Oh yeah, like what, every 1000 miles? Silence...hello?
I recommend that you get a second opinion about what was making your oil "gummy". Are they afraid to call it "sludge" to keep from having to do a free repair? You may want to try another dealership or an independent garage. Ask them to pull the valve cover and be present when they do it --take a camera. You may need to wait awhile to let it build up again, since you just had the flush.
Did you have any other symptoms of sludge, like smoke from the exhaust? Were you using any oil between oil changes?
Does anyone know if there if something I can do about my 1999 XLE's power right door. Every now and then,(after touching the power door button) the door will almost close(about six inches from closing) and the then re-open. . . any thoughts would be appreciated. . .
Also my left side sliding door(non-power) seemed to "freeze up" one time. I could not open it from the outside or inside. I tried with a little too much gusto and broke a clip inside the handle so that the right side of the handle comes loose when the door is opened. The door was still unable to open. . . A little while later I locked and unlocked the doors and now I can open the door. Good news is the door opens. . . bad news is that right side of the handle is loose.
While I am at it. . .the only other current issue with our 99 XLE is that the seek scan button fell off of the radio. We can still seek with the steering wheel controls, but once again if anyone has come across any of these issues I would appreciate any help you can offer.
Dillydill
Does the Tundra have the same engine?
First, I am surprised more '98 Owners haven't chimed into this issue. I performed an informal verbal survey and found 22 out of 22 '98 Owners had one or both motors replaced. What are the odds of that happening on a random basis in three different cities? I conducted this survey in Seattle WA, Columbus OH, and Pittsburgh PA. Since the same motors are used in newer models, I also interviewed an additional 30 Owners of '99 and '00 Sienna's and not one of them had experienced a problem. All the '98 owners stated there failures occurred outside the warrantee period - so they felt compelled to pay for it.
In my case, I am the original owner, had about 86,000 miles, have been a loyal Toyota customer (four vehicles purchased over the past 10 years), and felt this was an unusual occurrence of "sudden and complete" failure of a basic motor.
The dealer said this was "not covered" but would do labor service for free. However, I would have to pay $580 for motors. I contacted Toyota and explained the situation and my documented informal survey. Without too much hesitation they reimbursed me for the motors.
It definitely doesn't hurt to contact Toyota Service and present your concerns. Those other owners should have done the same thing. I believe these failures indicate a bad batch of motors.
Food for thought,
L
PS My cd player just went out. This time I purchased an after market cd player from Best Buy and installed it myself. I use the cd player on a regular basis. It was pretty easy and not too expensive.
No, the van runs well - no smoke, no lifter clatter, no oil usage, no runs, hits or errors..., no problems. I usually check the oil via dipstick (although, not a real check for "gumminess") between changes but didn't on the last 3K miles but all previous checks showed the oil full and fairly transparent. Then again, this whole thing might have been because my "wife" took it in this time and not me - no aspersions cast.....
I'm just going to keep my eye on it at this point and see the oil on the next change and probably thereafter.
For the older models:
Sienna 3.0l V6
Tundra 3.4l V6 or 4.7l V8
I think the only way to get the TSB is to subscribe to ALLDATA or ask the dealer. I have not found my receipt for the O2 sensor, so I have not made the call to my dealer.
Make: TOYOTA
Model: SIENNA
Year: 1998
Type: PASSENGER CAR
Service Bulletin Number: TC03014
NHTSA Item Number: 10003372
Summary Description:
EXTENDED WARRANTY COVERAGE REGARDING A NO MOVEMENT OR A SLIPPING CONDITION OF THE AUTOMATIC TRANSAXLE. *TT
Thanks for the input.
Also, is $16,000 too much?
If your dealer won't give you the TSB, you could see if you could get the full document from www.NHTSA.gov or from Alldata.
I can't understand how software (new computer module) can fix this problem. I am guessing that the door works like a garage door, and if it meets a certain level of resistence it stops closing and reopens. The computer module replacement may just up the resistence level that causes the door to reopen. This GUESS on what is happening fits with lubing the door and slamming it closed manually for a few weeks causing a temporary fix.
There is also a reset protocol for the door. They have to disconnect the battery and open and close the door in a certain sequence to reset something in the computer module. That might be worth a try too. It did not work for me. The $800 fix is the only one that comes with a guarantee.
Thanks again. . .and I will keep you posted.
Dillydill
My wife is upset over the dealer's lack of confidence. She wants to cancel the part and go elsewhere. After reading an earlier post, I do want assurance that they will replace any broken parts or clips. A Toyota dealership should be able to attempt and complete such a repair.
Any advice will be appreciated!
Seb
My confidence in them is somewhat low. If they had said it the way you did, there would be no problem. I will try to get them to actually state that they plan to fix the "damage" even if it costs $1.50 a clip. I had visions of having to either face my wife with a severely damaged door panel or find another shop to repair their damage.
Thanks for the information.
Seb
Has anyone else dealt with this issue ?
Have 02 Sienna XLE, I had the coolant and transmission fluid changed on it's second year. The stealership didn't wanna change brake fluid then says it's okey.The van is going on it's 4th year (got it in 01) I just had an oil change and asked about changing brake fluid,after service stealership says fluid checked and it's still good they don't need change except top off. I am used to changing all this fluids every two years and I can't seem to find anywhere in the manual about brake fluid change frequency. Anybody here knows ? I would highly appreciate it. The van by the way has 37000 miles in it.
I asked the service advisor about it and he didn't give me a definite answer just gave my a bunch of bull.
I took it to our Toyota dealership for an oil change and asked them to check the belts...I explained what I had been hearing. They said the belt(s) looked good. The noise could be caused by moisture or dirt. Well, on the drive home I decided to stop at a car wash...to spray off salt grime (we had a snow storm). A few moments after driving away, it made the whine noise again. Possibly from cold water getting under hood?
I don't want to replace a belt if it isn't needed, but I don't want to be broke down with my young children either.
Any thoughts would be great.
I'm not sure what the "manuals" say, but I never change brake fluid.
I should note that I seldom get rid of cars with less than 300,000 on them-so it certainly doesn't appear to be a necessary maintenance.
mom:
Certainly sounds like a belt slipping, it may be a tensioner pulley needs adjustment-but your dealer should have been able to do that.
My Sienna has 60,000 mile, 2001 it will be 4 years old in April. I have not flushed out my brake fluid. The brakes are fine. The car still has the factory brakes good service so far I would say.
I think changing your fluid depends on the driving you do. City driving or some type of hard driving. This is not my strong point so for me it's done with the brake job I will need at some point.
On the transaxle though I have changed the fluid three times.
Simple answer, no, never did find it or get it fixed. To be honest, the Wife drives the van 90% of the time. I am driving a smaller car to work now, so don't spend as much time in the van as I once did.
Let us know if you get it fixed and what it could be.
Never towed a trailer and fluid was changed at 65K and looked fine.
First round with the dealer - they said it is NOT covered under the slipping / no-movement 100K warranty. Still waiting to hear back from Tooyota Motors USA.
Any updates from your side?
Clint
I wonder if someone got any experience getting a crack due to heat of the windshield? I can't think of any other idea how could that happen as the car was standing at my house road access all day...
thanks a bunch for the tip. Resetting the fuse worked for me too. I'll see how the van behaves from this point on. have you gotten the check engine light since? I wonder if our symptoms indicate that there is no problem with our oxygen sensors? Any insight would be appreciated.
Once it is all the way down, it takes its time to close fully, does in within a few minutes.
Did you ever find out the problem? Or anyone in this forum?
I have read switches were replaced, is this switch accessible and where can I buy one?
IMHO -
sorry to hear your bad luck...
Sooner or later it will get stuck in the down position. Of course, if it is not raining when this happens you can count yourself as fortunate.
