Saab 9-3 Coupe (2002 and earlier)
Like every turbo engine, Saab engines require a minimum a maintenance, that is regular oil change and high quality oil.
If not, expect trouble, again, like every other turbo cars.
Saabs are build to last, anyone familiar with engineering will be able to see it immediately.
The mechanical parts are extremely durable, the electrical ones are as reliable as any European cars, that is .....below japanese standards IMO.
And to continue Stephan Belgium's "only in America" comment, the infamous unintended acceleration of some Audi models only occurred here. Apparently Europeans were able to distinguish between an accelerator and a brake pedal.
www.andrewsofprinceton.com/service/oil_sludge.pdf
www.consumerreports.org/cro/cars/maintenance-accessories/engine-sludge-1205/over- view/index.htm
In summary, the design of certain engines (and specifically the very fine oil screen on the 9-3 oil pump) can mean sludge can form very rapidly and be very damaging, especially if the oil pump screen becomes blocked. High-quality synthetic oil, frequent oil/filter changes, ideal ambient temperatures and ideal operating characteristics may not prevent the occurrence and reoccurrence of the problem.
Saab supposedly will repair sludged engines for eight years and unlimited miles. My 2002 9-3 is five years old and has 41K miles, so I will run out of the extended warranty at about 65K miles – which is when many 9-3’s start giving trouble because of mechanical wear. Saab themselves admit that 4% of European 9-3’s have engine failure due to sludge, and one wonders what the true figure is.
I’m going to get the oil pan removed at my local service station, and the oil pump screen inspected. If I’m lucky (our Saab has spent much of its life in moderate climes and has been treated to “severe service” oil changes when its actual use is relatively benign) I will find little or no sludge, but Flyndrive1 has dealt a blow to my complacency!
As an aside, I just talked to a dealer friend of mine who says Saabs are very cheap for him to buy right now, so it looks like the famed Saab resale value is also going into the tank! So now I have a late model car without an engine that is declining ever faster in value. I'm not sure whether to cut my losses or gear up for a fight. Either way, it's going to cost 6-10 grand. Best of luck to you, I hope you have one of the 250,000 mile Saabs.
My subsequent actions will depend solely on the extent of sludge that I find. Lots of sludge -- hello trade in! Minimal sludge -- change to 100% synthetic oil every 3500 miles, check again in 4 years, and keep for ever.
I'll keep my loyal readers posted. Should have the car in the shop within a couple of weeks.
On the web, Steve Crowe, a master Saab technician, states
"You will need to do a little more than just unbolt the pan. 1. remove the front pipe from the turbo to the cat. 2. Drop the right side of the subframe down to get the pan out. This is not too bad on a lift, but I bet it will be a blast on jack stands. If the car has a 5 speed removing the bottom trans cover will help. 3. Clean and dry the gasket area. Use Locktite 518 as the gasket (This is the factory stuff). 4. Make sure the oil cross over pipe does not fall out and the o-ring on it is not pinched to the side. If the tube stayed in place justleave it alone."
So I guess I'm back to square one. Do I have a ticking time bomb, or not?
In two months, at the next oil change, he will use the borescope to access the interior of the oil pan via the drain hole. The screen for the oil pump pickup may be inaccessible, but I should at least know whether sludge is present in the pan. At present things are looking up!
