Visitor Agreement.
I have contemplated the buy and cut-to-fit option but wanted to see if there were some aftermarket ones already available. I was planning on using the holes that are already there but was wondering how to make them stay flush with the existing flaps. I was thinking about using RTV silicone as glue. It sounds like the ones that you found were stiff enough that this is not required.
Based on my observations it looks like the new flaps will need to extend about an inch to the outside and several inches down to provide good coverage. Is this about what you did? The several inches down part is probably what gave Toyota the original problem. If they are down far enough to work then they have to be flexible enough to bend out of the way on obstructions without ripping the whole flap assembly off the vehicle.
Thanks for everyone's input!
Overall it looks o.k. and functions great!
I couldn't stand the sound quality of this basic system anymore so this weekend, I had the 4 main speakers replaced with Pioneer TS-A1667 6.5" 3-Ways. I must report that this upgrade has improved the highs 100%. The tweeters in the front doors have minimal effect so the new speakers really made a difference. The lows, however, did not really improve....but what can one expect from 6.5" door speakers?
Some interesting details from the install (I watched the installer do the job). The door panel removal was pretty tricky....especially the removal of the plastic bezel surrounding the door lock/latch. Then, the factory speakers were interesting, also made by Pioneer....they were molded into the bezel/spacers which mounted on top of the metal door panels. (Fronts were bigger than the rears) So the factory 'spacers' were not usable with the new speakers. Since there was very little space behind the metal door panels and the window, the installer had to fabricate spacers to raise the speakers away from the windows. I'm sure custom spacers are available out there, but time was of the essence here.
There are probably 2+ inches between the plastic door panel and the metal door frame so I suppose some larger speakers may fit but some degree of customization is necessary. But I think to fully round out the system, (without replacing the factory head unit), would be to add a 100 Watt 4 channel amp and a subwoofer. (not sure where to put a sub...a Bazooka takes up too much space and anything else would cost an arm and a leg to custom install into some kick panel or storage panel in the rear cargo area.)
But the biggest obstacle of all is to convice the wife of the necessity of this more complete upgrade. Any ideas?
My own car is using a pair of a/d/s components in the front doors and a pair of 10 inch a/d/s subwoofers. These are powered by a 4 channel Rockford fosgate(100x4) and a mono(250) Rockford fosgate amps.
Hope this helps.
Ken
Where are you located? You should have no trouble finding a buyer for your vehicle.
Slide the stupid headrest out by its two rails... now rotate the headrest 180 degrees and reinsert it into the holes... The headrest won't lock into place, but my wife has foung this solution of great relief. A more permanent solution would be to remove the headrest and find someone with a metal shop who has a large enough vise - clamping area- so that you could bend both headrest rails at the same time and experiment with a more comfortable angle.
Who in their right mind would design such stupid things??? GOOD LUCK AND let this board know how it works out. Thanks, Ken
Why not write them a letter to ask them if they have come to a conclusion as to why injuries increased in Toyotas using the improved seat/head restraint design.
http://www.roadandtravel.com/safetyandsecurity/ts_headrestraints.- html
http://www.iihs.org/news_releases/2002/pr102202.htm
Perhaps your local AAA or a company skilled in modifying vehicles for persons with disabilities can offer some advice.
I have been trying to find a place that would bend the headrest or take it apart and reupholster it with much less padding. So far without success. I have tried custom shops, machine shops, etc. I have even tried to find another headrest from another Toyota at a junk yard to see it it would work.
Also,I tried a Limited leather seat today and found the headrest in it to be very good. I am not sure what the difference is in the seat design that would be different from the cloth seat, but the headrest tilts which is great. Good luck with your problem.
I completely revamped the audio system on my HL limited. This included Pioneer DEX-1, 4 Polk 6 1/2 speakers , 1 12" JBL Sub, M357 Apline V12 Amp, 12 disc changer.
Lessons Learned:
Was going to keep my headunit since I liked the looks and the 6 CD changer - but my amp only included Pre-amp inputs So hence the Pioneer.
Thanks to all inputs on speaker door install. Was a breeze after figured out how to take door panel off.
CD Changer is under driver seat, Amp is under back seat ( However it is to big that the rear seat does not fold down all the way)
The sub makes all the difference in the world ! I have a quick disc kit and it is mounted in the back, The rear cover hides it well. Without the sub, the door speakers do not sound good, the door radiates as i turn up the volume and sounds terrible. It would be nice to hide the sub somewhere ? Let me know if you figure it out.
Good to hear you finally got that audio system upgraded! For me it was definitely no mean task -- Polk is an excellent name in speakers, and I have an Alpine V12 as well (MRV-F340); thanks for the feedback on your subwoofer experiences -- it pushes me a little closer to getting a sub (if I ever come up with a good idea of where to hide one, I'll let you know!).
One thing -- you mentioned you have a Limited with 6 CD changer, which indicates that you had the factory "premium" JBL sound system. Just to let you know the head unit DOES have preamp-level outputs, which are subsequently amplified to speaker-level outputs via an external amplifier that is in the rear of the vehicle (under the carpet behind the rear seat). But sounds like you have one super system. You know, we should have a Highlander convention sometime so we can compare how each-other's sound systems sound...
It is my feeling that these people got the car home and for some reason, maybe the spouse did not like it, are now looking for any reason to tear it down.
I also replaced all door speakers with Infinity kappas, 62.5 for the front and 60.5 for the rear. All speakers are being powered by a JL Audio 300/4 amp rated at 75 watts @ 4 channels. I also have a pair of Kicker Comp vr subs I wanted to install but my wife does not want to lose any trunk space. These changes also are a nice enhancement over the OEM speakers.
I would mention to the dealership that you have a medical history that includes previous or current back/spinal problems that make the seat uncomfortable for you. The way that the seat fits you is not comfortable, and you would like to know if they would be willing to work with you to arrive at a competant solution. It probably wouldn't be wise to attack them by accusing them of designing a poor seat - you may not get anywhere with that strategy.
P.S. - I have a limited highlander with cloth seats. So apparently this issue involves my seats as well.
If you watch on eBay there are people selling HLer interiors due to vehicles being totalled, etc.
Others here have used Infinity speakers. I have used Infinity speakers before and for my taste (accurate sound), they are some of the best. I plan on putting them into my new Highlander when it gets warm enough outside (above around 65 degrees to minimize cracking plastic parts when I pull off the door panels).
(For the heck of it, about six months back, I asked the dealership how much a replacement speaker for the front would cost -- around $150 for a SINGLE speaker (not a pair) that has a paper surround.)
Any info would be appreciated.
Jim
Romania Toyota
Auto wholesale parts
Yahoo Auto Fashion
WAAG.com
Performance Parts
Mats.com
No problems with any. The best thing about online buying is that its easy to shop around for the best deals.
