Chrysler 300M: Accessories & Modifications
2. What about HID kits for the 300M?
Last time I checked, coilovers were springs.
I very recently bought a 2002 300M Special from a friend of mine. 24,00 original miles & it is absolutely immaculate. Question: When the original tires need replacing, is there a tire choice, or wheel swapping choice, that would soften the ride just a bit? I commute across Los Angelels, rarely over 70 mph, & our rough roads keep the car unsettled. I would happily sacrifice a bit of the cars great handling for some added comfort. I'd welcome suggestions.
I will look to see if it is a workable solution.
best wishes,
Chris
T
Better yet, just post the details here so everybody can see it.
I recently crossed a similar situation with my 99' Chrysler 300m. The only difference is, I installed some cheaper form of the 7K HID bulbs for additional style, but because the car sits sooo low, nobody could really see them. I actually wanted to angle mine higher. I noticed as I was changing the bulbs (which was a pain in the a** completely), that there is a little screw, type thing in the middle of both headlights. In short, grab an alan wrench and turn that to the right. This will angle ur headlights down, as to not blind other drivers. Hope you get this and it helps!
Are there any empty boxes that you can replace the cd changer with? plastic tray fillers for example?
