Brake Life
98monte_ls
Member Posts: 117
My family and I have driven GM front wheel drive cars for a long time. Our experience has been that the front disc brake pads (semi-metallic)last anywhere from 20,000 to 28,000 miles and then start squealing loudly when the wear indicators make contact.
Well, I have a 98 chevy Monte Carlo and I have now 36,200 miles and I have the original brakes!!!
There is a slight pulsating feeling at times as I would expect the rotors to need resurfacing, and sometimes and I stress SOMETIMES I hear a little squeal not when the brake is applied. It is not constant like I have known the sound to be on other cars. I had the brakes inspected at 30,000 mi and they said I have plenty of pad!!!!!!!
Is this normal? Is this possible? Is GM using a longer-life pad today?
I had a little accident damage at 10,000 mi where they had to replace some suspension parts but I am wondering if they cheated and swapped out my brakes instead!! To my knowledge I have never had any work done on the brakes except having the rear drums cleaned/adjusted twice.
My Scirocco pads lasted 140,000 - would have been longer but the master cylinder went and that put a huge stress on the one front brake that still worked and wore in down by the time I could get a new M cyl. The other side still had about a third of its life left.
I have no problem believing a car can go 30,000 miles on a set of pads.
No GM car we have ever owned, not even the rear-drive '83 Olds Delta-88, has ever gone more than 30,000. And driven by two different kinds of driver - my mom is a chronically slow driver but I'm fast. doesn't matter.
I bought a brand new Pontiac Sunbird in '93 with 7 miles on the clock. Just rolled off the truck. When it hit 18,000 and the brakes were squealing loudly and people would turn their heads when I come up, I toook it in to the GM dealer and they say "oh that is quite normal to last 18,000 mi. We even see them last 12,000 mi!"
And don't forget local geography. To give you an idea, taxi cabs in San Francisco get new brakes every 6 weeks I'm told.
But like I said - the old rear drive Olds was in Michigan for 5 years and its brakes lasted 30,000 max. So who knows!!!
I could not be more displeased.
Why have they buoyed the rotor? I feel like I'm trying to get to my axle-not my brakes. For the first time since I worked for a mechanic, I'm looking at a tool that looks like a chicken foot.
the first AC delco tool was poorly machined and the bolts didn't fit through. Fourth trip to the auto parts store with a borrowed car...
So now, the tool that has a span of 4" made to fit standard CM cars, is no good I/I the center of the holes are 4" apart.
any suggestions?
(sorry if this in the wrong place, I'm still new at this)
By the way I live in town, and much of my driving is in the city.
Some of the variables:
1) Pad size
2) rotor size
3) driver's skill & habits.
4) vehicle weight
5) hydraulics (brake bias)
6) Type of transmissioon
7) geography
8) climate
9) brake lining composition
--- Bror Jace
Mark
--- Bror Jace
Out of your list, Number 3 is, by far, the most critical!
