Bug guards, protective bras & film
I bought a 2001 Accord EX on Friday and am considering purchasing a nose mask. I have problems with gravel trucks and "love bugs" here in Louisiana. I have heard that these masks can cover your nose and as the rest of your car fades what's under the mask doesn't. Any ideas on this? P.S my car is dark blue.
car bras? When I travel on the highway for a long
period of time there are bugs all over the front of
my car. Should I look into buying a front end
cover?
Would you have any advice about not getting one.
Do they damage the paint or front ends?
Should I get it from my auto dealer...Acura? Or
from an accessory supplier?
Let me know your opinions
The "factory" fit is pretty good, but you might be able to find the same for your Acura in an after-market item.
Unfortunately, while installing, I found a large chip in the hood paint already
...guess I should have put it on sooner...
As far as whether it's good to have on or not, though, I'm not sure. I installed one on my girlfriend's Civic today (we wanted matching cars, how dorky) and the directions for hers said that if water gets underneath and dries, it can cloud the paint. Most of the posts I have read say it's not damaging if you triple wax underneath, and wash and dry the hood frequently with rewaxing. That seems like a hassle, though.
Hope that helps a little.
Thanks for the response. I found out I can pick one up for $100 also from A & H. Could you tell me what the instructions/or your experience is w/ washing the actual front end cover? Do they hold up well while its actually raining or is it better to remove them if you know it will rain? How durable do they seem? But if spending $100 will save me some scratches and dents, I guess its worth it.
Thanks for the info
Around town, I think it's better to go "braless" because of their reputation for causing paint problems. My daughter left her bra on her car for a few weeks at a time and definitely had a paint fade problem when she took it off. It took some good, hard waxing, but I got the finish back.
No problems whatsoever... However, I'm a detail freak... I wash my car once sometimes twice a week, with regular wash/clay/wash/polish/wax sessions... I even do my wheels that way. I also always at least take off the hood-portion of the bra when I wash.... No fade problems, and no problems with the bra whatsoever... I also use Meguairs Vinyl & Rubber conditioner/protectant on my bra, and it looks like new, despite all the sun/rain/snow/bugs it has seen....
It'll hold up as good as you take care of the rest of the car...
Also, never spray armorall on your bra or your tires, if you want to keep them in good condition... It will promote cracking and drying out, despite their claims....
In fact, when putting anything on your bra or tires, make sure THEY DO NOT contain petroleum distillates, otherwise, they will eventually crack and dry out your vinyl and rubber....
One of the things to look out for when you remove your bra, is to remove any dirt particles or pebbles that may have found their way into it... Otherwise you will scratch your car... Also, if you use your bra in the rain, (but is always a good idea anyways), get some clay... It will get rid of all the crap that gets lodged in the paint under the bra, and all the other miscelaneous crap like rail dust from the rest of the car... And put a good coat of wax on the paint under the bra!!
1. Wash underneath every week or so and keep it waxed. If you get grit under it, the movement of the cloth as you drive will act like sand paper. Also, rinse off the back of the mask to get the grit off.
2. Take if off after it rains. Sun comes out after it rains, heats up the mask (black absorbs heat) which heats up the water trapped underneath and you can get paint damage. If you are driving the whole time (like on a trip), no problem cause the wind cools and evaporates the water underneath.
3. Don't put oily stuff on the mask to make it look shiny. They are all made with vinyl with teeny holes to let moisture evaporate thru the mask (to reduce paint damage). Oily stuff clogs the holes.
Yes, they require some care, but paint chips are real ugly.
schwanbeck,
So what products do you recommend for cleaning a Bra? What other cleaning steps do you also recommend? Is it fine to wash them w/ water then after they dry, protect them with certain products? What about the under part of the bra? Does it just require washing or does it also need a special cleaner different from the outside?
I'm thinking of buying one because my city uses
gravel a lot in the winter. However I've been
hearing that some people get discoloration because
their bra traps moiture and if sand ever gets in
between the bra and your car, it can act like
sandpaper.
This 'Bra" only makes things worse (Ruins the paint, decolrs-it, and makes stains) It ruined the hood of my Beretta !
Don't waste you're money !
Rob67
Any ideas?
What ever you do, only get a mask that your dealership recommends. This way they can be held responsible if anything occurs under they mask while you are using it. I bought an after market mask from Lebra for my 2000 Pontiac Bonneville. I only had it for a month and moisture and heat from the mask formed a cloudy stain in the paint on my hood! The dealership won't touch it and Lebra says I have to first take it to an auto shop to have heat lamps put on it to try to remove the stain and I will have to be reimbursed for that! I've used a Lebra mask on my 92 Bonneville with no ill effects. My wife used a GM mask for her 98 Grand Prix and no ill effects either, so I would just be careful.
Peace,
KZM
Be careful
I bought universal size from www.clearmask.com and I applied it to the mirrors on my 3.2TL and you can't tell it's there and it does a great job of protecting. I'm soon getting the clear bra for the whole front end and bumper.
The product is also sold at x-pel.com
KZM
Steve
anyway, I used to have a full nose mask for my previous car - kinda a pain to take care, but greatly reduced chips driving on the highways.
I am currently using the 3M clearmask - hoping that it will last as long as my window tints.
Usual disclaimers (and then some, lol)
Steve
Drew
PS - No luck using sites for '02 Explorer to resolve this either
It is the JC Whiney toll free # and there will probably be someone that will be able to solve your problem. They have contacts with all the "major bra" companies. Front end bras.. for cars...that is!!!!
TRON
As for bras, paint damage (fade) along with possible corossion (lots of salt on the roads in winter) detracts me from it.
Dinu
Or search there for "mud flaps" for posts like this one:
heintz1 "Ford Explorer/Mercury Mountaineer" Jan 4, 2003 5:15pm
