Volvo 850 maintenance and repair issues
We have a number of single question type topics on this vehicle. I'm moving them all to this more generalized discussion so that our members can more easily ask for and find information on the 850.
Pat
Sedans and Women's Auto Center Message Boards
Pat
Look for a mom and pop volvo dealer they charge less than the car sales shops.
good luck
There are instructions somewhere on one of these sites that explicitly lay out the steps to do your light replacement. It didn't sound hard, just time consuming. If I find it, I'll fowrad the excat location.
And to you Acura person... good luck with it. Parts are just as expensive for Japanese cars as they are for Swedes. And guess what, Acura's break too. Just look at some of the posts for Honda and Accura.
Worst case scenario is that the bearings in the starter are starting to go, or the starter itself has a bad connection. Listen for a grinding or dragging noise when you start it. If you don't, it's probably the battery. How are the temps in your neck of the woods... it could also just be cold weather.
Scott
Any books/sites that will give me instructions????
The real difficulty and the expensive part of the replacement is in painting the new bumper to match the rest of the car - if it's painted to match the car in the first place. Painting plastic requires careful preparation of paint and flex agent, or the paint will peel off the bumper. It may also not be easy to match the paint on an 8-9 year old car perfectly.
You could also have 2-3 problems going on at once.
I don't find your Scandanavian's solutions very logical given the symptoms, but maybe his meters did pick something up to justify what he did.
What about new injectors...this will often cure a myriad of problems. If there are no leaks, no codes, and nowhere else to turn, well, it's a chance....
I'm a firm believer in the idea that your car is only as good as you maintain it. I've had virtually no problems with our 1996 854 Turbo (854=sedan/ 855=wagon) and have seen many high-mileage models with very few service visits. The engines should run endlessly, and it should provide you with a high level of comfort, performance and safety for a great price (used), with a little preventative maintenance thrown in.
Of course, my 854 is at the body shop after being broadsided by a Ford Focus... which totalled the Ford
http://www.rydwell.com/brick-page.htm
--java
2. there is a terrible rattle that seems to be coming from the latch on the 5th door. I put some Duck Tape on it and it relieved the problem, temporarily. But it caused me to lock the doors by attempting to open the back hatch. Is there an easier fix that replacing the entire latch. And were do I find parts?
My lights on the console between the front seats are out also......how hard is that to fix?
All of the fuses are good, what next?
I can honestly say we enjoy driving this car as much today as the day we purchased it (can't say the same thing for the previous Volvo 960 we owned).
We maintain the car very well and don't hesitate to fix something if it looks like it is going bad.
Engine mounts are famous for breaking down on these cars, so check them regularly. Expect an expensive brake job at 100,000 miles (rotors, etc), but if well maintained, this car will treat you right. Follow the scheduled maint. and you will be just fine.
As for the manual vs automatic debate, I would not own an automatic in a non-turbo Volvo.....The manual is a hoot to drive (however you won't find as many manuals on the used car lot, at least in the 1995 model anyway...back then you could not even get the manual with the turbo charged version in this country).
Also, what type of gasoline is required or recommended for the 850 Turbo.
KL Diefenderfer
Since the "test" was performed, the air appears to be working ok. My question is, how can I accurately determine whether or not the evaporator is truly the problem. I'm also uncomfortable with the wide disparity in the prices quoted to me. Any suggestions would be greatly appreciated.
Thanks in advance
After the repair, the a.c. works as well as it worked when I bought the car.
I decided to just recharge my system right before summer, as the cheaper alternative. At the time, I was due for a complete brake job (pads and rotors), so I was in no mood for another $1,000 service bill.
This problem is common, at least with the 1995 model, due to inferior parts. However, it always seems to start leaking "out of warranty", so the owner is stuck with the entire bill.
Thanks for sharing your experiences!
Its been hot in NYC, and I've been using my a/c since it was charged last week. Guess what? It works like new!!!
I'm now wondering whether my evaporator was really ever damaged/defective? Or, perhaps, it has a slow leak. In which case I'd rather pay $100 per season to recharge, assuming that the freon will last through the summer - rather that than dole out $1100.
I'd like to hear your opinions/views.
No matter how bulletproof Volvo engines may be, I don't think this is good enough to warrant the $1.5K over KBB retail he was asking.
I'd like your thoughts on whether this is a "walk away" problem, or just a "negotiate down" situation. The lack of records and commercial registration make me suspicious. His story sounds silly to me--I can't believe there is no service record anywhere. Is his story likely? Is there any significance to the commercial registration?
I told him that his dealership should stand behind its reconditioning with a one-year warranty, and he only acknowledged it as a possibility when I started walking off the lot. I'm thinking of offering him around $5K less than his asking price, unless he can prove that this vehicle hasn't been abused. Am I out of line?
Thanks in advance. I'm looking forward to hearing your opinions.
"commercial lease vehicle" probably means that it was leased to a company.(More like it was leased to some corporate executive who ran it through the business) So really nothing abnormal there.
Buuuutttt.....
$1,500 over KBB? With 72K? Sounds like a $11K or so wholesale and $13,500 retail car to me...
Somemore info would help. Color, etc... Where the car is at..etc..
As far as service records go, when my customers drop off their lease returns it's funny. They are standing there, talking to their salesperson, and grabbing everything with their name on it out of the glovebox. Can't say that I blame them...
Feel free to e-mail me...
Bill (No... not with a volvo dealer any more...)
For a Car that is "Supposedly" really reliable, I sure got shafted!!
Seriously, go to ANY Volvo dealership and you all can see for yourself. If this car is so reliable, how come the damn Repair lines are so long!!??? Do NOT Buy the 800 Series Volvo! Trust me!
And for those who confuse "long repair lines" with reliability, what they don't understand is Volvo owners follow "scheduled maintenance", vs. the normal car owners approach of "fix it when it won't start any more".
I take my Volvo in and have belts, etc changed out "before" they go bad. The timing belt is the best example of this "preventive" type care. Volvo schedules it to be changed out every 70,000 miles. I get a little more "preventive" by having mine changed out at 60,000 miles.
The net result of following a "scheduled" program is my car has never failed to start, or broken down (knock on wood) since I purchased it new in 1995 (135,000 miles later).
My experience with them has been the aforementioned a/c issues, also the automatic transmission appears to be showing an abnormal failure rate, and quite a few of general quality control issues. I have taken the time now and then to stop an 850 owner and ask him /her how she likes the car, and usually I get a mixed response. I have never gotten a "rave".
So that's all I've got to contribute. Not the best data, but it is interesting I think.
Were I in the market for one, I'd certainly do as much research as I could on consumer survey data.
In other words, perhaps the main reason mine has been so good to me (excluding the a/c issue), is because I don't have any options on my model (less to go wrong).
We knew we would be putting many miles on this car, so we wanted the "base" model, with no frills. (we even got the steel wheels vs. alloy).
vguard
cheers.
Keep us informed.
