GS 27..? Scratch removers under $10?
                    We're not talking waxes or polishes or cleaners here...I'm curious what you all use to take out scratches? Zainobros, fairly spendy and I'm not familiar with Zymol, is it a wax? They sell GS27 here in the sticks, $9.00, anyone used it before to rid the paint of abrasions?
Sooo..., what inexpensive products will take Purrs abrasions out of the finish on my '00 MitSu Eclipse?
Thanks for posting, Jack
The GS27 did not work and I returned it.
I may even try toothpaste to see if that has any effect, anyone done this?
Toothpaste is a mild abrasive and will work in some instances. If the scratches are more serious then professional body work may be needed. There's no way anyone can accurately tell you what product or technique to use without seeing the damage firsthand.
I'm not suggesting these items will work for you, but for me I've used 3 different compounds and polishes over the years. For most problems I've had excellent results starting with Meguiars #2 fine cut cleaner followed by #7 show car glaze. If the scratch is more serious I start with a 3M pro product called DRX65 which starts aggressive and mellows out.
3M swirl mark remover is between Meguiars #2 and #7 in aggressiveness and works great with a buffer.
Speaking of buffers, you should use a milder product if you're using a rotary buffer since it will generate plenty of heat and work the product hard. Stay away from wool pads unless you're willing to sacrifice your paint job.
If it's a deep scratch nothing will help, because the surface has been destroyed.
The results? No more swirl marks and a well developed bicep. Oh, and yes, a Winterfresh smelling 100% terry cloth towel.
