meguiars products
purchased meguiars cleaner wax for silver car but was advised to use gold class clear coat
wax. can't find meguiar's polish in my area is there another polish that works well with meguiars. Also need advise on cleaning tires and keeping them black. please no amorall.
http://www.meguiars.com/
It does make sense however. After all, soap is soap right? But we use different soap for our bodies, our hair, our dishes and our clothes.
Depending on the condition of your paint, you might have to use several steps to get your paint in the right condition.
HOWEVER, after it is cleaned and polished, I would wash the already clean car one more time with DAWN or similar dishwashing liquid (normally that is a bad thing to use, but this one time it would be ok), and then let completely dry, and put on a couple of coats of #20 Meguiars Polymer Sealant.
It's harder to find, but you can purchase it over the internet.
It does a great job at shining and is the best from meguars at protecting the paint. HOWEVER, for the deepest, "wet water" look, you will need to use #26.
If you are not someone who waxes the car every week, #20 is probably your best bet.
Instead it says,"When Finish First is applied to the car, three important things happen. First, the cleansing agent in Finish First begins immediately to dissolve old wax, tar, road film, dirt, and organic contaminants which cling to the paint even after washing. Second, microscopic polishing agents loosen and lift dirt or oxidized paint, remove surface imperfections, and smooth out surface." http://www.finishfirstautopolish.com/FINISH_FIRST_POLISH.htm
You need to click on "More about Finish First" to read this
Microscopic polishing agents is simply another term for abrasives. It would be impossible for something to remove surface imperfections, oxidized paint, and smooth out the surface with out them.
I use Zaino because I know for a fact that there are no abrasives. Zaino will not remove oxidized paint, or remove surface imperfections. In fact, for oxidized paint or bad scratches, Zaino recommends using a 3M product before using Zaino. Zaino does have a product (Z5) that can fill in minor scratches and swirl marks, but not physically remove them.
I am not a distributor of Zaino products nor work for them.
TD
Al
Glaze is designed to bring out the gloss of your paint. But it has to be followed by a wax like #26. Sounds like you used the traditional cleaner/wax in the burgundy bottle. That stuff is a bit more aggressive in cleaning and light on the protection.
The #26 should last 3-4 months depending on a lot of variables like weather, garage or no, where you live, etc. Meguiars.com can help with more detailed info.
Al
I'm not sure what you are referring to as #28; prolly #26 Hi-Tech yellow wax. This is a combination of carnauba and polymers to provide a balance between gloss, depth, and durability. #20 Polymer Sealant is biased towards durability.
For a "one-step" product, Medallion is the best I've ever used. If you like to detail in multiple steps, you can use some of Meguiar's other products with great results.
Did you follow up with a coat of pure, non-abrasive wax? #7 is a glaze that offers no protection and cannot be considered a final step.
Al
http://www.finishfirstpolish.com
I've got a dark colored clearcoat, I'm in Mass so in the winter I'll be dealing with snow/salt/sand and my car is not garaged. - Meguire's Cleaner/Wax was suggested by my Mom as an easy to use product. I am willing to spend more time on my car than she does on hers so I am willing to try something other than that if I'd get better results.
So far the only product I've purchased is a "California Car Cleaner" ..... is there any harm in using that???
I'm a novice willing to spend a couple of hours on Saturday mornings cleaning my vehicle - I don't want to spend my whole day on it. Any tips?
Thanks very much
