Lincoln LS Accessories & Modifications
This question is for my 2004 Lincoln LS Sport v8. I bought a new chip that is supposed to increase my fuel mileage but now I am having problems figuring out which wires to hook into. The instructions says to hook it to the two wires of the plug from the IAT sensor, If I am looking at the right plug then I have 5 wires I believe. So needless to say I am at a loss as which to use. Is it possible that some one on the forum might have done this procedure and is aware of the color codes for the wires that I should use. Any help Is surely appreciated!
Thanks in advance.
Pete
2004 Lincoln ls v8
2004 Subaru Baja 2.5 Turbo
1986 Jaguar XJ6 Series III
http://www.gassavers.org/archive/index.php/IAT-Sensor-Mod-Experiment/t-149.html
You'll be extending the cigarette lighter socket....add 2 of them to the back of your center console.
I did and I've used both at the same time.
Was looking at mine today and they are paper in my '04. Were the speakers you got the 12 that are installed, or something else?
Mike
Actually, the code in located on the Computer Module.
http://www.tradebit.com/filedetail.php/9018747-lincoln-ls-2000-2005-service-repa- ir-manual
