Oldsmobile Intrigue: Problems & Solutions
Thanks...bill
I'll also mention that my last oil change was at Jiffy Lube and I am not sure if they put in 5.5 quarts of oil or stopped at 5. that oil change was about 6500 miles ago. Since i have not seen evidence of any leaks, I'm guessing the oil may not have been completely full when it left Jiffy lube adn I burned off enough oil to trigger the sensor.
This is the first time this has happen since I owned the car. I thought I read where this engine is known to burn oil from time to time. If it does, no big deal. I keep watching for leaks and keep a quart of oil in the car. Is this engine known to burn oil?
I really like the car. The problem I have is the car is only averaging 19-20 mpg. This is w-90% highway driving. Does anyone have any suggestions or any answers? I know the sticker says 19-20 in town and 27mpg highway.
How many miles do you have on the vehicle?
Do all the other functions work, mist button,Variable speed, hi lo etc?
If so, when pushing on the washer button, two switch contacts are activated. One for the washer pump and the other to motor logic circuits within the motor. This other contact to the motor follows a similar path through the stalk wiring as the mist control and delayed wipers.
Have you tried to wiggle/push a little harder on the switch when it is spraying?
If the tranny is OK, the new plugs may help but certainly won't get you 8-9 mpg increase. Mine regularly returns between 28 & 30 mpg in steady highway cruising.
Howdy, yes very simple, lift up the white locking pins but be careful when wiggling and pulling out the assembly so as not to scratch the bumper.
If the pins do not want to go back in then theh assembly may not be completely seated.
Also to avoid repeated burnouts and weird flashing, make sure you have the same # for a replacement. A 3157 is not the same as the 4157NAK( Natural Amber Krypton) that is there.
cheers
Deke
Now to the questions: Does the 'B' in the error code imply that there are two sensors? Also, someone mentioned that the sensor needs a scanner to learn the proper positions, or something like that, but I never saw anyone else mention that. Does that mean I need to go to a dealer rather than having my friend fix this?
Sorry to be so wordy.
Carl
The crankshaft sensor actually has two sensors in the same piece, A and B, but both are needed. Therefore, both are replaced at the same time.
I chose not to replace it myself as it's necessary to remove the starter and mess with it close to one exhaust manifold from underneath the car.
HTH
:lemon: - trying to make lemonade out of it and keeping a positive attitude!
Carl
HTH
The dealer said I have a bad gas cap, it isn't sealing the tank airtight. This is what brought on my SES light. Apparently air can get in the fuel line if I remember correctly. How bad is this for the engine? I'm getting about 21 mpg in 70% highway driving, which seems a tad bit low (I'm expecting about 23 mpg, and recall seeing that in the past). Is this air in the line? Am I still filling up with oxygenated gas? Or some other issue? I have almost 90K miles on my 99 GL 3.5. Thanks!
One side note....our service engine soon light has never come on for any of these problems. It comes on when the key is inserted but I don't know if it knows how to report a serious event!
I am experiencing the same hard shifts on my 2000 Intrigue (115,000 miles). It only seems to occur from 1st-2nd gear. Once I get up to 3rd or 4th gear it seems to behave smoothly. It also seems to get worse the longer I drive. Meaning when I first start it up in the morning the Hard shifts aren't as severe as they are 30 minutes later.
I had the tranny fluid flushed and it didn't seem to help the problem. I have seen many postings on this subject and was wondering if anyone took their car in for a fix and what the diagnosis was. $$$ estimate. Any help would be great. thanks.
Before you do anything, keep track of the next 5 tanks of gas and getr an accurate MPG. At 90k miles, you are also pretty close to needing a tune up as well.
I was told by the dealer that it was a stuck solenoid. Apparently, it's a common problem with GM's auto transmissions. I was also quoted at around $750 to replace it. It hasn't happened in a couple months for me, so I'm not worrying about it until it acts up regularly.
dtownfb,
I'll go ahead and buy a gas cap, but not until I see what the next two tanks of gas do. Hopefully my SES light will cut out (it has cut out after about two tanks before). And I'm being very aware that I screw the current gas cap on until it clicks. The cap itself says to do this or the SES light may come on.
To Akitadog & Coop121: About the harsh shifts. We also had to have the solenoid replaced and new transmission after pieces of the gears broke off and we floating through the whole system. Maybe the solenoid could be covered under a "silent warranty". It might be still covered under the 100,000 power train. I'd ask a GM dealer about it. We get a fantastic 29-30 MPG highway and about 28 around town.
My wife's car is a 2000 with 70,000 miles. Recently she has experienced hard starts and the engine has been stalling occasionally. The service engine light came on and we took it to a local mechanic and had it scanned for error codes. We were told the camshaft position sensor and mass air flow sensor were bad, and we had them replaced. About 2 weeks later the same issues occurred. We took the car back to the mechanic and this time we were told the camshaft sensor was bad again, and it was replaced free of charge. It has been a little more than a month, the hard starting has been resolved, but the car continues to stall, and the service engine light goes on from time to time.
We had a friend scan the car with a OBD II interface and got the error code: P0101 mass or volume air flow circuit range / performance problem and unfortunately we cleared the error code. We took the car back to the mechanic but they could not get it to stall and they said there were no error codes, so everything was ok. The car continues to stall and the service engine light goes on and off, but the mechanic cannot duplicate the situation.
Based on information learned on this site, it sounds like it could be a number of things including the crankshaft position sensor, camshaft position sensor, ignition switch, or fuel pressure regulator. I never read any mention of the mass air flow sensor.
Could the stalling problems be related to the mass air flow sensor or is this a completely separate issue?
I have tried jiggling the keys to get the car to stall, but this did not work so I think I have eliminated the ignition switch from the equation.
Any suggestions to help resolve this issue and end my frustration are greatly appreciated!!
This TSB applies to:
00-02 Regal, Impala, Monte Carlo, Intrigue, Grand Prix, with 3.5l or 3.8l engine
Today I just bought a new pair of 4157NALL, which at least stated on the package that it replaced 4157NAK.
AFAIK, now, the K means that the bulb is filled with Krypton, an inert gas, which prolongs its life. The LL means long-life, but it didn't say anything about Krypton. We'll see.
It's going in on Wednesday - I just hope it gets repaired properly and without creating any other issues. To provide a little more background, in October 2003 when I bought the car, I requested details of any service work that was performed prior to my purchase ( the car was only used by the sales managers wife and hadn't been sold to anyone) and I noted the rear crankshaft seal was replaced at 9,000 km. - now I'm thinking either the side crankcase gaskets were leaking all along, or maybe the leak now in the same general area is possibly from a bad repair of the seal - I better inform them before they haul the engine out. Sorry for rambling - this is kind of therapeutic.
Have any members on this board had any oil leak issues?
