Visitor Agreement.
http://128.242.141.111/
This couldn't be used on my A/T tires because the tread pattern was too "groovy". Should be fine for regular highway tires.
-mike
I'm glad I replaced the bulb myself. It's one of those things that will be much easier the second time around.
"miles to empty" display on the MID changes from 170-something to low fuel.
It reset itself after driving and didn't happen again the next day. Wednesday it does the same thing, drops to empty then resets.
Thursday driving home, Check Engine Light comes on, solid not blinking. Made one stop, go to restart truck and the gas gauge does its drop to empty routine again.
Truck is running fine, no hesitation, no misfire. Checked gas cap, fine, OEM cap, and I always tighten at least 3 times.
The gas drop to empty only seems to happen when I am at 1/2 tank or less.
Before I stop by the ONLY dealer left in my area and waste my time just to get the "problem not found" or "unable to duplicate" typed on the service ticket, has anyone here ever heard of this? Maybe a fuel presure sensor? EGR valve? Have to check to see but I think part of the 30k service was something for the EGR cleaning.
Have a great weekend everyone!
-mike
Just to confuse matters even more I filled it up for the weekend Friday morning, in the afternoon on the way home, made a stop, restarted the truck and the CEL was off. That was exactly 24 hours later AND the 4th start... go figure!
I'll keep an eye on it when it drops to 1/2 a tank and see if the gauge drops to empty like before. If this happens again and I get a CEL I'll plan on a quick stop by the dealer to have him pull the code.
So in my case the preventative maintenance at 30K seemed to cost me a lot more money/problems than it was worth.
There was an article in the paper this weekend about Isuzu and its current dealer and future. Interesting, and Isuzu is still looking to cut its dealerships down a significant amount (something like 400 down to 250).
Your problem is probably much different than mine except for the common factor 30K service and then problems afterwards. Very frustrating.
Does the vehicle shake all over, or just in your steering wheel? If it shakes in your steering wheel, look to the front of the vehicle. If you feel it more in your seat, you will want to look to the rear.
Also, check the wheel weights on the wheels after they have been balanced. There should only be one weight on the outside and one weight on the inside of each wheel (2 wheel weights per wheel total). If you see more than one weight on any side of any wheel, take it back and tell them to do it right. I'm in the tire business and you would not believe how many times tire techs just don't know how to balance tires properly. Slapping an additional weight on a wheel "fools" the machine into thinking the tire/wheel assembly is balanced and gives it a "zero" reading but in fact it is not balanced and will continue to shake.
Hope this helps
Got my truck back on Friday after 2 days at the dealer. They replaced the fuel pump because it had a bad control module. I was told I was very lucky they had the pump in stock at the dealer, in fact it was the last one. Not sure how long it would have taken otherwise but with the ever shrinking dealer network, I'm not real thrilled with the future of owning an Isuzu. I know there will be parts available for some time but since this is my daily driver I need parts READILY available for same day service. As it is now, bringing the Axiom in to the dealer is starting to feel like the "ugly step-sister" syndrome.
Anyway, I'll keep an eye on it and see if this fixed it.
Thanks to all for the suggestions.
When following instructions in User's Manual on how to program garage door buttons, make sure the ignition switch is turned on (all lights are on). As I remember this step is either misprinted or not mentioned in User's Manual. The other two buttons - you can program them for other garage doors.
Anyway, the service guy was ex Isuzu and very knowledgeable, but this was his first look at an Axiom. His thoughts were very favorable. He definitely likes it and said it is a shame they did not do more to promote it.
Tranny fluid was a little dark but much better than most he sees at 30k miles, for those of us who do bring them in at 30k miles. His thoughts on the GM 4L30 tranny are that as long as you do a fluid exchange every 30k miles or 2 to 2.5 years and drop the pan and do the filter at every other exchange (60k), this tranny will last a very, very long time with no problems. For the price $94.00 exchange and an additional $30.00 to do filter, it is cheap insurance.
Other items of interest were the front and rear diff. Fluid was a bit more metallic than was expected, but nothing out of the ordinary. The next service should be much cleaner.
Now I have a question for you all:
I think I read about this somewhere before but can't remember where. After having the coolant done, I get a sort of swooshing sound coming from the passenger side dash area. Possibly the heater core or something? It does not last for long. It almost sounds like air and coolant are going through the lines at the same time. It does not do it all of the time, just after starting and reving the engine a little and then seems to go away. I checked the coolant level and it is full. I tried running the heater for a while to circulate everything but still hear the sound. Any thoughts on what it is?
http://www.homelink.com
Thanks in advance.
Dennis P.
P.S. Still love my Ax but isuzu needs to tighten up their customer service.
Did any of you try to bring your truck to the dealer and ask to have the brake rotors replaced due to warping? I am planning a trip to the dealer and address the issue of vibration at braking. Did any of the dealers replace the rotors under warranty?
This weekend, I replaced the rear axle oil as well as transfer case fluid. Both were really easy and cost me just $6 for oil - a fraction of what a dealership would charge. However, I couldn't figure out how to drain the front axle oil! There is just one large bolt on the front side of the axle, but no plug on the bottom for drainage. Does anybody know if I need to pump out the existing fluid through the side plug? I am confused. Also, I could not find the "shift-on-the-fly" plug, which is illustrated in the manual, but I couldn't locate it anywhere. Any help would be appreciated.
Just a reminder, I had a hard time to re-program the homelink buttons after I changed our garage door opener to one of those which needs to "learn" the signal from the remotes on its first use. Let me know if you have the same situation.
Joe
Look from the back for bolts(13-14mm) what hold front diff housing together. The bolt on 5 or 7 o'clock position is your drain bolt, it sometimes
fill with some gasket stuff so use drill bit and try to clear it.If all this doen't work, yes, you can pump out old/pump in new fluid.
I must say I'm tempted though Mazda6 wagon is a bit more tempting right now and it's in the same price range.
P.S. The rebate is $6500 on Rodeos and $5000 on 7-pass. Ascenders.
Are you still happy with your Axiom? As I recall, you had a major 4WD part replaced soon after you bought it. Any other problems? How many miles do you have now? How's the dealer service? And would you buy it again?
Anyway, if you can get the truck for the price they quoted you, you will have an awesome vehicle and money leftover in your wallet. How are you planning to transport the Ax to Georgia?
-mike
First posting, been following this forum for along time. I just got my 02 (35K) axiom back from Bill Stillwiell (sp) in Downers Grove IL. I had the problem with the moaning/vibration in my from right side when hitting the brakes. Talk to Dave in the Isuzu Service Dept. He is familiar with this problem, and has dealt with this on other vehicles. They replaced both front rotors and the problem is gone. It was covered under warranty. He said that they haven't had a problem with Isuzu covering warranty work, just that Izusu is a bit more anal about having all your I's dotted and T's crossed. I had to have a head liner kit installed because of recall on the axiom for Front Crash Impact. He said that Isuzu wouldn't cover the rotor problem if they hadn't done the recall work. (things like that.)
Love the forum. Its been great, and very helpful.
Bottom line, even with the rebates, it's still an overpriced vehicle. It will take a few more thousands to lure me in.
sbcooke: I purchased a used '02 Axiom back in 2002 from local Isuzu dealer. The Ax is made in April 2001, and was placed in service in June 2001. Dealer said that it was a fleet vehicle (I believe used by government or private company for a year), and therefore only basic 3yr/50,000mi warranty applies to my particular Axiom, which expired in June of this year. I also checked Isuzu's website, and it states that 10-Year/120,000-Mile Powertrain Warranty "excludes commercial or fleet vehicles".
cracovian: as I stated in my previous post, one of my main concerns is noisy engine. Did Isuzu improve its engine in 2004 model? I agree that sticker price of over $30,000 is too much for Axiom, but they have up to $5,000 cash back by August 2nd for all 2004 Axioms, so I may visit my Isuzu dealer and see what deal I can get with trade-in. The other concern is: even if I get another 3-Year/50,000-Miles basic warranty and 7/75,000 powertrain with new Axiom (vs. 10/120,000 for 2002 model), the number of Isuzu dealers is shrinking, and I heard that Isuzu may pull its products from US market because of poor sales. What am I going to do with my warranty?
And, of course, it doesn't make any sense to trade-in my Ax with new one only because of warranty concerns. Instead of paying the difference, which I am sure is not going to be small, I can buy an extended warranty and continue enjoying the Axiom. I just thought that there are some improvements that will make me go for it...
I've got the S model, but it's 4WD, so it has most of the options on it. It has great acceleration and I've had no problem towing my pop-up trailer with it. It hasn't really been off-road much, because I haven't had the time, but I hope to try that soon.
I don't know if it would be worth it to trade it in, but I can tell you that they have pretty good deals on them right now. You would probably take a hit on your trade-in value though.
I really think there should be some sort of investigation or recall of the tires.
My 02 has about 14,500 miles on it (low, I know) and recently, under wet road conditions, I have fishtailed (while going up hill/right hand turn) and slid sideways while negotiating an on ramp.
The fishtail was in 2WD mode...the sideways slide was in 4WD high.
No doubt -- these tires CANNOT handle the weight of the vehicle and/or it's higher center of gravity. I keep them at the manufaturer's suggested pressure (26 I think) and I have uneven wearing on the edges (I had them rotated at 7,500 miles).
I know these tires are standard on other SUVs (Honda Pilot to name one)...I can't see how they should be on any mid sized SUV that is over 2 tons. It just seems like an accident waiting to happen.
