MODERATOR /ADMINISTRATOR
Review your vehicle
I just got my new Matrix xr 4wd on the 12th of april and I love it. The only thing is that I hear a toc in the front left wheel when I'm driving slowly and I hit a bump or when I'm at an intersection and I start moving. They checked everything at the dealership yesterday and one of the 3 bolts on my shocks was not at the proper tighness. The thing is that I still hear that "toc". I'll be going back to the dealership next week but; does anyone have an idea of what it could be? Could it be normal that a new car adjust itself in the first little while and some noises are heard?
Thanks :confuse:
The question about disconnecting the thing came up as early as 2003. I seem to recall someone reporting that a service manager had reported that the headlights wouldn't work at all if the DRL sensor was removed.
pcotugno
Ross
Makes me wonder why I have a light switch at all in the car.
On the light issue. I'm one for more driver control so the auto lights are something that I care little about. Also on cars with fog lights... there needs to be a rear one too.
It'll gradually corrode if you don't use it regularly.
It'll still "parking brake" just fine...
...but it won't release properly.
Ask me how I know this... I've bought a lot of used cars.
-Mathias
PS - My dogs wear a harness seatbelt, so they won't be running loose back there with a child.
Anyway through my general research I have found some claims on the internet that the supercharger available for the matrix can actually improve fuel economy. Anyone heard of/experienced this? Seems unlikely to me but I am very far from an authority.
DC
pcotugno
Oh come now, it's not that big a deal.... if the DRL's were functioning properly, we wouldn't be having this conversation. I like mine, but I don't like that I can NEVER turn them off.
I wouldn't be satisfied with the brake light on all the time either, but it's not a crime against humanity.
BTW, by "brake light" he's talking about the little indicator light on the dash, not the rear brake lights that tell the guy behind you that you're slowing down. Now that would be bad...
-Mathias
I don't think it would work with my Vibe, though... to be clear: Before the rewiring, did your parking brake turn off the DRL's? It's supposed to work that way, but it doesn't in my car.
Thanks again,
-Mathias
For this reason, the Vibe GT never offered an auto, and the XRS didn't after the first year.
-Mathias
Option: Leather Faced Seats-LA10 $1,099
There is even one that is 4WD (it is base though not XR) with leather.
Did you ever find anything out? Bought a Matrix two weeks ago and I'm desperate for the beep-beep. I know other Toyotas do it - my dealer seemed to know nothing about the Matrix! Can't find in manual or Internet either. This makes me crazy!!!! :mad:
I hope I can use your knowledge to solve this very mysterious problem I had with my 2003 Matrix.
After jump starting the car, I noticed that both low beam headlights are not working.
Both bulbs are OK, and so are the fuses (left low and right low) same goes for the light master fuse (40 AMP).
High beam and all other electrical components work fine, when testing the bulb socket with a voltmeter I noticed I don’t get ground on the socket.
I get 12V on the fuse; I’m real confused about that
I’ll appreciate ant advice on the matter
oreng
Back in Virginia where I had a longer commute but few stops, I got 26-27.
I live in Florida, commute 120 miles a day. Does anyone out there knows how Matrix behaves on the highway during the rain? Is it worth to buy a Matrix with VSC (stability control) or ABS with traction control is enough? Or maybe AWD is a better alternative to VSC?
I don't think you need AWD. ABS and traction control with a good set of tires will do you just fine.
Perhaps you could find a way to test those options on a rainy day?
I'm in the market for a Matrix and drove a family member's new Vibe for a little while, and found the ride to be really harsh. Are there suspension differences between the Vibe and Matrix to make the 'Trix have a better ride? I was a bit disappointed when I drove the Vibe because I was looking to get a Matrix because of its good looks, practicality, and fuel economy. Would getting the 17" wheels help or hinder the ride comfort? Finally, would the Corolla be a better choice in terms of ride comfort?
Your comments or suggestions would be much appreciated. It seems that the Buick Rendezvous is the only one I've seen so far that combines road comfort and practicality, but the big V6 guzzles far more gas than the Trix would.
The 17" wheels will make the ride harsher.
The 17" wheels look great, but it's sad they take away from ride comfort.
Has anyone tried replacing the stock tires with larger tires?
Did you buy the Matrix? Tow with it? How did it do? I'm interested in doing the same thing.
baj
