A rev limiter typically cuts the supply of fuel to the engine, but it will NOT save you in the event of a mechanical overrev, which is what happened to cgr45. For example, if you're going 90 mph in 5th and then drop it into 1st and dump the clutch, the rev limiter will NOT save the engine. Fortunately, in this instance the transmission will almost always fail first, as with cgr45, so the engine doesn't ever get spun up beyond its rpm limit.
However, let's say the maximum rpm is 6000 rpm, and in 2nd gear at 6000 rpm the car will go 40 mph. If you're going 50 mph and drop it into second and engage the clutch, the transmission probably will not fail and the engine speed WILL exceed 6000 rpm.
I guess my point is that the rev limiter will not always keep the engine from spinning beyond its maximum rpm. It mainly saves you from overreving the engine when accelerating.
That's what I was thinking earlier. This is why I'm worry about Honda. I really think that I did some damage to the engine but, they said that the engine is fine.
If I remember correctly I was at 6500 rpm when I shifted to 2nd. That's 900 rpm away from red line. I don't know when the rev limiter kicks in.
After I pull over to the side of the road and turn the car off and back on. It crank right away and it idle normally but, a knocking noise was coming from the engine compartment. The tech says that is was the flywheel. The lever was stuck in 2nd but, I was able to move it. I had to pull on in extremely hard. It was so hard that I didn't want to move thinking that it would just make it worse.
I guess I'll find out tomorrow. I feel stupid for misshifting. What makes me angry is the fact that I was just driving, I wasn't racing or anything like that. I really need to pay more attention to shifting. At the time I had about a million thoughts running through my mind. I really learn my lesson.
Question- How fast will the Prelude go in 2nd gear at its maximum rpm? Perhaps the answer is in the owners manual. I ask because I wonder how much above the max rpm you went when you shifted into 2nd at 75mph. Depending upon the gearing, you may not have exceeded the max by that much.
I wouldn't feel bad about the misshift. I've done it also, but I was just plain lucky that I missed into a gear that was okay for the speed I was driving (I shifted from 4th to 3rd instead of 5th at about 60 mph).
A coworker of mine mishifted his Mustang from 4th to FIRST when trying to downshift to 3rd to pass another car. This was at freeway speeds. Not surprisingly, his clutch disc broke off BUT his engine was fine. Ford fixed the car under warranty and it's been fine since. I really think that the transmission is designed to fail before the engine during a mechanical overrev, but that's just a guess.
In any event, cgr45, if your car runs fine when you get it back, then I think you should be in the clear. I think the engine would run badly even it was damaged, such as a bent valve, etc...
I have a 5 speed, but not a day goes by when I am sitting in traffic that I don't wish I had gotten the automatic...if your daily driving is mainly congested...your doing the right thing by getting the automatic.
I have never put anything put premium in my Prelude, so can't help you with that. What I have heard is that you don't have to, but your performance won't be as good...but I don't want to take that chance.
Unless you plan on drag racing, an automatic Lude will be quick enough.
Unfortunately, the Prelude is being phased out supposedly to be replaced by a new coupe that will be something between the Accord Coupe and the new Acura Integra replacement...not until 2003 model year.
I think that the maximum speed for 2nd gear is 67 mph. I'm not too sure. When I get home I'll check some of the articles that I have on the Prelude. They list the maximum speed of each gear at redline. I'll let you know tomorrow.
hgiles- Thanks for the tip, but I am concerned about polishing and the look of the "xpel" product. I actually found someone who tried it (on a Porsche) and he said it was "a good idea, but not quite ready for the market." In the meantime, I'm just gonna take off the mask when it looks like rain and put it back on after everything's dry. To hell with obsessing about it...
Justin, the Sportshift Prelude is reasonably quick and it handles just as well as the five-speed model, so it's not a bad choice if you absolutely need an automatic transmission car, but...
The five-speed is so much faster, and so much more fun to drive, that if you're even remotely considering a manual transmission, you should take one for a test drive.
I have a question on my Prelude SH. I was driving and some idiot in front of me dropped something out of their truck and I ran it over it. It bent up my front right alloy wheel and shredded the tire. Now I'm driving on a spare and the ATTS light comes on. I'm wondering is the light coming on b/c of the impact or b/c it's riding on a spare? Anyone experienced this? I'm praying that it's b/c i'm riding on the spare and when I get the rim replaced it'll go away.
While looking around for a commuter car, I stumbled upon a 1990 Prelude. Since I was a kid I have loved this car. The car is automatic with 130,000 miles on it. They are asking $2500. Does anyone have some advice or insight? Is it a good deal? Will it be dependable? Please help Thanks
I just picked her up a few minutes ago. I'm so happy. The dealer was really cool about the whole thing. They replace the flywheel, clutch, timing belt and oil pump. The also change the oil on the tranny and engine.
The only thing that bother is that they scratch the car a lot. On the driver side there are 3 really deep scratches and a lot of little ones on the left quarter panel. The interior is also very dirty. The floor mat on the driver side is stain with mud and oil.
I really didn't have time to complain about this things, I was already an hour late for work. I'm taking it back tomorrow and see what they can do about it.
One last thing. The car does not feel th same as before. I don't know if is me but, It don't feel as quick as it used to. I'll wait a couple of days and see what happens.
I'm in the market to lease a new or used Lude, depending on the feedback. Will anyone share what their monthly payments are and how much mileage you negotiated?? Did you put a downpayment?? Any feedback will be appreciated.
I have a co-worker who leased a 98 SH for $451/mon with no money down. That is for 3yr/36k miles. He just turned it in this month. Since the price of Lude has gone up for about $300, I would think the lease rate will be a little bit higher, but $450 mihgt be an OK deal with NO down payment. The base would be cheaper, like $300 with $2000 down though.
Hey guys! I've recently bought a 2001 base Prelude and I've been reading up on all the possible mods. I'm thinking about putting in an AEM cold air first and continue with the headers and exhaust after that. My question is, would this void the warranty? What experience has anyone that has put in mods have had with Honda regarding warranties? Thanks in advance.
I'm leasing my Prelude. Is a 2001 SH. I'm paying $350 per month and put down $3,000. The only bad thing is that the lease is for 4 years. I'll probably turn it in by the end of the third year. If you need help figuring out some figures go to www.carsdirect.com so that you can get an idea, also this site is very helpful. I used the leasing tutorial and my payments came within $15 of what Edmunds told me.
I'm on the same boat as you. There so many things that I want to do to this car. Warranty should not void if you install what you have plan. The only way that the warranty would be void is if the dealer can proof that the mod create the problem.
I'm on thin ice with Honda as it is because of my mis-shift. So, I don't know if I'm going to install any mods. However, I'm installing new tires. Bridgestone RE730s. The stock tires suck in the rain.
I'm looking into purchasing a used Prelude(only 5 speed)..I've found this 1997 Lude red ext with 59,000 miles for $15,000...is the price right?..also is a prelude wit 60K reliable?..i want the car to last at least until 130k..
I'm not sure if 15,000 is high or not but I bought a used 1998 PRELUDE TYPE SH in black with 50,000 miles for $14,000 that is clean, no accidents and clear title. Even though the car is 3 years old it's solid as a rock and I think will go 200K pretty easy with maintenance.
Im looking at a 93 Si 4ws with 77,500 miles. I know from experience that Hondas are generally bulletproof, but have heard horror stories about 4WS. However, no one around here has a clue about these cars except the dealer, and of course they say the car is a reliablity tour de force.
If the 4ws fails, can you still drive the car, and what kind of maintainence (if any) does the 4ws system take?
I have a 98 Prelude and the hand-brake lever is loose and has some play before it catches. Has anyone experienced this and is it any easy fix of just tightening some bolts? Thanks for the input.
I have a '92 Prelude Si-4WS with about 101,000 miles. The only problem I have had with the 4WS is the warning light came on a few months ago at start up. I took it to the dealer and they checked the computer code and reset the light. Unfortunately, they charged me $75 to do it. They said it came on because of a power fluctuation to the 4WS, possibly due to a wearing ignition switch. Anyway, it was not come on since.
If there is some problem with the 4WS that causes the light to come on, the rear wheels will center and the car will drive like a normal car without 4WS. This information is in the owners manual. You will notice a decrease in steering response. I don't know of any maintenance for the 4WS. You will need have a 4 wheel alignment instead of just a 2 wheel.
The brake lever on my 98 has always been like what you described. I've never been concerned about it cause it does work properly. I wouldn't take it to be a problem unless it rattles or vibrates in normal position.
My Honda dealer does a periodic adjustment to my hand break lever as part of regular maintenance...you might check into it. They've done it on every Honda I have owned.
First I mis-shift now she gets stolen. It happened a week ago. The car was stolen from my driveway at 12:30pm. The middle of the day!!!!! No one saw or heard anything. I was home at the time. I was doing some construction in my basement. So I didn't hear a damn thing. I remember looking outside every 10-15 minutes. At 12:15pm she was there, 15 minutes later she was gone. I'm so mad. I had this car for a month and 3 days. I have to wait 3 weeks and if the car is not found my insurance compony will get me a new one. I hope that my insurance doesn't go up. I've been driving around town looking for the car and nothing so far. I even went to a couple of chop shops that I know to see if someone knew something. Everyone tells me the same thing. That I'm not going to find that car. The car is either in pieces, on a ship to another country, park somewhere with a broken clutch or burned up somewhere. I don't think I'm going to get another Prelude. Everywhere I went people would just look at it and they will give me funny looks. By the way I live in Jersey City, NJ. We are ranked 3 on the nation when it comes to stolen cars.
Pray they don't find it. I had an RX7 stolen and it was found stripped about 2 days later. It took several weeks, but I got it back and I swear it never was the same car after that.
I doubt there is much of a market for Prelude parts as its not that common of a vehicle. The more common, the more likely it will be stolen for parts. Its probably being used for a joy ride or on its way to Kuwait.
Your story doesn't bring me alot of faith in the anti-theft starter that is standard in my Prelude! What's it called? "Eliminator" or something like that. ???
Not to tell you what to do...but don't buy your next car based on how people stare @ you in it. Buy it because you love it. That should be all that matters...not what others think.
Are you sure it's your car they were staring at? Maybe you should check the mirror. HA ha h... Oh... I am sorry... I wouldn't feel like laughing either if my car got stolen. (those dirty bastards)
That really stinks man... now I'm scared to buy one. I'm looking into a 2001 base Prelude. I got an awesome deal for one. I wonder how they got the car without you hearing it...?
I have one quick question for all you 'Lude owners out there. I want to buy a 2001 new but don't want to buy the Honda spoiler. Can someone give me the dimensions of the rear of the car? I need the dimensions of the entire trunk from end to end and from the actual trunk door itself, side to side. Thanks!
The anti-theft system used in the Honda's is called Immobolizer Theft-Deterrent System... and I agree, if they got his car, whats to stop them from taking yours or mine, if I get it...
I waz thinkin of gettin a prelude as soon as i get my liscense next month. Just a queation though, i know in the previous prelude, there was absolutely no room to sit in da back. Is that the case in the 97+ preludes ?? Or is their sufficient seating for my passengers in the back seaT ??
The back seat of 5th gen Prelude is definitely larger than those of 4th gen. But, it is used for short trips or short/lean guys/gals (i.e shorter than 5'8" and 130 lb to be comfortable).
About the immobilizer, there is nothing you can do to really make it theft proof. If they want your car, they will get it. I heard that even with the security on MZ and Porsche, a "professional" theif can break it with in 10 sec. without touching the car. They have some kind of devices designed to transmit the same signal the chip in the key transmit to the ECU and activate the car without a key and open the door and drive away, just like it is his car.
So, if you really want your car to be safe, either park it in the garage all the time or use a club to protect it (I know that won't help much if you don't have a good security system. But, IMO, the immobilizer in Prelude is good enough to stop entry level theives and senior ones won't bother mass with a club for 10-20 min, they will just locate another one instead.)
cgr45: I was dead scared my new 01 prelude would get stolen. I didn't get factory alarm since dealer wanted $900cdn for it! but i did have them do this window etching thing just to discourage thieves.. and i installed an aftermarket alarm just 3 days after i got the car. ugh.. hopefully they'll deter most "amateur" thieves..
mohit07: yes the back seats are small. but OK for short people and kids. personally, i couldn't care less if the backseat drivers were having leg cramps. if they want leg room, let them go find a van or something!
The user's manual says regular gas can be used when premium gas can't be found and with the regular gas, the car will have slightly less power. so i experimented with it. not too sure about the power loss but the engine definitely sounded different. from the sweet "whirling" sound upward of 3000 RPM to somewhat low "growling" sound. I didn't like it so I filled the rest of the tank with premium. Did anybody notice this? does anybody run his/her lude with regular gas all the time? yeah I wish I invested in those stinking oil companies...
Well a week and 3 days have gone by and still no word. I already got over the shock. The car is gone and there's nothing I can do. I was thinking about this long and hard and I've decide to get another Prelude. I love that car. I'm not gonna let some thief kill my dream of having a Prelude. Just one problem. My parents. They want me to get an SUV. No way!!!
I have a question. The car was a lease. I spoke to my claim agent he says that I should get my down payment back. Is this true? I had GAP insurance on it. Now I'm getting nervous. I hope that I don't end up broke and with no car.
Good choice on getting another Prelude. Any car that's worth having is going to be worth stealing -- but that doesn't mean you shouldn't get it. As much of a hassle as it is to replace a car, it's still worth it to be able to drive a car you love every day.
I drive a '94 S10 Blazer right now and am looking at a 2001 Prelude. I can tell you SUV's are not the way to go. They are semi-uncomfortable to drive, hogs on gas, and just a nuisance in general. The smaller SUV's like the Blazer and the Explorer aren't bad, but I can't stand the Expedition, Tahoe, the beastly Excursion or Surbaban, Navigator, etc. The only points about them really are tons of space and four-wheel drive.
I have already posted in 2 other threads today my experience coming to work this a.m. in our Prelude, so I won't bore you with the details of it, but....for you Prelude owners, I have a question.
Doesn't it irritate the crap out of you that Honda chose a plastic headliner in your $25k sports coupe?
This car drives me crazy! I want to like our Prelude, but every time I drive it I get out of it angry. The constant "tick-tick-tick" of the headliner as the suspension picks up road feel is soooooooo irritating. The rest of the interior is dead silent, which I think is why the noise from the headliner appears so loud. You've heard the saying that "the silence was deafening"? Kind of fits here.
Am I the only one bothered by this? Am I just way too anal??? I traded in a '91 CRX for the Prelude and had a similar problem with it, I use to stuff gobs of kleenex into the headliner to keep it from rattling. I guess I expected more from the Prelude, considering the costs.
Its definitely a love/hate relationship between me and this car!
I hate my $22k 98 Prelude w/45k miles because it has a loud rattle that eminates from rear passenger side wheel well when the temp. drops below 70 degrees. Once the temp rises, the rattle goes away. It's been this way since new. I love my Prelude because of the engine/5spd outstanding performance. I love my Prelude because of its outstanding roadholding and maneuvering ability. I love it because it's fun to drive. I love it because I do enjoy driving it fast and constantly test its roadholding on sharp curves and hills, where this car's engineering really shines. I've never had any problem with the "ticking" complaint that other owners mention about the headliner. I do use my stereo to drown out that terrible rattle I hate so much. I would recommend this car, though, because it does have a bulletproof drivetrain that constantly challenges you to take it to the limit. I've had it 3 years and now the party's over. I always buy something different every 3-4 yrs. I owned a '94 Cobra before the Prelude and will now being purchasing my first truck...either a Tundra Limited or a Ford Supercrew Lariat. I'll always have fond memories of the Prelude, though. I think the Prelude is to Honda what the Karman Ghia was to Volkswagen back in the 60's. A very unique car for the true enthusiast who enjoys driving, wants BMW quality but doesn't want to pay a kings ransom for the car. To those of you considering the Prelude...definitely put this one on your list. I'm in Texas...the ladies down here love those weird headlights for some reason. Must be like looking into a man's eyes or something. Oh well, just my nickel's worth toward this thread.
John...you might want to have that rattle in the rear end looked into. I had the exact same problem and it turned out it was the rear strut. They fixed it under warranty.
In fact, if you look back in this thread, you should be able to find where someone posted the service advisory on the issue. I copied it and took it in with me to the dealer...fixed it with no questions asked. Stopped that rattle @ least.
Regarding that rattle...I've suspected the strut all along because of the rattle being notorious at 68 degrees and below, but going completely away at 70+ degrees. It's my fault, but I hate being without my car and failed to take it in during warranty period...but I really appreciate you pointing out that there's a post with TSB in this thread. I'll look it up as soon as I post this. Did I get my Tundra? No, I'm still struggling between that and the Supercrew. As you know, I'm turned off by Toyota forcing Gulf States option pkgs on buyers. But, enough of that, this is the Prelude thread, and I'll stick to the topic at hand. I'll get that strut fixed and some other maintenance done before I sell my Prelude. I want to make sure the next owner buys a car that's current on all maintenance. Again, thank you for the reference to the TSB....I'll go look for it now.
I found the post (#136) you referred to regarding the dreaded shock-rattle. I'm posting the site that has the TB for the benefit of other owners who may have missed earlier comments. If your Prelude rattles over bumps in cold weather, check this out: Credit to jkidd2 for pointing it out and credit to 5gen_prelude for posting the TB site. Thanks guys.
I just bought a 2001 Prelude base model a couple of days ago. If most people have had this problem with the rear strut, do you think I should confront the dealer now or wait and see if I have the problem myself...? I don't pick the car up until next week sometime.
I'd suspect that Honda would have fixed the problem....I'd print out the TSB and keep it handy, just in case.
Enjoy your Prelude, as critical of it as I have been, it really is a joy to drive...be careful, it gives you an inflated sense of your driving skills!
My only true complaint are the annoying interior rattles. It had a hard act to follow. I traded in my beloved '91 CRX Si for the Prelude...its never been able to live up to the memory of my little red CRX.
I was reading about the Prelude that got stolen. You 're much better off than me who own a GSR. In '99 1 out 10 Integras got stolen! The Integra had the highest theft rate in '99 and was still very high in '00. It's our VTEC motors they 're after because they can be easily installed in all Civics from '88 on up, and non-VTEC Integras and Ludes. Just make sure you have a garage in your house and you 'll be fine. 4 of my friends had their GSRs stolen right out of their driveway while they were sleeping. 2 of them had dogs in the house! What's funny is that one of my friends had Type-R wheels and brakes on his GSR with a different wheel lock on every wheel. That's 5 different kind wheel locks on each wheel. They found the car a week later with all the wheels and brakes intact. Everything else was stripped and only the chassis remained :-) I guess it was too much trouble for them to try and hammer all 20 wheel locks loose, hehe.
'99 Integra GSR '06 Civic LX coupe '11 BMW 335i coupe xDrive '13 Honda Accord sedan (wife's car)
Ditto to jkidd2's comments about TB and safety. Don't be turned off by the shock issue. Although jkidd points out interior rattles, I've been fortunate enough to have had zero problems in that regard. Overall, the Prelude's a great car and it's power train/suspension is an engineering marvel. It doesn't have a fancy interior or pretty face, but all of its true qualities are underneath its skin. You'll see.... if you got the 5spd, you'll have even more fun. Be safe, especially when VTEC kicks in at 5500rpm and you're screaming onto the freeway at an entrance ramp. Yahoooooo!!!!..... feel them sweaty palms!!!!
Just to mention 1 thing about the rattle when temp. are low. Yes, there is a TSB and the dealer will eventually fix it for you, but that will last for only a few month and it will come back again. It is really a problem of the bush(or coil.) and if you don't fix it, no harm will done on the suspension other than the noise that can be fixed by a loud music.
I pulled out my service info on the rattle problem...this is what it says on the invoice:
"When going over medium bumps you can hear a rachetting noise from right rear."
"Replace R/R Coil spring - per Bulletin 99-084"
That rattle hasn't come back since. Had it serviced on 2-2-01.
Plenty of others to take its place though...all of mine seem to come from the headliner...one of the biggest comes from the sun visors resting on the headliner. I tried adjusting the visors, but to keep them off the headliner, but not all the way down, positions them right into my forehead!
There won't be any new prelude for 2002. If your interested in it, get one ASAP.
Here is a site you might find interesting:
http://www.vtec.net/
Please help
Harry
98 Prelude SH
Thanks in advance.
Any help would be apprecciated..
thankz
dave
And SUVs? Just say no.
Thanks....just needed to vent!
98 SH
fun to drive, but only with the stereo up
Did you get your Tundra?
TB for rattle: http://www.sonic.net/~damn/dude/shock_knock_TSB.gif
Have fun and enjoy!
'06 Civic LX coupe
