I just finished replacing the timing belt, water pump, and power steering belt and a few other misc. things, which ran upwards of around $850.
Before I purchased it my friend got the bright idea to put low profiles on it, for whatever reason and I'm now finding out that you have to be really rich when you live in Nortern Indiana to afford low profiles since you have to replace them with on a monthly basis (wonderful potholes :mad: ). Anyways, after replacing all those flats and bent rims, I've spent roughly $500.
If I keep the car, what should I do? Purchase 16" rims with new tires? That seems to make sense to me (even though I'll be sacrificing how good my car looks with the existing 17" rims that are on it)...that's what a couple local places have recommended.
Also, my battery went dead one morning and I found out that you have to have the security code to the radio when this happens. Wa-hoooooo... so I figure I'll just go look in the manual. Guess what, I don't have the manual and my friend doesn't know where it is. So I call up the Mitsubishi dealer and they tell me for $50 + whatever else they can charge ya for, they'll give me the code. It's the factory 10 disc cd changer by the way; quite honestly I don't want to pay $50 for something I should already have (and not to mention, its not like the radio is even worth $50) so I'm guessing I should just buy a whole new system, but I'm just too cheap to fork over a couple hundred for a new setup!
Fine, alright, no security code--as far as the new setup goes, any recommendations for an in-dash cd player?
Also, when I took my car in to have it detailed, Armor All or something of the sort somehow got inbetween the dash and the gauges in my car, so now it doesn't look all that great when I of course look at my gauges (it looks as if someone blew smoke into the gauges and it just stuck there.) I've been told it would be very costly to remove/replace/correct this problem...however you want to say it. Any thoughts or ideas :confuse: ?
And as a side note, I got into an accident a few weeks back. It was a hit and run... the guy took off and I eventually lost him, but anyways it totally tore up the bottom part of my driver side door, well not really tore up, it just put a rather large dent in it. Now there is some paint that's beginning to chip off and I can see a small amount of rust developing for whatever reason... I'm guessing to fix this it will cost around $1000 more dollars?
Lastly, my eclipse has a little over 76,000 miles on it, is there anything else that will be going wrong with it :sick: , and if so, how much will it cost?
Thanks in advance!
-Brett
http://autos.msn.com/research/vip/overview.aspx?modelid=2106&src=vip
And of course, Edmund's has loads of info. When you talk to say a Toyota or Honda loyalist, you may get the opinion that the Eclipse is just crap, but don't be swayed too much by that. It is not as bad as stated by some. Every individual car however has the potential of being a lemon, so you just have to keep that in mind too. If ya want to feel better, just look at the woes of many VW owners on their posting site. Oh my! Then you have someone that has not a problem one with their VW, so go figure???
:shades: Loren
Go visit a junk yard and see if you can find a gauge cover in good condition. It isn't an easy thing to replace, but you could probably do it yourself. Most cars allow you to open up the gauge cluster area with about 6 screws without tearing into the rest of the dash.
Its not that hard to remove the radio, i did it while waiting for my wife to get off work.. in the parking lot
Also, you should learn to do some repairs yourself. Tools arent that hard to use.. go to a junkyard, get a replacement door, unbolt the sucker and have it painted the same color as your car [this is hard and sometimes have to paint whole car so it matches].
Thanks again!
Brett
I was reading through the emails and saw yours. I am having a problem with the idle being erratic, replaced the Idle control valve after reading the CODE that the problem was in the throatle body, this did not take care of the problem. Very interested in knowing how you fixed yours, sounds the same problem. When you say Idle screw, where is the o-ring located ???? This could be the problem I am having.
Regards GSX1
BUT THEN i drove for about 3 minutes and when i went to stop a stoplight it died. By the time I got it home it would start for a second and then die. After the motor cooled back down it would start right back up and idle fine. The only way for me to drive it is to turn the idle up. Please Help
Thanks everyone.....
Please tell me the fuel pump is not inside the gas tank. Any help is appreciated. My next move, if I don't hear something definite, is to pull all 3 relay modules and take them to the dealer's service desk and hope for a knowledgeable attendant.
Email me: donnyhollis@comcast.net
I have a Mitsubishi Ecplisce 2000, GT. I recently paid it off about 5months. It has 133k. I kept regular maint. on car. Since I have new battery, starter, altenator.
Problem: When in drive at stop light my rpm drops (about 500) but comes back up (about 700)but car is still not as quiet seemly. I have not had tune-up since 65k could this be problem with drop in rpm and rise.
Car is not quiet when sitting still. Where should I be sitting still in rpm I'm about at 700rpm.
Could this also be a sensor? Which ones do I have?
At 133k could this be the problem; will the tune up help with silence my car?
I've never had a problem with my car and love it. Just seems I have to replace parts after paying off
Please help ,
mtsgt
mtsgt
I live in Balto. Md. Pruchased a 2000 GT in 1999. It's paid off now, I have 133k on it and never had any problems out of it. I only had the regular maintenace on it. I did pay 21k for it in 1999, new model off the show room floor. Its still running well, of course after 133k you can look to replace parts for it (starter, batteries, alternators) those things that would wear out after 5 years of driving on them never having a problem from them. Yes this car only designed to take premium gas and gas price are pretty steep here too, about 1.20 - 1.40 a gal. I did hear the ABS is not a good feature to have although the insurance aspect might save you some money. I expect after doing a few other things after 133k this car will run another 130k if maintained. I did have problems with the radio (no display but sound) the car was under warranty at the time and it was replaced.
Good luck
mtsgt
Again thank you
I got 60K miles on my eclipse spyder,
recently, every time I roll to a stop, the oil light comes up, and goes away as soon as I press the accelarator, most of the time the light sort of blinks, is it just a sensor, or something more serious.
I'll have it looked at ASAP. thanks again
Heres the deal on the radio. They charge you 50 bucks to remove the radio to get the serial number. If you do this yourself, and call them with the info, they will give you the code for free. It happens whenever you jumpstart or otherwise disconnect battery cables to the car. Get the code, write it down in a safe place and be done with it.
As I recently installed a new battery, my radio is obviously looking for a code. I can see no screws or anything on the face of the radio, to make removal simple. Care to share how you removed it so easily? Thanks for any help.
Also my check engine light is on now.
If anyone knows what to do please reply, cause i'm stumped.
I had the alternator and battery replaced around 12 months ago and a couple of weeks ago had the dealer check the power drain for the stereo/alarm and test the alternator and battery and they didn't find anything wrong.
Does anyone have any suggestions on how to over come this?
Or, maybe doing an engine swap with an eclipse. I was told they can be interchanged.
Any thoughts or ideas would be Greatly Appreciated!!!
Thanks for any Help,
Mark
I've been told by the dealer that the hydraulics were not created to be strong enough to support the weight of the spoiler, but there is no recall. Apparently the 2001 model was redesigned to solve this problem. Since Mitsu wouldn't replace it when under warranty, does anyone have suggestions on how/where to repair it? I haul a lot of stuff in that trunk so this glitch is really making me crazy and has me looking at new cars.
