knowledge about the transmission issues (in general) but refused to take the initiative and be proactive with their customers. That speaks volumes - that kind of behavior is what I expect from some of the unresponsive domestic makers but not from the likes of Toyota!
Can any of you give me a list of common problems with 02 Sienna's. I want to check the used ones I'm looking at for signs of these issues and I'd like to ask a mechanic to check the vehicles for these problems as well.
Also, does anyone know of any other bulletin boards, like this one, which are specifically for Toyotas. Sort of like FreshAlloy.com is for Nissans?
Thanks!!!
Try a net search for other sites - we frown on advertising/promoting competing forums on Town Hall. Thanks!
I had a friend once who could not drive above a certain speed in his vehicle because something got into and stuck to the inside surface of his rim, throwing the wheel off balance.
Get under the car and check inside each rim, you'd be surprised how much space is there for things to get into.
Just something simple you can check.
Good luck,
Howard
Did you ever find out what the problem was?
We apologize for the brake squeal concern you are experiencing with your Sienna.
We have researched your Vehilce Identification Number, 4T3ZF13C01UXXXXX, and determined that there are no Special Service Campaigns for your vehicle. We also have not issued any Technical Service Bulletins for a brake concern for the 2001 Sienna.
We rely on the technical expertise of our dealers. Our dealer technicians are given extensive training and use state-of-the-art equipment in order to obtain speedy and accurate diagnoses. We recommend you contact the Customer Relations Manager at your your local Toyota dealer for further assistance.
Your email has been documented at our National Headquarters under file #2003022XXXXX. If we can be of further assistance, please feel free contact us via email or by calling 800-331-4331. We are available from 6 AM to 6 PM, Pacific Time, Monday through Friday.
National Customer Relations
BTW to jasdmw - window seems to work fine now with no effort on my behalf. Humidity, lubrication, who knows? I'll lube it when I get a chance, but if it ain't broke...
Our's is out of warranty and I suspect that fixing a problem could be expensive.
I had a problem this past week on a trip with my 2001 Sienna LE that my tailgate would not re-open. It shut normally, but would not open with key or remote. I had power to the rear wiper and it seemed like me the lock was functioning, but the handle would not engage to open.
I took it in to the dealer who said that the "cable is broken" and since I have 38K on it (and am out of 3/36K warranty) that Toyota would pay for the part if I paid for the labor for $180.
The cable was not in stock, so I have to go back to get it installed. I absent mindedly went to put something in the tailgate at the grocery store yesterday and it opened fine repeatedly.
Question: Has anyone heard of this problem before? I wonder if cable is really "broken".
I have had car serviced, maint and oil changes at dealer and think $180 is too much.
So the last 2 messages I have posted have detailed 50% of the problems I have encountered in almost 5 years of ownership. The other 2 issues were a broken piece of trim and a interior fan motor replacement. Sure beats the performance of the Caravan I had which experienced 10 failures (sometimes bizarre) during the first 3 years. The Sienna has been a dream in comparison. Now if I can just keep my wife from wanting an '04 now that the '99 is only 3 payments from being paid off.
The problem is that the light has not gone back off. How long should it take for the light to go out? Should I take it to the dealer right away or give it a few more days? (There does not seem to be any other problem with the engine or the car other than the steering wheel shimmy with high speed braking that I've mentioned previously.)
it was a very polite letter stating that they have found some sienna's from 98-00 models have been experiencing tranny problems so they decided to extend the warranty. how nice of them!
