Chevy HD2500 Problems
I have a 2001 Chevy HD 2500 4 x 4 crew cab with 2800 miles. At 1600 to 2000 RPM the vehicle vibrates, kind of fills like your driving down a bumpy dirt road. The vibration goes away and then comes back at 2600 RPM. The dealer replaced the drive shaft saying there was a silent recall on this item. The new drive shaft did not correct the problem. The dealer and GM customer assistance have said the vehicle is working as designed. My feelings are if the vehicle is working as designed then why did they replace the drive shaft. Has anyone else experienced a problem like this with the New Like A Rock HD 2500 4 x 4 crew cabs? If so how was it corrected.I have the 6.0 eng. with auto trans.
Best of luck to you!
had 1 piece driveshaft replaced yesterday. It has corrected the launch shudder problems. The driveshaft is 6" via and aluminum. thanks for info
Peter
Chris
Any help would be greatly appreciated.
Michael
If your that worried about mpg the 6.0 and the 8.1 isnt for you.
For Scott - how many miles do you have on your truck and when did you start having problems? What kind of oil are you using?
Ryanbab, my husband used to be like you...when he was younger, just wait...someday that extra 2 mpg may make a difference to you!
Chris
Interesting story about the Firestones. One batch for Fords and another batch for GM? yeah, right.
Piston skirt length is too short. When cold it "slaps" against the cyl. wall. Most likely failure will be a broken skirt at some point, and or slow loss of compression in the cyl, where the skirt is wearing a grove in the cyl. wall.
Don't settle for the "lasts 100,000" line. Get the motor replaced or get rid of the truck.
Will report next week.
Still very happy, no defects. I do run premium fuel when towing near GCWR max....
My trucks is smooth all the way up to 90 mph, of course going over expansion joints will make the truck buck, but even my old half ton did that.
I have a 2001 2500HD EC 4x4 with 8.1L/Alli and at 3200 miles it rides like a dream with no transmission problems at all either!!
Bob
-Eric
So maybe the carbon buildup causes the pinging under acceleration (which mine desn't do) and the reason for the cold start knock is that the pistons haven't warmed up and thermatically expanded (is that a word??) inside the cylinder.
Oh well, until I can figure this out, I won't go, not ready to leave my baby with the dealer overnight...I guess I could call and see if they have even heard of the cold start knock issue...that's all I need is for them to start replacing stuff 'cause they don't know anything about the problem...
Time will tell I guess.
Bob
-Eric
