Detailing Aluminum Engines and Parts
I'm wondering how you folks are detailing aluminum parts if you are so inclined to do so. My entire engine and attached components and most suspension parts and a few chassis members are cast aluminum and they are getting quite oxidised as aluminum is wont to do. I'm not talking tarnish-like, I'm referring to the kind of oxidation that looks like baking soda has been sprinkled on it. If you rub it it'll come off but leaving it looking like someone rubbed baking soda into it. How do you remove it and leave it looking more or less like new aluminum and how do you keep it from oxidising in the future or at least slow it down. A non oily/sticky solution would be most desirable as would be one with minimal elbow grease.
I had heard the aluminum/silicon alloys were more durable and reduced crud. I will be interested in other responses, as I have aluminum top parts on my 2000 exploder, and they still look good... but stunk mightily for some 2500 miles when the engine was up to temp.
Weird! Suddenly both doors developed the problem within a couple of weeks of one another. Problem is, once the doors are latched, no movement of the interior or exterior handles will open the doors. I pulled off the door panel and managed to open them by manually triggering the release mechanism, but even disconnecting the key lock and interior button doesn't help. I took one of the latches off the car & everything seems to be OK, but this one's a baffler.
P.S. If anyone's wondering why I'm worrying about a "beater," it's actually a Colt with an engine/trans/rear end swap, and is a "Colt" in name only. Mucho bux in this car, so I need the doors to work!
thank you
Mr. Shiftright
